  3. Combining relay and temperature sketch
76 Posts 9 Posters 24.1k Views 12 Watching
  • N Newzwaver
    Did you get this working and if so can you share?
    B
    B
    bluezr1
    @newzwaver I'm curious aswell, been pounding my head all night trying to get a temperature and relay into one sketch.
    • N
      N
      Newzwaver
      HI
      I did get it to work and will post the sketch later today after work. I have it working on the ESP8266 and Arduino.
      • N
        N
        Newzwaver
        wrote on last edited by gohan
        #42
        I figured why wait, this has the temp, hum and 2 relays working not problem. One relay controls my fan for my AV and the other controls my doorbell for my HTD Lync system.
         * Version 1.0: Henrik EKblad
         * sensor using a DHT11/DHT-22.
        // Enable debug prints
        #define MY_NODE_ID 29
        //#define MY_RS485
        #define MY_REPEATER_FEATURE
        #define DHT_DATA_PIN 3
        #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define RELAY_2  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define NUMBER_OF_RELAYS 2 // Total number of attached relays
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 60000;
        #define CHILD_ID_HUM 28
        #define CHILD_ID_TEMP 30
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        DHT dht;
        void before()
            pinMode(pin, OUTPUT);
          sendSketchInfo("AVCABRelayTempAndHumidity", "1.1");
          present(CHILD_ID_HUM, S_HUM);
          dht.readSensor(true);
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
          if (message.type==V_STATUS) {
            // Change relay state
            // Store state in eeprom
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
            nNoUpdatesHum++;
          sleep(UPDATE_INTERVAL);
        rejoe2R 1 Reply Last reply
        • N Newzwaver
          //#define MY_RS485
          float lastTemp;
          float lastHum;
          bool metric = true;
          DHT dht;
          void before()
              if (!metric) {
              nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
              nNoUpdatesTemp++;
              lastHum = humidity;
              nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
              nNoUpdatesHum++;
          rejoe2R
          rejoe2R
          rejoe2
          @newzwaver your code is pretty hard to read due to not beeing entirely formatted as code.
          Nevertheless there seems not to exist any loop() section and the node is put to sleep after having received anything for a certain periode of time.
          This may work in most cases, but imo is not a "lucky code design".
          Imo better aproach:
          Use the https://www.arduino.cc/en/tutorial/BlinkWithoutDelay - principle. Additionally a wait() is used instead of sleep() for the time to fulfill measurements (DS18B20 in my case).
          If you need a working implementation of the blink-without-delay function within MySensors, see the https://www.mysensors.org/build/pulse_power example.
          At least three of my nodes (combining temperature and relays) work pretty well like that.
          B 1 Reply Last reply
          • rejoe2R rejoe2
            Imo better aproach:
            B
            B
            bluezr1
            wrote on last edited by bluezr1
            #44
            @rejoe2 said in Combining relay and temperature sketch:
            Thanks Newzwaver
            You wouldn't happen to have a sketch with the DS18B20? I have both DHTs and DS18B20s but plan on using this to turn on and off a fan to keep my AV equipment cool. So I'm not that concerned about humidity although it wouldn't be deal breaker if it did.
            • B bluezr1
              Thanks Newzwaver
              rejoe2R
              rejoe2R
              rejoe2
              @bluezr1 Sure... But imo it is easier to stick with the given examples, they may be much easier to understand than e.g. this one:grin:
              sinczeS 1 Reply Last reply
              • rejoe2R rejoe2
                sinczeS
                sinczeS
                sincze
                MySensors Evangelist
                @rejoe2 NIce example thanks.
                rejoe2R sinczeS 2 Replies Last reply
                • sinczeS sincze
                  rejoe2R
                  rejoe2R
                  rejoe2
                  @sincze Thanks too.
                  Just to mention: I don't use the internal functionality for the servo any more - this part didn't work to my personal satisfaction.
                  If you're interested: The RS485 variant in the repo is even more complex - it uses three Pins for 1wire with different timings, but may require some tweeks in the libs to compile.
