FOTA flow in sleeping nodes - need two cycles?
I've finally managed to get my RFM69 radios working almost 100% and am testing FOTA on my battery powered nodes.
These nodes sleep for 3h, wake up, do some processing, and then go back to sleep.
The summarized sketch is as follows:
void loop() { if (!isFirmwareUpdateOngoing()) { < read sensors and do the processing> sleep(SLEEP_TIME_3h, true); }When I upload a new fw to MYSController, the new fw is detected and the download appears to start for a few lines, but then the node goes to sleep and the update doesn't continue until the next wake-up cycle. This is the node log:
0 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.0-rc.1 4 TSM:INIT 4 TSF:WUR:MS=0 8 TSM:INIT:TSP OK 10 TSF:SID:OK,ID=8 12 TSM:FPAR 12 TSM:FPAR:STATP=0 14 TSM:ID 16 TSM:ID:OK 18 TSM:UPL 24 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 45 TSF:MSG:READ,0-0-8,s=255,c=3,t=25,pt=1,l=1,sg=0:1 49 TSF:MSG:PONG RECV,HP=1 53 TSM:UPL:OK 55 TSM:READY:ID=8,PAR=0,DIS=1 65 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:03000000400547620300 133 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 145 TSF:MSG:READ,0-0-8,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 159 TSF:MSG:SEND,8-8-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-rc.1 225 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0 258 TSF:MSG:READ,0-0-8,s=255,c=3,t=6,pt=0,l=1,sg=0:M 272 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=11,pt=0,l=17,sg=0,ft=0,st=OK:Sensor de humedad 337 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:3.0 446 TSF:MSG:SEND,8-8-0-0,s=1,c=0,t=35,pt=0,l=13,sg=0,ft=0,st=OK:Humedad suelo 454 MCO:REG:REQ 509 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2 524 TSF:MSG:READ,0-0-8,s=255,c=3,t=27,pt=1,l=1,sg=0:1 530 MCO:PIM:NODE REG=1 534 MCO:BGN:STP 534 MCO:BGN:INIT OK,TSP=1 540 TSF:MSG:READ,0-0-8,s=255,c=3,t=6,pt=0,l=1,sg=0:M 737 TSF:MSG:SEND,8-8-0-0,s=1,c=1,t=37,pt=3,l=2,sg=0,ft=0,st=OK:0 804 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:25 Value1=775 96.87 Value2=185 97.10 Result = 96.99% (0.43cb) VCC = 3.30 Volts VCC% = 25 % 819 MCO:SLP:MS=30000,SMS=1,I1=255,M1=255,I2=255,M2=255 868 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500 899 TSF:MSG:READ,0-0-8,s=0,c=4,t=1,pt=6,l=8,sg=0:0300000040054396 907 OTA:FWP:UPDATE 909 OTA:FRQ:FW REQ,T=0003,V=0000,B=053F 921 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003F05 958 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003F05FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 968 OTA:FWP:RECV B=053F 976 OTA:FRQ:FW REQ,T=0003,V=0000,B=053E 989 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003E05 1026 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003E05003F002100322E322E302D72632E3100 1036 OTA:FWP:RECV B=053E 1042 OTA:FRQ:FW REQ,T=0003,V=0000,B=053D 1054 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003D05 1093 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003D05003C4E4F4E43453E004F4B004E41434B 1103 OTA:FWP:RECV B=053D 1110 OTA:FRQ:FW REQ,T=0003,V=0000,B=053C 1122 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003C05 1155 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003C0525000D0A006E616E00696E66006F7666 1165 OTA:FWP:RECV B=053C 1171 OTA:FRQ:FW REQ,T=0003,V=0000,B=053B 1183 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003B05 1216 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003B0520566F6C74730056434325203D200020 1226 OTA:FWP:RECV B=053B 1234 OTA:FRQ:FW REQ,T=0003,V=0000,B=053A 1247 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003A05 1286 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003A05002520280063622900564343203D2000 1296 OTA:FWP:RECV B=053A 1302 OTA:FRQ:FW REQ,T=0003,V=0000,B=0539 1314 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003905 1349 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003905616C7565323D00526573756C74203D20 1359 OTA:FWP:RECV B=0539 1366 OTA:FRQ:FW REQ,T=0003,V=0000,B=0538 1376 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003805 1384 TSF:TDI:TSL 1388 MCO:SLP:WUP=-1 