  3. Combining relay and temperature sketch
76 Posts 9 Posters 24.1k Views 12 Watching
  • B
    B
    bluezr1
    wrote on last edited by bluezr1
    #48
    Thank you so much Newzwaver. I've been trying to combine two sketches together and this is my first successful one. I may never be as good as most of the people on this forum, although I don't plan on stopping with combining more than one sensor to one node -- need to get rid of my double nodes I have in various places. :)
    When I ran your sketch and the relays didn't show up in vera. So after I copied and pasted from the relay sketch posted by hek under void presentation, I ended up with errors. So after comparing the two (yours to hek's) I ended up with this that seems to be working.
    As of right now I'm looking into what rejoe2 said about using wait instead of sleep, unless I'll be fine with what I have?
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    //#define MY_RS485
    //#define MY_REPEATER_FEATURE
    #define MY_NODE_ID 10
    #define DHT_DATA_PIN 3
    //#define RELAY1_PIN  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    //#define RELAY2_PIN  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 1000;
    #define CHILD_ID_HUM 28
    #define CHILD_ID_TEMP 30
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    void before()
        for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
            digitalWrite(pin, loadState(sensor)?RELAY_OFF:RELAY_ON);
      sendSketchInfo("AVCABRelayTempAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
            present(sensor, S_BINARY);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
        if (message.type==V_STATUS) {
            // Change relay state
            digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_OFF:RELAY_ON);
            // Store state in eeprom
    rejoe2R 1 Reply Last reply
    • B bluezr1
      //#define MY_RS485
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      void before()
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
      rejoe2R
      rejoe2R
      rejoe2
      @bluezr1 Great to hear about you having first positive results.
      Nevertheless, imo the sketch you posted is designed against some basic principles.
      First: all main functions should be placed in the loop() section (not present in this sketch). The posted sketch does all the measurements within an exceptional routine called receive(). This should be reserved for all functionality that really is related to receive any info from controller side - obviously doing measurements does not belong to that category.
      I also started as complete noob to coding around 30 months ago and just followed the examples (mostly from Build section), so be assured: you will also learn how to do this just by following these examples and ask yourself why things are solved the way they are.
      If you need a good example of a combined sketch, have a look at the atmospheric pressure one (or the DHT (humidity?) sketch you have used here): They already have two children... From the BME180-Preassure you may follow the route to the BME280 examples available in the forum here or in my repo (#98, RS485).
      Btw: In the header section of your sketch there are also two defines left not necessary (just as a info, this does not cause any trouble for the moment).
      B 1 Reply Last reply
      • sinczeS sincze
        @rejoe2 NIce example thanks.
        sinczeS
        sinczeS
        sincze
        MySensors Evangelist
        haha combining sketches... frees up some hardware ;-) for other stuff.
        • rejoe2R rejoe2
          B
          B
          bluezr1
          @rejoe2 I listened to what you said and then went back over it, it's working much better now. What you said "why things are solved the way they are" made me stand back for a moment. I do Maintenance for a living and work on everything from HVAC, boilers, Kitchen equipment to hanging drywall. There's always one thing I always tell myself when troubleshooting something, what's the sequence of operation. Well I'm not to savvy with writing code although the same principles applies. Maybe I just needed someone to tell me that, I don't know.
          Anyways, thank you
          I updated the sketch I posted in my last post with the changes I made.
          • sinczeS sincze
            rejoe2R
            rejoe2R
            rejoe2
            @sincze Does not only free HW for other stuff, but also makes things easier once they work as expected. I have to admitt this in some cases may need hard work to get to that point.
            What's the "other stuff" showed on your picture?
            @bluezr1 Looks like a big step ahead!
            Imo next step in your code should be to have a look at the remarks I already posted and replace the sleep() by wait(). By now, you have a rather fast update rate of your values, this may not be necessary and also may lead to a early wear-out of your DHT (?):
            @rejoe2 said in Combining relay and temperature sketch:
            Imo better aproach:
            Use the https://www.arduino.cc/en/tutorial/BlinkWithoutDelay - principle. Additionally a wait() is used instead of sleep() for the time to fulfill measurements (DS18B20 in my case).
            If you need a working implementation of the blink-without-delay function within MySensors, see the https://www.mysensors.org/build/pulse_power example.