                  • B
                    B
                    bluezr1
                    #48
                    Thank you so much Newzwaver. I've been trying to combine two sketches together and this is my first successful one. I may never be as good as most of the people on this forum, although I don't plan on stopping with combining more than one sensor to one node -- need to get rid of my double nodes I have in various places. :)
                    When I ran your sketch and the relays didn't show up in vera. So after I copied and pasted from the relay sketch posted by hek under void presentation, I ended up with errors. So after comparing the two (yours to hek's) I ended up with this that seems to be working.
                    As of right now I'm looking into what rejoe2 said about using wait instead of sleep, unless I'll be fine with what I have?
                    //#define MY_RS485
                    //#define MY_REPEATER_FEATURE
                    #define MY_NODE_ID 10
                    //#define RELAY1_PIN  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                    //#define RELAY2_PIN  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                    static const uint64_t UPDATE_INTERVAL = 1000;
                    float lastTemp;
                    float lastHum;
                    bool metric = true;
                    DHT dht;
                    void before()
                        for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                            digitalWrite(pin, loadState(sensor)?RELAY_OFF:RELAY_ON);
                            present(sensor, S_BINARY);
                        if (!metric) {
                        nNoUpdatesTemp = 0;
                        #ifdef MY_DEBUG
                        nNoUpdatesTemp++;
                        lastHum = humidity;
                        nNoUpdatesHum = 0;
                        #ifdef MY_DEBUG
                        nNoUpdatesHum++;
                            digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_OFF:RELAY_ON);
                    • B bluezr1
                      //#define MY_RS485
                      float lastTemp;
                      float lastHum;
                      bool metric = true;
                      DHT dht;
                      void before()
                          if (!metric) {
                          nNoUpdatesTemp = 0;
                          #ifdef MY_DEBUG
                          nNoUpdatesTemp++;
                          lastHum = humidity;
                          nNoUpdatesHum = 0;
                          #ifdef MY_DEBUG
                          nNoUpdatesHum++;
                      rejoe2R
                      rejoe2R
                      rejoe2
                      @bluezr1 Great to hear about you having first positive results.
                      Nevertheless, imo the sketch you posted is designed against some basic principles.
                      First: all main functions should be placed in the loop() section (not present in this sketch). The posted sketch does all the measurements within an exceptional routine called receive(). This should be reserved for all functionality that really is related to receive any info from controller side - obviously doing measurements does not belong to that category.
                      I also started as complete noob to coding around 30 months ago and just followed the examples (mostly from Build section), so be assured: you will also learn how to do this just by following these examples and ask yourself why things are solved the way they are.
                      If you need a good example of a combined sketch, have a look at the atmospheric pressure one (or the DHT (humidity?) sketch you have used here): They already have two children... From the BME180-Preassure you may follow the route to the BME280 examples available in the forum here or in my repo (#98, RS485).
                      Btw: In the header section of your sketch there are also two defines left not necessary (just as a info, this does not cause any trouble for the moment).
                      • sinczeS sincze
                        sinczeS
                        sinczeS
                        sincze
                        haha combining sketches... frees up some hardware ;-) for other stuff.
                        • rejoe2R rejoe2
                          B
                          B
                          bluezr1
                          @rejoe2 I listened to what you said and then went back over it, it's working much better now. What you said "why things are solved the way they are" made me stand back for a moment. I do Maintenance for a living and work on everything from HVAC, boilers, Kitchen equipment to hanging drywall. There's always one thing I always tell myself when troubleshooting something, what's the sequence of operation. Well I'm not to savvy with writing code although the same principles applies. Maybe I just needed someone to tell me that, I don't know.
                          Anyways, thank you
                          I updated the sketch I posted in my last post with the changes I made.
                          • sinczeS sincze
                            rejoe2R
                            rejoe2R
                            rejoe2
                            @sincze Does not only free HW for other stuff, but also makes things easier once they work as expected. I have to admitt this in some cases may need hard work to get to that point.
                            What's the "other stuff" showed on your picture?
                            @bluezr1 Looks like a big step ahead!
                            Imo next step in your code should be to have a look at the remarks I already posted and replace the sleep() by wait(). By now, you have a rather fast update rate of your values, this may not be necessary and also may lead to a early wear-out of your DHT (?):
                            Imo better aproach:
                            Please keep in mind changing existent posts like you did may lead to irritation wrt to the remarks in following posts. You may better show the resulting code as an update in your next answer and add a remark wrt. to enhancements in the earlier one.