1390 TSF:TRI:TSB 1398 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000 1867 OTA:FRQ:FW REQ,T=0003,V=0000,B=0538 1878 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003805 1914 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003805207375656C6F0056616C7565313D0056 1925 OTA:FWP:RECV B=0538 1931 OTA:FRQ:FW REQ,T=0003,V=0000,B=0537 1943 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003705 1978 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:0300000037056564616400332E300048756D65646164 1988 OTA:FWP:RECV B=0537 1996 OTA:FRQ:FW REQ,T=0003,V=0000,B=0536 2009 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003605 2045 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:03000000360507010353656E736F722064652068756D 2056 OTA:FWP:RECV B=0536 2062 OTA:FRQ:FW REQ,T=0003,V=0000,B=0535 2074 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003505 2111 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:03000000350507070707070707070707070707070707 2121 OTA:FWP:RECV B=0535 2127 OTA:FRQ:FW REQ,T=0003,V=0000,B=0534 2140 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003405 2174 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:03000000340507000204060707070707070707070707 2185 OTA:FWP:RECV B=0534 2191 OTA:FRQ:FW REQ,T=0003,V=0000,B=0533 2203 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003305 2238 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:03000000330500AE0A7E0ADE0A520A760A620A530A05 2248 OTA:FWP:RECV B=0533 2256 OTA:FRQ:FW REQ,T=0003,V=0000,B=0532 2269 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003205 2304 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:0300000032051151117C112B12AD118B119F11000000 2314 OTA:FWP:RECV B=0532 2320 OTA:FRQ:FW REQ,T=0003,V=0000,B=0531 2332 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003105 2371 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003105FF3AFF3C053D106F30FF0000000000E4 2381 OTA:FWP:RECV B=0531 2387 OTA:FRQ:FW REQ,T=0003,V=0000,B=0530 2400 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003005 2433 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003005DC2C002D032E882F2D306437D4384239 2443 OTA:FWP:RECV B=0530 2449 OTA:FRQ:FW REQ,T=0003,V=0000,B=052F 2461 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002F05 2496 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002F0502044005030633188819422607281029 2506 OTA:FWP:RECV B=052F 2514 OTA:FRQ:FW REQ,T=0003,V=0000,B=052E 2527 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002E05 2562 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002E05FF1F0A1F0A01FFF709CF080104020003 2574 OTA:FWP:RECV B=052E 2580 OTA:FRQ:FW REQ,T=0003,V=0000,B=052D 2590 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002D05 2625 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002D056C084208A40856042708D407A8079507 2635 OTA:FWP:RECV B=052D 2641 OTA:FRQ:FW REQ,T=0003,V=0000,B=052C 2654 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002C05 2689 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002C055040E0F70895F894FFCFFFFF5A073207 2701 OTA:FWP:RECV B=052C 2705 OTA:FRQ:FW REQ,T=0003,V=0000,B=052B 2717 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002B05 2797 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002B0548F001900D920020C9F701C01D924150 2807 OTA:FWP:RECV B=052B 2818 OTA:FRQ:FW REQ,T=0003,V=0000,B=052A 2828 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000002A05 2928 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000002A0541505040D8F70895FB01DC0141505040 2938 OTA:FWP:RECV B=052A <continues>As can be seen, the node starts, presents itself, etc, does the first processing cycle, and arrives to the sleep instruction (line 819, sleep time reduced to 30s to speed testing). Then some CRC seems to be exchanged with the gw, and it is determined that an fota is needed (line 907). Then some blocks of code are received until the node goes to sleep after receving block 0538 (line 1384). When it returns (line 1388), the update continues with the same block and from there on to the end of the update.
