  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    @neverdie Tinfoil?
    You get an A+ for creative thinking. I suppose extra wide foil tape might work.
    zboblamontZ
    zboblamontZ
    zboblamont
    @neverdie I was thinking kitchen foil pressed flat as possible to the block surface, whatever works...
      #229
      This is a good video for how to auto level in ChiliPeppr:
      https://www.youtube.com/watch?v=6WNE3E1ZZYY
      So, with that as inspiration, I plan to connect the probe to A5 on the woodpecker, and the PCB surface to GND. He soldered his ground wire to the PCB, so I guess I'll do the same, at least for now.
      I'll use tape to secure the PCB to the sacrificial board underneath.
        #230
        I've confirmed that A5 and GND work correctly for the auto-leveling.
        However, Chillipeppr strangely defaults to probe a much larger area than is needed for auto-leveling, so I need to figure out how to reduce the upper and right-hand boundaries of the probing area:
        Otherwise, it runs the risk of not even hitting the PCB if it gets too far out.
          #231
          Nailed it!
          Well, further progress will have to wait until I can move the CNC to the garage or outdoors, so that I don't fill the house with toxic fiberglass particles (Thank you @executivul for pointing that out, and sorry I butchered your name earlier. I didn't mean to.)
          E 1 Reply Last reply
            Nailed it!
            E
            E
            executivul
            @neverdie no problem, I got used to it since I'm using such a weird nickname, the good part is it's always free to register on any forum so all I have to remember is the pass.
            I'm really excited about wet milling, it's freezing down here and not having to have windows open for the modded vacuum cleaner it's a treat. The trick is to use a solution with higher surface tension then water, but not too thick or it will gather around the mill as a small tornado and start splashing everywhere. You can use soap, shampoo, dishwash, carwash, etc. Start at 1:1 water mix and add more water if it tends to gather around the spinning bit. It's better to pour it slowly on the board and spread with your finger (use a syringe) than to spray it as not to make foam. Also try using a clear shampoo to better see what's milling below the liquid. A piece of flat plastic, acrylic, lexan, plexiglas, whatever, doublesided taped to the wood spoilboard is a must unless you leave a large margin between the actual milling and pcb edge liquid will spill and will swell the wood. Have a roll of paper sheets nearby and a garbage bag open. Always use glasses when operating the machine. I made a "fence" out of some polycarbonate sheet to contain any eventual splashes which occur mostly when drilling through the board, normal engraving behaves and doesn't splash at all.
              #233
              Given that the goal is to get 6mil isolatioin routing, what cutting depth should I set in flatcam? 0.05mm?
              dbemowskD 1 Reply Last reply
                dbemowskD
                dbemowskD
                @neverdie I have been kind of following this topic, but don't have a CNC mill, but wouldn't the thickness of the copper clad on the board be your depth?
                • dbemowskD dbemowsk
                  #235
                  Makes sense to me. Well, doing that it would be 0.01mm. But since this isn't a perfect process, it likely needs some added depth to guarantee it's removed. The effective tool width gets wider the deeper you cut, so in some sense I suppose there's that as an added constraint on how deep you can cut before it becomes more than 6 mil isolation. We could try to arrive at an answer analytically from first principles only, but I thought it might be easier to just ask what depth others who are doing this successfully are using.
                  dbemowskD andrewA 2 Replies Last reply
                    dbemowskD
                    dbemowskD
                    @neverdie See what depth you need to go with that bit to get 6 mil routing, and that will be your max. I would think that would be more than 0.01mm, but I haven't seen your bit, so I don't know.
                      andrewA
                      andrewA
                      andrew
                      @neverdie you should use one depth, regardless of the trace width. for me 0.05mm worked, see my shared settings above. you should decide the isolation width, this is the main property for the given config, but you should stick for one milling depth only. if the requires isolation width is bigger than the tool width at a given depth, then it will use multiple rounds to reach the given width, but still, with one milling depth.
                        #238
                        I'm stuck. I converted my gerber to gcode using flatcam, and imported it into Chilipeppr:
                        On the one hand, it seems to have gotten the dimensioning right, as indicated by the Y1.48in and X1.43in. However, the grid that it's showing is out of sync with that. Each square on the grid is 5mm. It's as though Chilipeppr thinks the entire design fits easily inside a 5mm square, and so when I attempt to do the autoleveling, it comes out completely wrong.
                        andrewA 1 Reply Last reply
                          andrewA
                          andrewA
                          andrew
                          you can mark the zero point in the pcb designer tool before you export the gergbel, or in flatcam, during the post processing. if you do not define it, then maybe the given zero point could have some "offset" to the effective design. it is not problem, but it could make your life easier if your zero is e.g. at the pcb's corner.
                          if you don't want to update the files, then in chilipeppr you can update the probe area to not start from 0,0 but from a given offset.
                            Thanks! I don't know why, but somehow that fixed the problem:
                              I found these copper clad boards that seem to be made out of bakelite (?) rather than fiberglass. So, hopefully not the same level of toxic dust concern as with FR4's.
                              I double sided taped the non-copper side:
                              and soldered a ground wire on the copper clad side:
                              Now I'm ready for autoleveling and then my first PCB etch.
                                Here are the results of the autoleveling:
                                For some reason it's hard to read some of the numbers.
                                  dbemowskD
                                  dbemowskD
                                  @neverdie It looks like everything in the top right corner is above the level bed surface. which puts it above the grid that is shown. Looks like the bed is tilted.
                                    #244
                                    @dbemowsk Fortunately the auto-leveling should render it a moot issue.
                                      #245
                                      LOL, except that unfortunately it did not:
                                      OK, my bad. I hadn't sent the auto-leveled g-code to the workspace (I had thought this would be done automatically, but no), so this picture shows what would happen without auto-leveling.
                                      I've made the change and am now re-running the job with the auto-leveled g-code.
                                        dbemowskD
                                        dbemowskD
                                        @neverdie Looks about on par with your final matrix, only it is following the grid and not the auto leveling values.
                                          So, I re-ran the job over the same area with the g-code modified by auto-leveling, and this time I got a better result:
                                          So, now I'll try it on a fresh area of the PCB, after doing a new auto-leveling.
                                          rmtuckerR 1 Reply Last reply
