  3. NodeMCU PIN reference
21 Posts 3 Posters 6.5k Views 4 Watching
  • S Offline
    Strixx
    Hello!
    I am struggling with how I should refer to the different GPIOs vs PINs in my code. I have been looking at the library source code and different example code, as well as the complete pin mappings of the NodeMCU, and i find disparities.
    For example in the code for the ESP8266 WiFi Gateway (https://github.com/mysensors/MySensors/blob/master/examples/GatewayESP8266/GatewayESP8266.ino) all comments about which GPIO to connect the radio correlates correct to the PIN layout.
    Then it says to connect the inclusion button to GPIO5 which is PIN D1. Later in the code it defines inclusion button to PIN 3, which is GPIO0.
    To confuse it even more, the same example code later uses PIN 16 which is the internal LED on the board...
    And the next confusing thing is how I refer to the analog PIN on the board? On the board there is only one analoug PIN, named A0. How do I put that one in the code for soft signing? I have seen example of both "0" and "A0". Which is the correct?
    Is there any where I could find a complete reference for the PIN vs GPIO for the ESP8266 in the MySensors library?
    mfalkviddM AffordableTechA 2 Replies Last reply
    • S Strixx
      Hello!
      @Strixx the MySensors library does not have a pin reference.
      The pins are defined by the board definitions.
      See here for the NodeMCU Dn pins and BUILTIN_LED
      See here for the A0 pin.
      These definitions are just aliases. So A0 is an alias for PIN_A0 which is an alias for 17. You can use any alias you like, they will all result in the same code. I like the PIN_A0 notation because I think it is very clear that you mean the pin called A0 and that makes the code easier to read. But you can write 17 in your code and the code will work the same way as with PIN_A0.
      For details on how the esp8266 works, I recommend Kolban's book.
      S mfalkviddM 2 Replies Last reply
        Strixx
        @mfalkvidd Thank you!
        Then I had it all figured out any way and the code for the ESP8266 WiFi Gateway (https://github.com/mysensors/MySensors/blob/master/examples/GatewayESP8266/GatewayESP8266.ino) is not correct when it comes to the inclusion button. Either the comments on which GPIO the button should be connected to or the PIN assignment should be changed.
        Once more: Thank you for your help!
        • S Strixx
          @Strixx thanks. I have created https://github.com/mysensors/MySensors/issues/993 to get it fixed.
          • S Strixx
            @Strixx dit you get the inclusion button working? If so, what pin did you use?
            S 1 Reply Last reply
              Strixx
              @mfalkvidd I have not started building it yet. Hopefully I will have some spare time tomorrow, otherwise it will be in a week or two. I will get back as soon as I have got it all up and running (with external radio traffic LED as well).
              • S Strixx
                @Strixx great, thanks! It seems like GPIO5/D1 is better suitable than GPIO3/D9 because GPIO3/D9 is connected to serial RX so connecting a button might interfere with flashing.
                • mfalkviddM Offline
                  I think https://github.com/mfalkvidd/MySensors/commit/8a14819a72f84df1dc27ebd13af1bace2c2289f5 will fix the problem, but I can't verify since I don't have a controller that uses inclusion mode. Will await feedback before i create a pull request.
                  • S Offline
                    Strixx
                    Back to testing the inclusion button, now that the gateway is up and running.
                    I am trying to see in serial monitor, MYS Controller and Domoticz to see if it works, but nothing.
                    What would be the easiest way to see if the function actually is working?
                    • S Strixx
                      @strixx to my knowledge, Domoticz does not support inclusion mode. I have never used inclusion mode so I can't help much unfortunately.
                      • S Offline
                        Strixx
                        I believed that adding this button to the gateway would set Domoticz to accept new hardware, when the button was pushed. But now that I have investigated some more it seems that this button is only used in Vera? Maybe there is a way to add this function in Domoticz, but that's for later.
                        Anyway; since I started this "issue" I want to finish it, even if I have no use of the button.
                        Is there any way to see if the gateway sends anything to the controller when I push the button?
                        I cant see anything on the serial output.