As a side to this, I've capture occasions where the node determined that no fw update was necessary, went to sleep, and then did an update after waking up, like in this case:
942 MCO:SLP:MS=30000,SMS=1,I1=255,M1=255,I2=255,M2=255 993 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500 1021 TSF:MSG:READ,0-0-8,s=0,c=4,t=1,pt=6,l=8,sg=0:0300000040054396 1028 OTA:FWP:UPDATE 1030 OTA:FRQ:FW REQ,T=0003,V=0000,B=053F 1042 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003F05 1071 TSF:MSG:READ,0-0-8,s=0,c=4,t=1,pt=6,l=8,sg=0:0300000040054396 1077 OTA:FWP:UPDATE SKIPPED 1089 TSF:MSG:READ,0-0-8,s=0,c=4,t=1,pt=6,l=8,sg=0:0300000040054396 1097 OTA:FWP:UPDATE SKIPPED 1501 TSF:TDI:TSL 1503 MCO:SLP:WUP=-1 1505 TSF:TRI:TSB 1513 TSF:MSG:SEND,8-8-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000 1531 OTA:FRQ:FW REQ,T=0003,V=0000,B=053F 1581 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003F05 1615 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003F05FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1626 OTA:FWP:RECV B=053F 1636 OTA:FRQ:FW REQ,T=0003,V=0000,B=053E 1646 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003E05 1681 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003E05003F002100322E322E302D72632E3100 1693 OTA:FWP:RECV B=053E 1697 OTA:FRQ:FW REQ,T=0003,V=0000,B=053D 1710 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003D05 1980 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003D05003C4E4F4E43453E004F4B004E41434B 1992 OTA:FWP:RECV B=053D 1996 OTA:FRQ:FW REQ,T=0003,V=0000,B=053C 2009 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003C05 2048 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003C0525000D0A006E616E00696E66006F7666 2058 OTA:FWP:RECV B=053C 2064 OTA:FRQ:FW REQ,T=0003,V=0000,B=053B 2076 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003B05 2111 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003B0520566F6C74730056434325203D200020 2121 OTA:FWP:RECV B=053B 2129 OTA:FRQ:FW REQ,T=0003,V=0000,B=053A 2142 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003A05 2416 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003A05002520280063622900564343203D2000 2426 OTA:FWP:RECV B=053A 2433 OTA:FRQ:FW REQ,T=0003,V=0000,B=0539 2445 TSF:MSG:SEND,8-8-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:030000003905 2484 TSF:MSG:READ,0-0-8,s=255,c=4,t=3,pt=6,l=22,sg=0:030000003905616C7565323D00526573756C74203D20 2494 OTA:FWP:RECV B=0539Lines 1077 (and 1097 again for some reason) indicate UPDATE SKIPPED; the node goes to sleep, but then an update is launched after wake-up.
Of course, no changes in the ino.hex file were done while the node was sleeping.
Would this be expected behaviour or is there some inconsistency? The fact that the firmware update needs to wait until the next wake-up cycle is very inconvenient in this scenario where the node sleeps for hours.
Alternatively is there some detailed description of the FOTA update process flow where I can try to understand?
I will try to check that if I get some time, but you still can block your sleep mode until FOTA is finished (by adding a condition in your sketch)
@manutremo you're right. i need to take a look
@scalz Many thanks, let me know if I can help further with the testing.
Regarding your comment on blocking the sleep - how would that be done? I thought the conditional in my sketch (shown above) would already be blocking it.
@manutremo Can you post the entire sketch + full log when you receive a "OTA:FWP:UPDATE SKIPPED" message. In addition, it would be helpful to get infos on your setup, i.e. HW, IDE & board definition versions.
@tekka Sure, here it goes:
#define MY_RADIO_RFM69 #define MY_RFM69_NEW_DRIVER #define MY_IS_RFM69HW #define MY_RFM69_MAX_POWER_LEVEL_DBM 13 #define MY_RFM69_FREQUENCY RFM69_868MHZ //#define MY_DEBUG_VERBOSE_RFM69 #define MY_PARENT_NODE_ID 0 #define MY_PARENT_NODE_IS_STATIC #define MY_TRANSPORT_MAX_TX_FAILURES (3u) #define MY_OTA_FIRMWARE_FEATURE #define MY_OTA_USE_I2C_EEPROM #define MY_DEBUG #include <MySensors.h> #include <SPI.h> #include <Vcc.h> #include <Streaming.h> #include <math.h> #define SLEEP_TIME_15min 900000 // 15min x 60s = 900000 ms -13% = 783000 (my arduinos show a delay of 8s/min = 13%) #define SLEEP_TIME_1h 3600000 // 1 h = 1*60*60000 = 3600000 ms -13% = 3132000 ms #define SLEEP_TIME_2h 7200000 // 2 h = 2*60*60000 = 7200000 ms -13% = 6264000 ms #define SLEEP_TIME_3h 10800000 // 3 h = 3*60*60000 = 10800000 ms -13% = 9396000 ms #define VERSION "3.0" #define PIN_ALIM1 4 // Connect to input of resistor #define PIN_ALIM2 7 // Connect to input of measuring probe #define PIN_LECTURA A0 #define AGUA_DIR 800.0 #define AGUA_INV 160.0 #define AIRE_DIR 0.0 #define AIRE_INV 1023.0 #define TIEMPO_LECTURA 10 #define MAX_REP_LECTURA 20 #define MAX_REPORTING_LOOPS 4 // Battery calibration (Li-ion) const float VccMin = 3.0; // Minimum expected Vcc level, in Volts. const float VccMax = 4.2; // Maximum expected Vcc level, in Volts. const float VccCorrection = 3.82/3.74; // Measured Vcc by multimeter divided by reported Vcc #define CHILD_MOIST_ID 1 MyMessage msgmoist(CHILD_MOIST_ID, V_LEVEL); Vcc vcc(VccCorrection); int count=0; signed int oldv1=0, oldv2=0; float oldresultcb=0; void setup() { #ifdef MY_DEBUG Serial.begin(115200); #endif analogReference(DEFAULT); pinMode(PIN_LECTURA, INPUT); pinMode(PIN_ALIM1, OUTPUT); pinMode(PIN_ALIM2, OUTPUT); } void presentation(){ sendSketchInfo("Sensor de humedad", VERSION); present(CHILD_MOIST_ID, S_MOISTURE, "Humedad suelo"); } void loop() { if (!isFirmwareUpdateOngoing()) { signed int value1=0, value2=0, i=0; float result1, result2, resultp, resultcb; //Loop until readings are stable or max number of readings is reached do { oldv1=value1; oldv2=value2; wait(TIEMPO_LECTURA); digitalWrite(PIN_ALIM1, HIGH); digitalWrite(PIN_ALIM2, LOW); wait(TIEMPO_LECTURA); value1 = analogRead(PIN_LECTURA); digitalWrite(PIN_ALIM1, LOW); digitalWrite(PIN_ALIM2, HIGH); wait(TIEMPO_LECTURA); value2 = analogRead(PIN_LECTURA);; digitalWrite(PIN_ALIM1, LOW); digitalWrite(PIN_ALIM2, LOW); } while (((oldv1 != value1) && (oldv2 != value2)) || (i == MAX_REP_LECTURA)); /* 0-10 Saturated Soil. Occurs for a day or two after irrigation 10-20 Soil is adequately wet (except coarse sands which are drying out at this range) 20-60 Usual range to irrigate or water (most soils except heavy clay soils). 60-100 Usual range to irrigate heavy clay soils 100-200 Soil is becoming dangerously dry */ result1=constrain(value1/(AGUA_DIR-AIRE_DIR)*100.0, 1, 100); result2=constrain(100-(value2-AGUA_INV)/(AIRE_INV-AGUA_INV)*100.0,1,100); resultp = (result1+result2)/2.0; resultcb = resultcb + constrain(square((-2.96699 + 351.395/resultp)),0,200); //Equation fit using stat software count++; //Send the data - only if moisture changed to save battery (send anyways once every 4 readings). If moisture sent, send battery level. if ((oldresultcb!=resultcb) || (count==MAX_REPORTING_LOOPS)) { send(msgmoist.set((unsigned int)resultcb)); oldresultcb=resultcb; //Measure battery voltage and send level float v = vcc.Read_Volts(); int p = vcc.Read_Perc(VccMin, VccMax); p=constrain(p,0,100); sendBatteryLevel(p); #ifdef MY_DEBUG Serial << "Value1=" << value1 << " " << result1 << endl << "Value2=" << value2 << " " << result2 << endl << "Result = " << resultp << "% (" << resultcb << "cb)" << endl; Serial << "VCC = " << v << " Volts" << endl << "VCC% = " << p << " %" << endl; #endif } if (count==MAX_REPORTING_LOOPS) count=0; sleep(SLEEP_TIME_3h, true); } }The node uses a Mini Pro 3.3v @ 8 MHz. I'm powering it with a Li battery through a MCP1703 LDO with the 2 caps as shown in the datasheet. The radio is a RFM69HW with a 47uF cap in the power rail and a 0.1uF soldered to the power pins of the board shield. I'm using Arduino IDE v1.8.4, with boards definition v1.6.20.
Thanks in advance.
Thanks in advance.