            Please keep in mind changing existent posts like you did may lead to irritation wrt to the remarks in following posts. You may better show the resulting code as an update in your next answer and add a remark wrt. to enhancements in the earlier one.
            • rejoe2R rejoe2
              Imo better aproach:
              B
              B
              bluezr1
              @rejoe2 Just so I know that I’m not heading down the wrong path and wasting everyone’s time, I should be looking into the use of millis correct?
              • B bluezr1
                rejoe2R
                rejoe2R
                rejoe2
                @bluezr1 Yes, millis() is the right thing to look for (or the simpleTimer2-lib, that internally does the same things). But keep in mind: sleep() and millis() don't fit well together, as after every sleep() millis() will be reset... Use wait() instead of sleep() in case you need short periods eg. between initialising and completion of measurements.
                • B
                  B
                  bluezr1
                  #55
                  This is where I'm currently at, it seems to be working really well. Thanks rejoe2
                  //#define MY_RS485
                  #define MY_NODE_ID 19
                  static const uint64_t UPDATE_INTERVAL = 60000;
                  #define CHILD_ID_HUM 10
                  #define CHILD_ID_TEMP 11
                  float lastTemp;
                  float lastHum;
                  bool metric = true;
                  DHT dht;
                  void before()
                    sendSketchInfo("TempRELAY", "1.1");
                    wait(dht.getMinimumSamplingPeriod());
                      if (!metric) {
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesTemp++;
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesHum++;
                    wait(UPDATE_INTERVAL);
                  • B bluezr1
                    //#define MY_RS485
                    float lastTemp;
                    float lastHum;
                    bool metric = true;
                    DHT dht;
                    void before()
                        if (!metric) {
                        nNoUpdatesTemp = 0;
                        #ifdef MY_DEBUG
                        nNoUpdatesTemp++;
                        lastHum = humidity;
                        nNoUpdatesHum = 0;
                        #ifdef MY_DEBUG
                        nNoUpdatesHum++;
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @bluezr1 Looks already really good.
                    Question: does the receive() work while the loop does the wait()? I'm not sure about that, because I am used to do the millis()-nonblocking-loop.
                    • rejoe2R rejoe2
                      B
                      B
                      bluezr1
                      @rejoe2 I hope that this answers your question. I use Vera as my home controller and tried multiple times turning (sometimes randomly) on and off both relays without any misses as soon as Vera allowed me. Meaning, Vera won’t let you instantly turn a device on and then off or vise versa.
                      Do you think I’ll be ok the way it is or should I keep working on this project?
                      • B bluezr1
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @bluezr1 As it seems to work to your satisfaction, you may leave it as is.
                        FHEM as a controller allows direct interaction with switching devices, and it is really astonishing to hear Vera may have some restrictions wrt. that.
                        But I didn't test your code in my setup, this is why I asked about your observations.
                        I may be wrong, but imo, the code isn't yet perfect, so you might keep that in mind for the future in case you run into trouble. In case you need some sort of timer for other projects, you would miss the opportunity to learn how to use this...
                        • rejoe2R rejoe2
                          B
                          B
                          bluezr1
                          #59
                          @rejoe2 It's working
                          Although I'm not sure if this part makes sense?
                          unsigned long interval = 60000;
                          unsigned long previousMillis = 0;```
                          //#define MY_RS485
                          #define MY_NODE_ID 20
                          float lastTemp;
                          float lastHum;
                          bool metric = true;
                          DHT dht;
                          void before()
                            // wait(dht.getMinimumSamplingPeriod());
                           if ((unsigned long)(currentMillis - previousMillis) >= interval) {
                              if (!metric) {
                              nNoUpdatesTemp = 0;
                              #ifdef MY_DEBUG
                              nNoUpdatesTemp++;
                              lastHum = humidity;
                              nNoUpdatesHum = 0;
                              #ifdef MY_DEBUG
                              nNoUpdatesTemp++;
                            previousMillis = millis();
                          • B bluezr1
                            //#define MY_RS485
                            float lastTemp;
                            float lastHum;
                            bool metric = true;
                            DHT dht;
                            void before()
                                if (!metric) {
                                nNoUpdatesTemp = 0;
                                #ifdef MY_DEBUG
                                nNoUpdatesTemp++;
                                lastHum = humidity;
                                nNoUpdatesHum = 0;
                                #ifdef MY_DEBUG
                                nNoUpdatesTemp++;
                            rejoe2R
                            rejoe2R
                            rejoe2
                            @bluezr1 Looks like you did a working non-blocking loop :grin:
                            Didn't do a too close look to all things, but the only header definition that seems to be no longer necessary is the UPDATE_INTERVAL, as this variable isn't used any longer.
