  3. Repeater Node and DHT11
7 Posts 2 Posters 2.0k Views 3 Watching
  • W
    W
    Wikibear
    Hello together,
    i try to understand how does it works. Did i need really only #define MY_REPEATER_FEATURE ???
    Must i set some variables in loop or define more that i can use this as repeater?
    DHT11 takes some time to read out data. Normally we do this over sleep. But in this time the repeater feature will be blocked. I read so many threads and posts here at mysensors that i get more and more confused.
    What i understand at the moment, that i only need #define MY_REPEATER_FEATURE and loop does not contain any sleep. Is this right or not?
    Greetings Wikibear
    • W Wikibear
      Hello together,
      Greetings Wikibear
      @wikibear yes, that should be sufficient. For the delay when reading DHT11 you can replace sleep() with wait().
      Welcome to the MySensors community!
      • W
        W
        Wikibear
        wrote on last edited by Wikibear
        Thank you very much for this quick reply!
        I read a thread with gw.XXX commands. That confused me. API say only #define MY_REPEATER_FEATURE.
        Now it's more clear to me!
        • mfalkviddM
          @wikibear great.
          gw.xxx is from MySensors 1.x. In MySensors 2.x, gw. is no longer needed. More info here: https://forum.mysensors.org/topic/4261/mysensors-2-0-0-released
          • W
            W
            Wikibear
            Thanks but it seems not to work. My serial Gateway is working well. My repeater works DHT sends temp and humidity but it seems that repeat function does not work. I'm a little bit far away from gateway. A stay beside my repeater with arduino mini pro direct connected via programmer powered with USB voltage. But i didn't get any connection. If i go beside my gateway all is fine.
            Repeater code:
            //#define MY_TRANSPORT_WAIT_READY_MS 1
            #define MY_NODE_ID 51
            #define MY_RF24_IRQ_PIN 2
            #define MY_RF24_PA_LEVEL   (RF24_PA_MAX)
            #define DHT_DATA_PIN 3
            #define SENSOR_TEMP_OFFSET 0
            static const uint64_t UPDATE_INTERVAL = 60000;
            #define CHILD_ID_HUM 1
            #define CHILD_ID_TEMP 0
            float lastTemp;
            float lastHum;
            uint8_t nNoUpdatesTemp;
            uint8_t nNoUpdatesHum;
            bool metric = true;
            DHT dht;
              sendSketchInfo("TemperatureAndHumidity", "1.1");
              present(CHILD_ID_HUM, S_HUM);
              dht.readSensor(true);
              if (isnan(temperature)) {
                lastTemp = temperature;
                if (!metric) {
                // Reset no updates counter
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                Serial.print("T: ");
                nNoUpdatesTemp++;
              if (isnan(humidity)) {
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                Serial.print("H: ");
                Serial.println(humidity);
                nNoUpdatesHum++;
              wait(UPDATE_INTERVAL);
            Mini pro code:
            // Enable debug prints
            //#define MY_RS485
            #define MY_NODE_ID 52
            #define MY_PARENT_NODE_ID 51
            int oldBatteryPcnt = 0;
            static const uint64_t UPDATE_INTERVAL = 300000;
            float lastTemp;
            float lastHum;
            bool metric = true;
            DHT dht;
                analogReference(INTERNAL1V1);
                analogReference(INTERNAL);
                if (!metric) {
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                /////////////battery part////////////////
              #ifdef MY_DEBUG
                Serial.println(sensorValue);
              #ifdef MY_DEBUG
                Serial.print(batteryV);
                Serial.println(" V");
                Serial.print(batteryPcnt);
                Serial.println(" %");
                    // Power up radio after sleep
                    if(batteryPcnt>100){ Serial.println("too much batt power"); batteryPcnt = 100; }
                    oldBatteryPcnt = batteryPcnt;
                nNoUpdatesTemp++;
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                nNoUpdatesHum++;
              sleep(UPDATE_INTERVAL);
            Thanks for any help
            • W Wikibear
              Repeater code:
              float lastTemp;
              float lastHum;
              bool metric = true;
              DHT dht;
                  if (!metric) {
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesTemp++;
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesHum++;
              Mini pro code:
              //#define MY_RS485
              float lastTemp;
              float lastHum;
              bool metric = true;
              DHT dht;
                  if (!metric) {
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                #ifdef MY_DEBUG
                #ifdef MY_DEBUG
                  nNoUpdatesTemp++;
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesHum++;
              Thanks for any help
              @wikibear could you post the debug output from the node, repeater and gateway?
              • W
                W
                Wikibear
                I'm not sure whats happened... But i think its working now. I try to investigate why it works now! If i find the reason i will post here. Thanks for help.
                12.5k