@manutremo you're using a i2c eeprom? Please re-run a FOTA update with
#define MY_DEBUG_VERBOSE_OTA_UPDATEenabled and post the full log. Could be an issue with the i2c eeprom...let's see
@tekka See below the log of a new occurence of the same issue with UPDATE SKIPPED. This time I enabled verbose debug for OTA . This time I was testing with another different node with a similar hw setup - I'm also adding the sketch below although I think that from an OTA standpoint it's the same. First the node says UPDATE (line 2600), then UPDATE SKIPPED (line 2654), then goes to sleep, and after wake-up the update starts. This time the firmware was a new one, so the update is correct - which makes me think that maybe it's just that the UPDATE SKIPPED appears incorrectly.
18 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.0-rc.1 28 TSM:INIT 28 TSF:WUR:MS=0 32 TSM:INIT:TSP OK 34 TSM:INIT:STATID=22 36 TSF:SID:OK,ID=22 38 TSM:FPAR 38 TSM:FPAR:STATP=0 40 TSM:ID 43 TSM:ID:OK 45 TSM:UPL 53 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 71 TSF:MSG:READ,0-0-22,s=255,c=3,t=25,pt=1,l=1,sg=0:1 77 TSF:MSG:PONG RECV,HP=1 79 TSM:UPL:OK 81 TSM:READY:ID=22,PAR=0,DIS=1 307 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010001000005990D0300 370 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 382 TSF:MSG:READ,0-0-22,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 397 TSF:MSG:SEND,22-22-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-rc.1 464 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0 491 TSF:MSG:READ,0-0-22,s=255,c=3,t=6,pt=0,l=1,sg=0:M 507 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=11,pt=0,l=23,sg=0,ft=0,st=OK:Sensor de fugas de agua 575 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1 638 TSF:MSG:SEND,22-22-0-0,s=1,c=0,t=32,pt=0,l=13,sg=0,ft=0,st=OK:Fugas de agua 647 MCO:REG:REQ 700 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2 952 TSF:MSG:READ,0-0-22,s=255,c=3,t=27,pt=1,l=1,sg=0:1 958 MCO:PIM:NODE REG=1 960 MCO:BGN:STP 962 MCO:BGN:INIT OK,TSP=1 2459 !TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:0 2498 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:36 No detection 2506 MCO:SLP:MS=30000,SMS=1,I1=1,M1=1,I2=255,M2=255 2560 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500 2592 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3 2600 OTA:FWP:UPDATE 2603 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF 2615 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04 2648 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3 2654 OTA:FWP:UPDATE SKIPPED 3069 TSF:TDI:TSL 3072 MCO:SLP:WUP=-1 3074 TSF:TRI:TSB 3082 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000 3104 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF 3143 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04 3178 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FF04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3188 OTA:FWP:RECV B=04FF 3198 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE 3211 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FE04 3254 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FE04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3264 OTA:FWP:RECV B=04FE 3270 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FD 3282 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FD04 3315 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FD042E310000FFFFFFFFFFFFFFFFFFFFFFFF 3328 OTA:FWP:RECV B=04FD 3334 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FC 3346 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FC04 3379 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FC0441434B003F002100322E322E302D7263 3389 OTA:FWP:RECV B=04FC 3397 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FB 3407 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FB04 3446 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FB04696F6E003C4E4F4E43453E004F4B004E 3457 OTA:FWP:RECV B=04FB 3467 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FA 3477 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FA04 3514 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FA04746564000D0A004E6F20646574656374 3524 