                            But beside that small remark: :clap:
                            • B
                              B
                              bluezr1
                              #61
                              <<edit>>It was me, my bad, it's working.
                              For some reason if I pull a wire for the relay it'll still show a change within Vera. I can turn them on and off and they'll show up as if they were turned on and off. Before if I pulled a wire to the relays vera wouldn't show any changes.
                              Thank you so much rejoe2 for not just giving me the answers but by pushing me to do it myself. You pointed me to where I needed to be and I thank you for that.
                              Now you got me wanting to learn even more. :)
                              • B
                                B
                                bluezr1
                                Wanted to post it incase someone else wants to use it.
                                //#define MY_RS485
                                //static const uint64_t UPDATE_INTERVAL = 60000;
                                float lastTemp;
                                float lastHum;
                                bool metric = true;
                                DHT dht;
                                void before()
                                  //if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod()) {
                                   // Serial.println("Warning: UPDATE_INTERVAL is smaller than supported by the sensor!");
                                    if (!metric) {
                                    nNoUpdatesTemp = 0;
                                    #ifdef MY_DEBUG
                                    nNoUpdatesTemp++;
                                    lastHum = humidity;
                                    nNoUpdatesHum = 0;
                                    #ifdef MY_DEBUG
                                    nNoUpdatesTemp++;
                                        digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                                • B bluezr1
                                  rejoe2R
                                  rejoe2R
                                  rejoe2
                                  @bluezr1 said in Combining relay and temperature sketch:
                                  Thanks also a lot for your positive feedback - seems there are more and more people interested in quick fixes, but imo, it's by far better to "learn how to fish".
                                  For the next steps, I'd recommend to do some more "combinded sketching", based on the existing build examples - but you'll find that easy once you did the next two of them :grin:
                                  One more interesting thing may be working with interrups in non-blocking sketches - please mind the needed type of variable definition to avoid irritating effects ;-)
                                  Then you might run into trouble as combining things needs more PINs - then you are forced to have a look on the next level of abstraction: array functions ;-) . For a start, you may analyse the multi-button-relay-sketch somwhere around here in the forum.
                                  Then you are at least on my level of knowledge within one week :grin:
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    Hi
                                    I need help... I want use sketch for 2 relay and sensor temp Dallas SD18b20.
                                    I have working sketch for 2xrelay and put to it sketch from mysensors
                                    https://www.mysensors.org/build/temp
                                    for Dallas but it not working. Not showing temp from Dallas. In DOmotcz on Gateway show only Binary from relay. Not Show Temp.
                                       DESCRIPTION
                                       Sketch for 2x relay with buttons monostable. After back power all relays set OFF and send correct status OFF to controller.
                                    #define MY_RADIO_RFM69
                                    #define MY_RFM69_FREQUENCY RF69_868MHZ
                                    #define MY_IS_RFM69HW
                                    // Node id defaults to AUTO (tries to fetch id from controller)
                                    #define MY_NODE_ID AUTO
                                    #include <OneWire.h>
                                    // Define Relays
                                    // Define Sensor ID's
                                    #define SSR_A_ID 1   // Id of the sensor child
                                    #define SSR_B_ID 2   // Id of the sensor child
                                    // Define buttons and relays
                                    const int buttonPinA = 3;
                                    const int buttonPinB = 4;
                                    const int relayPinA = 5;
                                    const int relayPinB = 6;
                                    // Define Variables
                                    int oldValueA = 0;
                                    int oldValueB = 0;
                                    bool stateA = false;
                                    bool stateB = false;
                                    int trigger = 0;
                                    // Define Sensors Temperature
                                    int numSensors=0;
                                    bool receivedConfig = false;
                                    bool metric = true;
                                    Bounce debouncerA = Bounce();
                                    Bounce debouncerB = Bounce();
                                    MyMessage msgA(SSR_A_ID, V_STATUS);
                                    MyMessage msgB(SSR_B_ID, V_STATUS);
                                    MyMessage msg(0,V_TEMP);
                                    void before()
                                      sensors.begin();
                                      pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
                                      pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
                                      // After setting up the buttons, setup debouncer
                                      debouncerA.attach(buttonPinA);
                                      debouncerA.interval(5);
                                      debouncerB.attach(buttonPinB);
                                      debouncerB.interval(5);
                                      digitalWrite(relayPinA, RELAY_OFF);
                                      digitalWrite(relayPinB, RELAY_OFF);
                                      pinMode(relayPinA, OUTPUT);
                                      pinMode(relayPinB, OUTPUT);
                                    void presentation()  {