                            • rejoe2R rejoe2
                              Imo better aproach:
                              B
                              B
                              bluezr1
                              @rejoe2 Just so I know that I’m not heading down the wrong path and wasting everyone’s time, I should be looking into the use of millis correct?
                              • B bluezr1
                                rejoe2R
                                rejoe2R
                                rejoe2
                                @bluezr1 Yes, millis() is the right thing to look for (or the simpleTimer2-lib, that internally does the same things). But keep in mind: sleep() and millis() don't fit well together, as after every sleep() millis() will be reset... Use wait() instead of sleep() in case you need short periods eg. between initialising and completion of measurements.
                                • B
                                  B
                                  bluezr1
                                  #55
                                  This is where I'm currently at, it seems to be working really well. Thanks rejoe2
                                  //#define MY_RS485
                                  #define MY_NODE_ID 19
                                  #define CHILD_ID_HUM 10
                                  #define CHILD_ID_TEMP 11
                                  float lastTemp;
                                  float lastHum;
                                  bool metric = true;
                                  DHT dht;
                                  void before()
                                    sendSketchInfo("TempRELAY", "1.1");
                                    wait(dht.getMinimumSamplingPeriod());
                                      if (!metric) {
                                      nNoUpdatesTemp = 0;
                                      #ifdef MY_DEBUG
                                      nNoUpdatesTemp++;
                                      lastHum = humidity;
                                      nNoUpdatesHum = 0;
                                      #ifdef MY_DEBUG
                                      nNoUpdatesHum++;
                                    wait(UPDATE_INTERVAL);
                                  • B bluezr1
                                    //#define MY_RS485
                                    float lastTemp;
                                    float lastHum;
                                    bool metric = true;
                                    DHT dht;
                                    void before()
                                        if (!metric) {
                                        nNoUpdatesTemp = 0;
                                        #ifdef MY_DEBUG
                                        nNoUpdatesTemp++;
                                        lastHum = humidity;
                                        nNoUpdatesHum = 0;
                                        #ifdef MY_DEBUG
                                        nNoUpdatesHum++;
                                    rejoe2R
                                    rejoe2R
                                    rejoe2
                                    @bluezr1 Looks already really good.
                                    Question: does the receive() work while the loop does the wait()? I'm not sure about that, because I am used to do the millis()-nonblocking-loop.
                                    • rejoe2R rejoe2
                                      B
                                      B
                                      bluezr1
                                      @rejoe2 I hope that this answers your question. I use Vera as my home controller and tried multiple times turning (sometimes randomly) on and off both relays without any misses as soon as Vera allowed me. Meaning, Vera won’t let you instantly turn a device on and then off or vise versa.
                                      Do you think I’ll be ok the way it is or should I keep working on this project?
                                      • B bluezr1
                                        rejoe2R
                                        rejoe2R
                                        rejoe2
                                        @bluezr1 As it seems to work to your satisfaction, you may leave it as is.
                                        FHEM as a controller allows direct interaction with switching devices, and it is really astonishing to hear Vera may have some restrictions wrt. that.
                                        But I didn't test your code in my setup, this is why I asked about your observations.
                                        I may be wrong, but imo, the code isn't yet perfect, so you might keep that in mind for the future in case you run into trouble. In case you need some sort of timer for other projects, you would miss the opportunity to learn how to use this...
                                        • rejoe2R rejoe2
                                          B
                                          B
                                          bluezr1
                                          #59
                                          @rejoe2 It's working
                                          Although I'm not sure if this part makes sense?
                                          unsigned long interval = 60000;
                                          unsigned long previousMillis = 0;```
                                          //#define MY_RS485
                                          #define MY_NODE_ID 20
                                          float lastTemp;
                                          float lastHum;
                                          bool metric = true;
                                          DHT dht;
                                          void before()
                                            // wait(dht.getMinimumSamplingPeriod());
                                           if ((unsigned long)(currentMillis - previousMillis) >= interval) {
                                              if (!metric) {
                                              nNoUpdatesTemp = 0;
                                              #ifdef MY_DEBUG
                                              nNoUpdatesTemp++;
                                              lastHum = humidity;
                                              nNoUpdatesHum = 0;
                                              #ifdef MY_DEBUG
                                              nNoUpdatesTemp++;
                                            previousMillis = millis();