OTA:FWP:RECV B=04FA 3530 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F9 3543 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F904 3579 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F9046167756100466C6F6F64206465746563 3592 OTA:FWP:RECV B=04F9 3598 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F8 3608 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F804 3651 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F804756100312E3100467567617320646520 3661 OTA:FWP:RECV B=04F8 3667 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F7 3680 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F704 3715 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F70472206465206675676173206465206167 3727 OTA:FWP:RECV B=04F7#define MY_RADIO_RFM69 #define MY_RFM69_NEW_DRIVER // ATC on RFM69 works only with the new driver (not compatible with old=default driver) #define MY_IS_RFM69HW #define MY_RFM69_MAX_POWER_LEVEL_DBM 13 #define MY_RFM69_FREQUENCY RFM69_868MHZ #define MY_DEBUG_VERBOSE_OTA_UPDATE #define MY_PARENT_NODE_ID 0 #define MY_PARENT_NODE_IS_STATIC #define MY_TRANSPORT_MAX_TX_FAILURES (3u) #define MY_NODE_ID 22 #define MY_OTA_FIRMWARE_FEATURE #define MY_OTA_USE_I2C_EEPROM #define MY_DEBUG #include <MySensors.h> #include <SPI.h> #include <Vcc.h> #include <Streaming.h> #define SLEEP_TIME_5min 300000 #define SLEEP_TIME_10min 600000 #define SLEEP_TIME_15min 900000 #define SLEEP_TIME_1h 3600000 #define SLEEP_TIME_2h 7200000 #define SLEEP_TIME_3h 10800000 #define VERSION "1.1" #define PIN_INTERRUPT 3 // Battery calibration (Li-ion) const float VccMin = 3.0; // Minimum expected Vcc level, in Volts. const float VccMax = 4.2; // Maximum expected Vcc level, in Volts. const float VccCorrection = 3.82/3.74; // Measured Vcc by multimeter divided by reported Vcc #define CHILD_FLOOD_ID 1 MyMessage msgflood(CHILD_FLOOD_ID, V_TRIPPED); Vcc vcc(VccCorrection); bool res; int interrupt=digitalPinToInterrupt(PIN_INTERRUPT), oldbat=101; // Set so that it will be sent always on the first run void setup(){ Serial.begin(115200); pinMode(PIN_INTERRUPT, INPUT); } void presentation(){ sendSketchInfo("Sensor de fugas de agua", VERSION); present(CHILD_FLOOD_ID, S_WATER_LEAK, "Fugas de agua"); } void loop() { if (!isFirmwareUpdateOngoing()) { // Contact status is always sent as a safety measure to allow checking if the sensor is working // We start with a short delay for debouncing the contact (otherwise the reading from the pin might be incorrect after exiting from the sleep() delay(150); res = (digitalRead(PIN_INTERRUPT) == LOW); send(msgflood.set(res)); //Measure battery voltage and send level if it has changed int p = vcc.Read_Perc(VccMin, VccMax); p=constrain(p,0,100); if (p != oldbat) { oldbat = p; sendBatteryLevel(p); } #ifdef MY_DEBUG if (res) Serial.println("Flood detected"); else Serial.println("No detection"); #endif sleep(interrupt, CHANGE, 20000, true);//SLEEP_TIME_3h, true); } } -
By the way - following the above, I made a small modification to the sketch, compiled, etc. Myscontroller detected the new fw corectly and the update run fine at the next wake-up, with no SKIPPED messages.
20987 MCO:SLP:MS=20000,SMS=1,I1=1,M1=1,I2=255,M2=255 21041 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500 21073 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:010001000005990D 21082 OTA:FWP:UPDATE 21084 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF 21096 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04 21135 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FF04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 21145 OTA:FWP:RECV B=04FF 21155 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FEHowever I then modified the sketch again, uploaded it to Myscontroller, etc, but this time I reset the node. The log showed the UPDATE SKIPPED message again before starting the update.