                                      sendSketchInfo("2xRelay monostable + temp. DS18b20", "2.1.1");
                                      present(SSR_A_ID, S_LIGHT);
                                      present(SSR_B_ID, S_LIGHT);
                                         present(i, S_TEMP);
                                    if (trigger == 0){
                                      send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                                      send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                                      trigger = 1;
                                      debouncerA.update();
                                      // Get the update value
                                      int valueA = debouncerA.read();
                                      if (valueA != oldValueA && valueA == 0) {
                                        send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
                                      oldValueA = valueA;
                                      debouncerB.update();
                                      int valueB = debouncerB.read();
                                      if (valueB != oldValueB && valueB == 0) {
                                        send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
                                      oldValueB = valueB;
                                      sleep(conversionTime);
                                        #if COMPARE_TEMP == 1
                                      sleep(SLEEP_TIME);
                                        switch (message.sensor) {
                                          case 1:
                                            stateA = message.getBool();
                                            digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                                          case 2:
                                            stateB = message.getBool();
                                            digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
                                        Serial.print("from node:");
                                        Serial.println(message.sender);
                                    Please help me
                                    • pepsonP pepson
                                      Hi
                                         DESCRIPTION
                                      // Define Relays
                                      // Define Variables
                                      int oldValueA = 0;
                                      int oldValueB = 0;
                                      int trigger = 0;
                                      int numSensors=0;
                                      bool metric = true;
                                      void before()
                                        sensors.begin();
                                           present(i, S_TEMP);
                                      if (trigger == 0){
                                        trigger = 1;
                                        oldValueA = valueA;
                                        oldValueB = valueB;
                                        sleep(SLEEP_TIME);
                                            case 1:
                                            case 2:
                                      Please help me
                                      rejoe2R
                                      rejoe2R
                                      rejoe2
                                      @pepson
                                      Imo there are several things to look at:
                                      1. Pin 3 seems to be used for button a + 1-wire? -> use a different one
                                      2. How many DS18B20 do you have attached?
                                        a) In case it's up to three, you try to report Relay and Temp info partly under the same Child_ID (1+2). Imo, it's better to chose a different starting Child ID, something like "present(i+10, S_TEMP)" or use a variable like "FIRST_TEMP_CHILD" (also use the same scheme for sending).
                                        b) You may also suffer from a wiring problem, if you are able to compile and flash this sketch. Just for testing you could add a debugg-message to serial with the numSensors
                                      3. Combining relays, debounced buttons and sleep() most likely will cause problems. Better use a non-blocking loop as described in post #45 and following.
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        wrote on last edited by pepson
                                        #66
                                        I use one temp sensor. Ok i try correct but i dont know how correct it for send...please help me for sending...
                                        And please help me with this:
                                           DESCRIPTION
                                        // Define Relays
                                        // Define Variables
                                        int oldValueA = 0;
                                        int oldValueB = 0;
                                        int trigger = 0;
                                        #define ONE_WIRE_BUS 7 // Pin where dallase sensor is connected
                                        int numSensors=0;
                                        bool metric = true;
                                        void before()
                                          sensors.begin();
                                             present(i+10, S_TEMP);
                                        if (trigger == 0){
                                          trigger = 1;
                                          oldValueA = valueA;
                                          oldValueB = valueB;
                                          sleep(SLEEP_TIME);
                                              case 1:
                                              case 2:
                                        • rejoe2R
                                          rejoe2R
                                          rejoe2
                                          1. Wrt sending: your controller should show one temperature sensor with Child ID 10. As a consequence, the temp value should also be reported using this ID. So you should adopt this line appropriately, just use the same logic as in presentation() :grin: .
                                          1. For the non-blocking loop: As already mentionned, within this thread you just should follow @bluezr1 steps and some of my remarks :grinning: .
                                            The sketch in #63 should be a working solution, but when using dallas temp instead of the DHT, you have also to change the sleep(conversionTime) to wait().