                        • S Strixx
                          @strixx I didn't know, so I checked with the team and this is the info I got:
                          The gateway should send a start inclusion internal command when the button is pressed… and after X seconds in should send a inclusion end command.
                          So testing it should be fairly straightforward.
                            I tried to verify this, but had no success :(
                            https://github.com/mysensors/MySensors/issues/993#issuecomment-366526857
                              Verified now (thanks to @hek) and merged. The fix is available in the development branch and will be included in the next release.
                              • S Offline
                                Strixx
                                @mfalkvidd That is perfect.
                                I have been buisy with another projects. But I did quite a lot of trials, and could not get it to work for me no mater what i tried.
                                But now I see what was the problem. I was assigning the pin with only a digit. IE 1, 3, 4. But with D1, D3 and D4 it works. I was under the impression that 1 = D1, but it's not.
                                Now that I got it working I have noticed a strange thing. When using MYSController for debugging I can only sometimes se the inclusion message sometimes in the "log". But always when logging with netcat. I have not been able to see any pattern for when MYSController is not showing the message.
                                May I suggest another PIN for the inclusion button?
                                As I understand it. With the NodeMCU 0.9 that I'm using there is only a limited number of pins left to use after connecting the radio. D0, D1, D3, D4, D9 and D10. And some of them have special purpose. And if you want to use external leds for rx/tx/err (instead of the internal led as used by the example) there are (as I understand it) only three pins left, and that is D1, D9 and D10. But D3 and D4 should be safe to use for inclusion button, since they only have special use at boot. So as long as you don't press the inclution button at startup of the gateway they are safe to use as input.
                                My suggestion, which I have been trying with out problems the last couple of hours, is that:
                                #define MY_INCLUSION_MODE_BUTTON_PIN  D4
                                #define MY_DEFAULT_ERR_LED_PIN D10  // Error led pin (Red)
                                #define MY_DEFAULT_RX_LED_PIN  D9  // Receive led pin (Yellow)
                                #define MY_DEFAULT_TX_LED_PIN  D1  // Transmit led pin (Green)
                                  @Strixx I guess you didn't see this reference earlier?
                                  It shows that numbers the Dn aliases are mapped to. :-)
                                  As for changing the example to D4: if you are sure it doesn't interfere with boot go ahead and create a pull request.
                                    Strixx
                                    @mfalkvidd said in NodeMCU PIN reference:
                                    I shows that numbers the Dn aliases are mapped to.
                                    Yes I did. I don't know why I have been trying with only digits without the D in front. I have been reading up on this project a lot, and I think I have seen somewhere that both Dx and x have mappings to GPIO. But maybe I have been reading in some old source or maybe that is only for Arduino. Or maybe I am only dreaming. But I do feel a bit stupid now... :-/
                                    (But in my defense, in the example code for the gateway the LED pins are only referenced by a single digit)
                                    As for the pull request. I consider myself to much of a newbee to be doing that. Even suggesting to the professional here in the forum is a bit scary.. :-)
                                    • S Strixx
                                      @strixx I feel stupid quite a lot. Learning (and especially re-learning) can be painful :) But rewarding in the end.
                                      Pull requests aren't for everyone. It is a great way to get things done though. Without a pull request, things just end up on someone's todo list, and for most open source projects those todo lists are pretty long.
                                      Would you mind creating an issue? https://github.com/mysensors/MySensors/issues
                                      Just describe the change, why you think the change is good and why you think it won't break anything. With an issue created, your suggestion will at least be added to the todo list. Here in the forum it might get lost.
                                      • S Offline
                                        Strixx
                                        Ok. Will do some more testing to be sure it works as expected, and then create an issue.
                                        • S Strixx
                                          @strixx Kolban's book on esp8266, says the following on using D4
                                          Used for UART1 output and, as such, is likely to be used
                                          during development time for debugging. Written to when
                                          flashed with new firmware.
                                          I think most MySensors users use the usb port for debugging so using D4 for inclusion pin should be safe, as long as nothing tries to print to UART1. I don't know if anything uses UART1.