18 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.0-rc.1 28 TSM:INIT 28 TSF:WUR:MS=0 32 TSM:INIT:TSP OK 34 TSM:INIT:STATID=22 36 TSF:SID:OK,ID=22 38 TSM:FPAR 38 TSM:FPAR:STATP=0 40 TSM:ID 43 TSM:ID:OK 45 TSM:UPL 53 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 71 TSF:MSG:READ,0-0-22,s=255,c=3,t=25,pt=1,l=1,sg=0:1 77 TSF:MSG:PONG RECV,HP=1 79 TSM:UPL:OK 81 TSM:READY:ID=22,PAR=0,DIS=1 94 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010001000005990D0300 161 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 172 TSF:MSG:READ,0-0-22,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 188 TSF:MSG:SEND,22-22-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-rc.1 253 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0 282 TSF:MSG:READ,0-0-22,s=255,c=3,t=6,pt=0,l=1,sg=0:M 299 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=11,pt=0,l=23,sg=0,ft=0,st=OK:Sensor de fugas de agua 364 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1 428 TSF:MSG:SEND,22-22-0-0,s=1,c=0,t=32,pt=0,l=13,sg=0,ft=0,st=OK:Fugas de agua 436 MCO:REG:REQ 489 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2 505 TSF:MSG:READ,0-0-22,s=255,c=3,t=27,pt=1,l=1,sg=0:1 512 MCO:PIM:NODE REG=1 514 MCO:BGN:STP 516 MCO:BGN:INIT OK,TSP=1 675 TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0 739 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:32 No detection 745 MCO:SLP:MS=30000,SMS=1,I1=1,M1=1,I2=255,M2=255 802 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500 831 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3 839 OTA:FWP:UPDATE 841 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF 854 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04 882 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3 888 OTA:FWP:UPDATE SKIPPED 1220 TSF:MSG:READ,0-0-22,s=255,c=3,t=6,pt=0,l=1,sg=0:M 1288 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FF04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1298 OTA:FWP:RECV B=04FF 1308 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE 1320 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FE04 1329 TSF:TDI:TSL 1331 MCO:SLP:WUP=-1 1333 TSF:TRI:TSB 1343 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000 1810 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE 1820 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FE04 1859 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FE04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1869 OTA:FWP:RECV B=04FE 1878 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FD 1888 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FD04 1925 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FD042E310000FFFFFFFFFFFFFFFFFFFFFFFF 1935 OTA:FWP:RECV B=04FD 1943 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FC 1953 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FC04 1992 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FC0441434B003F002100322E322E302D7263 2002 OTA:FWP:RECV B=04FC 2009 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FB 2021 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FB04 2056 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FB04696F6E003C4E4F4E43453E004F4B004E 2066 OTA:FWP:RECV B=04FB 2076 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FA 2086 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FA04 2123 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FA04746564000D0A004E6F20646574656374 2134 OTA:FWP:RECV B=04FA 2140 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F9 2152 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F904 2187 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F9046167756100466C6F6F64206465746563 2197 OTA:FWP:RECV B=04F9 2203 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F8So it looks this happens only if right after a node reset. I hope this gives a hint.
As a side note - I also find interesting that the number of update blocks sent before the node goes to sleep changes between test runs.
@tekka Tested the new library and both issues seem to be gone now, great job ! :clap:
I have one more question though :)
During testing I treid to put things difficult for my radios and move them until reception started to be bad. At some point the FOTA process gave up with a FW UPD FAIL message (line 41146 in attached log). So the node gave up and went to sleep. I was expecting it to try again after wake-up, but it didn't (see lines after 43589).
