  3. OTA FW update using I2C EEPROM
27 Posts 6 Posters 10.7k Views 7 Watching
  • kisse66K
    kisse66K
    kisse66
    I have boards with I2C EEPROM (32 or 64kB) instead of a SPI flash already supported via dualoptiboot. Been looking a bit but haven't found any discussion about such so far? Sorry if I have missed one.
    I have both nRF24 and RFM69 radios in use and going to mysensors from my earlier proprietary system.
    Anyway I already started implementing changes to dualoptiboot and mysensors OTA code. IF someone knows of existing work please do point me there so I can stop working on it. My idea is to make a simple EEPROM (24(L)Cxxx) driver that looks like the SPI flash driver to make the changes to mysensors minimal. Seems so far only a few lines are needed in addition to the new driver. Bootloader is a bit more work. Any comments about this approach (in case it starts working well and someone else likes to use it) ?
    • scalzS
      scalzS
      @kisse66
      cool.
      so far only spi flash memory are supported. so, no i2c existing work for the moment i think ;)
      • kisse66K
        kisse66K
        kisse66
        It seems to work now. Boot loader needs some more work, but MySensors part should be usable. If someone likes to have a look you can find it at http://github.com/kisse66/MySensors fork. By default it still uses SPI flash and works just like the original. To use I2C EEPROM uncomment (MyConfig.h) or define MY_OTA_USE_I2C_EEPROM in your sketch. You'll need also MY_OTA_FIRMWARE_FEATURE of course.
        My code uses Wire library for I2C (new driver) and defaults to address 0x50 (real I2C address 0xA0) that most EEPROMs use I think. EEPROM has to use 16-bit addresses, 24(L)C256 or 512 should work.
        Only tested with MYScontroller, pro mini 8MHz with nRF24 and 24LC512 EEPROM on AVR HW I2C.
        Do note that I'm still working on the bootloader part which you'll need to make this actually work. I have a "seems like working" hack, but it needs some more work. Approach is to use DualOptiboot code and add option there for alternate I2C. I'll publish it when it's getting a bit better.
          melwinek
          Please correct the warnings at https://github.com/mysensors/MySensors/pull/834
          I really want to see support for eeprom in official mysensors.
            melwinek
            kisse66: i have error while writing bootloader:
            avrdude: ERROR: address 0x8010 out of range at line 65 of ...optiboot_atmega328_e8.hex
            I compile it with Arduino-1.0.x
            Can you share a compiled file?
            • kisse66K
              kisse66K
              kisse66
              The bootloader at github is not verified yet, it's an updated version from pieces I used to test. That's why I haven't mentioned it yet here. Looks like linking adresses are wrong. Will fix but can't promise when. Might have time next week.
              If you need it now, try lowering the --section-start=.text=0x7c00 at Makefile line 618 to 0x7a00 (or down to 0x7800). The 7c00 only allow for 1kB bootloader. You also need to have fuses set for max boot block. Luckily they are so as default in many pro mini's at least.
              I'll see if I still have the binary I used. It's for 8MHz pro mini.
              I'm interested in hearing if it works on your case as well. I'll be doing some more testing also and update github accordingly.
                melwinek
                I changed to 0x7a00
                FUSE: L:FF H:DA E:05 this is 1024 words bootloader.
                And beautifully everything works.
                With little attention, I do not know why MYSCOntroller has been sending firmware several times.
                  melwinek
                  When eeprom ota will be attached to official development branch ?
                    melwinek
                    kisse66: Can you refresh your sources? Official Mysensors has now added a very cool option: MY_SIGNING_SIMPLE_PASSWD.
                    What determines the moment to add your changes to the official distribution?
                    • kisse66K
                      kisse66K
                      kisse66
                      It's up to the maintainers to decide if it's good enough implementation and then when to merge the PR. There has been no comments yet.
                      I don't like to update my version now as it's pending.
                      alexsh1A 1 Reply Last reply
                        melwinek
                        I wish it was so long. You did a great job.
                        • kisse66K kisse66
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @kisse66 Excellent work - I have a few nodes with i2c eeprom waiting for MySensors to support it.
                          • Nca78N
                            Nca78N
                            Wow, great job, thank you @kisse66 !
                            Any limit in the size of the memory chips ? Like is it a problem if I use a 256/512k version ?
                            kisse66K 1 Reply Last reply
                            • Nca78N Nca78
                              kisse66K
                              kisse66K
                              kisse66
                              @Nca78
                              Good question - Have only tested 256 and 512kbit (32/64kB), nothing bigger than 64kB. Unfortunately I2C protocol is slightly different between different EEPROMs, so code does have limitations. There's two sides of it. MySensors side now uses extEEPROM underneath, so what it supports should work. Address type is 32-bit, so the interface supports >64kB. Haven't checked the code, but at least it defines 2Mbit type (see extEEPROM.h). My patch now assumes EEPROM is 32kB (64 fine) as it's enough for mega328.
                              Bigger issue is the bootloader, which has more assumptions. Likely not working as is for anything bigger than 64kB. Would be interesting to hear if someone can try, I don't have larger EEPROMs.
                                melwinek
                                kisse66: Arduino with this bootloader without connected EEPROM hang in bootloader with DEBUG: SSF2
                                • M melwinek
                                  kisse66K
                                  kisse66K
                                  kisse66
                                  @melwinek
                                  hmm, interesting. There should be a timeout, but I need to re-check. Are the I2C pins floating or are the pullup resistors still there?
                                    melwinek
                                    kisse66: Bootloader hang only when i disconnect pullup.
                                    1. Pullup and EEPROM - OK
                                    2. Pullup without EEPROM - OK
                                    3. Only EEPROM - Hang
                                    4. Free I2C pins - Hang
                                    • M melwinek
                                      kisse66K
                                      kisse66K
                                      kisse66
                                      @melwinek
                                      Thanks, good info. Middle of vacation activities here but I looked the code a bit more. It does have the retry limit, but also forever loops with certain I2C events. Can be fixed quite easily I believe. I need to setup test bed for it to see myself.
                                      Not an urgent thing I believe?
                                      M 1 Reply Last reply
                                      • kisse66K kisse66
                                        @melwinek
                                        melwinek
                                        @kisse66
                                        This is not urgent.
                                        Nice holiday :)
                                          manutremo
                                          Hi, I just wanted to report that I was able to compile and use the dualoptiboot bootloader with I2C support on a Mini Pro 8MHz board with an I2C AT24C256 breakout board and a RFM69HW radio. With this setup I've been able to to update several sketches via OTA using MysController.
                                          I took me some time to understand the workflow and necessary tools since I wasn't able to find a complete, up to date tutorial. Specifically, it took me some time to find out that the compilation of the bootloader with the Arduino IDE requires downgrading to version 1.0.6.
                                          I also run into some issues with the Arduino IDE not being able to find the extEEPROM.h file (even though it was indeed present at the correct location), and having to copy the i2c.h file to the optiboot folder in addition to the optiboot.c and the Makefile files.
                                          Also, I finally managed to flash it using avrdudess since I was getting errors when trying to use the IDE.
                                          So even though the author above that this bootloader isn't yet finished, it's working properly. Granted that I haven't tested it thoroughly under all scenarios, but it certainly looks promising. Can't wait to see it fully implemented in the mysensors framework. I'll continue reporting any additional findings.
                                          Many thanks!