36734 !RFM69:SWR:NACK 36737 RFM69:PTX:NO ADJ 36771 RFM69:SWR:SEND,TO=0,RETRY=5 36966 RFM69:SWR:ACK,FROM=0,SEQ=119,RSSI=-55 36972 RFM69:ATC:ADJ TXL,cR=-55,tR=-80,TXL=12 36976 RFM69:PTX:LEVEL=12 dBm 36978 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005 36988 OTA:FRQ:FW REQ,T=0001,V=0001,B=0520 36993 RFM69:SWR:SEND,TO=0,RETRY=0 37203 !RFM69:SWR:NACK 37206 RFM69:PTX:LEVEL=13 dBm 37216 RFM69:SWR:SEND,TO=0,RETRY=1 37423 !RFM69:SWR:NACK 37425 RFM69:PTX:NO ADJ 37459 RFM69:SWR:SEND,TO=0,RETRY=2 37666 !RFM69:SWR:NACK 37668 RFM69:PTX:NO ADJ 37679 RFM69:SWR:SEND,TO=0,RETRY=3 37885 !RFM69:SWR:NACK 37888 RFM69:PTX:NO ADJ 37922 RFM69:SWR:SEND,TO=0,RETRY=4 38129 !RFM69:SWR:NACK 38131 RFM69:PTX:NO ADJ 38174 RFM69:SWR:SEND,TO=0,RETRY=5 38313 RFM69:SWR:ACK,FROM=0,SEQ=120,RSSI=-56 38318 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=12 38322 RFM69:PTX:LEVEL=12 dBm 38326 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005 38334 OTA:FRQ:FW REQ,T=0001,V=0001,B=0520 38338 RFM69:SWR:SEND,TO=0,RETRY=0 38547 !RFM69:SWR:NACK 38549 RFM69:PTX:LEVEL=13 dBm 38559 RFM69:SWR:SEND,TO=0,RETRY=1 38768 !RFM69:SWR:NACK 38770 RFM69:PTX:NO ADJ 38805 RFM69:SWR:SEND,TO=0,RETRY=2 39012 !RFM69:SWR:NACK 39014 RFM69:PTX:NO ADJ 39024 RFM69:SWR:SEND,TO=0,RETRY=3 39231 !RFM69:SWR:NACK 39233 RFM69:PTX:NO ADJ 39268 RFM69:SWR:SEND,TO=0,RETRY=4 39475 !RFM69:SWR:NACK 39477 RFM69:PTX:NO ADJ 39520 RFM69:SWR:SEND,TO=0,RETRY=5 39702 RFM69:SWR:ACK,FROM=0,SEQ=121,RSSI=-54 39706 RFM69:ATC:ADJ TXL,cR=-54,tR=-80,TXL=12 39712 RFM69:PTX:LEVEL=12 dBm 39714 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005 39723 OTA:FRQ:FW REQ,T=0001,V=0001,B=0520 39729 RFM69:SWR:SEND,TO=0,RETRY=0 39938 !RFM69:SWR:NACK 39940 RFM69:PTX:LEVEL=13 dBm 39983 RFM69:SWR:SEND,TO=0,RETRY=1 40192 !RFM69:SWR:NACK 40194 RFM69:PTX:NO ADJ 40228 RFM69:SWR:SEND,TO=0,RETRY=2 40435 !RFM69:SWR:NACK 40437 RFM69:PTX:NO ADJ 40480 RFM69:SWR:SEND,TO=0,RETRY=3 40687 !RFM69:SWR:NACK 40689 RFM69:PTX:NO ADJ 40724 RFM69:SWR:SEND,TO=0,RETRY=4 40931 !RFM69:SWR:NACK 40933 RFM69:PTX:NO ADJ 40943 RFM69:SWR:SEND,TO=0,RETRY=5 41125 RFM69:SWR:ACK,FROM=0,SEQ=122,RSSI=-54 41129 RFM69:ATC:ADJ TXL,cR=-54,tR=-80,TXL=12 41134 RFM69:PTX:LEVEL=12 dBm 41138 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005 41146 !OTA:FRQ:FW UPD FAIL 41299 RFM69:SWR:SEND,TO=0,RETRY=0 41506 !RFM69:SWR:NACK 41508 RFM69:PTX:LEVEL=13 dBm 41519 RFM69:SWR:SEND,TO=0,RETRY=1 41725 !RFM69:SWR:NACK 41728 RFM69:PTX:NO ADJ 41762 RFM69:SWR:SEND,TO=0,RETRY=2 41969 !RFM69:SWR:NACK 41971 RFM69:PTX:NO ADJ 42014 RFM69:SWR:SEND,TO=0,RETRY=3 42221 !RFM69:SWR:NACK 42223 RFM69:PTX:NO ADJ 42258 RFM69:SWR:SEND,TO=0,RETRY=4 42465 !RFM69:SWR:NACK 42467 RFM69:PTX:NO ADJ 42477 RFM69:SWR:SEND,TO=0,RETRY=5 42684 !RFM69:SWR:NACK 42686 RFM69:PTX:NO ADJ 42721 !TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:0 42729 RFM69:SWR:SEND,TO=0,RETRY=0 42950 !RFM69:SWR:NACK 42952 RFM69:PTX:NO ADJ 42995 RFM69:SWR:SEND,TO=0,RETRY=1 43005 RFM69:SWR:ACK,FROM=0,SEQ=124,RSSI=-55 43010 RFM69:ATC:ADJ TXL,cR=-55,tR=-80,TXL=12 43014 RFM69:PTX:LEVEL=12 dBm 43018 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:20 No detection 43026 MCO:SLP:MS=30000,SMS=1,I1=1,M1=1,I2=255,M2=255 43030 RFM69:SWR:SEND,TO=0,RETRY=0 43065 RFM69:SWR:ACK,FROM=0,SEQ=125,RSSI=-56 43069 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=11 43075 RFM69:PTX:LEVEL=11 dBm 43077 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500 43585 TSF:TDI:TSL 43587 RFM69:RSL 43589 MCO:SLP:WUP=-1 43591 TSF:TRI:TSB 43593 RFM69:RSB 43595 RFM69:SWR:SEND,TO=0,RETRY=0 43606 RFM69:SWR:ACK,FROM=0,SEQ=126,RSSI=-56 43610 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=10 43616 RFM69:PTX:LEVEL=10 dBm 43618 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000 43778 RFM69:SWR:SEND,TO=0,RETRY=0 43788 RFM69:SWR:ACK,FROM=0,SEQ=127,RSSI=-59 43792 RFM69:ATC:ADJ TXL,cR=-59,tR=-80,TXL=9 43796 RFM69:PTX:LEVEL=9 dBmSo when this occurs the only way I can think of to force another update would be update the sketch, refresh the repo in MysController and assign it to the node again. Therefore I wonder if this is intended behaviour and if so, if there is some other way to force an update after a failed one.
