  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    #231
    Nailed it!
    Well, further progress will have to wait until I can move the CNC to the garage or outdoors, so that I don't fill the house with toxic fiberglass particles (Thank you @executivul for pointing that out, and sorry I butchered your name earlier. I didn't mean to.)
    E 1 Reply Last reply
      Nailed it!
      E
      E
      executivul
      @neverdie no problem, I got used to it since I'm using such a weird nickname, the good part is it's always free to register on any forum so all I have to remember is the pass.
      I'm really excited about wet milling, it's freezing down here and not having to have windows open for the modded vacuum cleaner it's a treat. The trick is to use a solution with higher surface tension then water, but not too thick or it will gather around the mill as a small tornado and start splashing everywhere. You can use soap, shampoo, dishwash, carwash, etc. Start at 1:1 water mix and add more water if it tends to gather around the spinning bit. It's better to pour it slowly on the board and spread with your finger (use a syringe) than to spray it as not to make foam. Also try using a clear shampoo to better see what's milling below the liquid. A piece of flat plastic, acrylic, lexan, plexiglas, whatever, doublesided taped to the wood spoilboard is a must unless you leave a large margin between the actual milling and pcb edge liquid will spill and will swell the wood. Have a roll of paper sheets nearby and a garbage bag open. Always use glasses when operating the machine. I made a "fence" out of some polycarbonate sheet to contain any eventual splashes which occur mostly when drilling through the board, normal engraving behaves and doesn't splash at all.
        #233
        Given that the goal is to get 6mil isolatioin routing, what cutting depth should I set in flatcam? 0.05mm?
        dbemowskD 1 Reply Last reply
          dbemowskD
          dbemowskD
          @neverdie I have been kind of following this topic, but don't have a CNC mill, but wouldn't the thickness of the copper clad on the board be your depth?
          • dbemowskD dbemowsk
            #235
            Makes sense to me. Well, doing that it would be 0.01mm. But since this isn't a perfect process, it likely needs some added depth to guarantee it's removed. The effective tool width gets wider the deeper you cut, so in some sense I suppose there's that as an added constraint on how deep you can cut before it becomes more than 6 mil isolation. We could try to arrive at an answer analytically from first principles only, but I thought it might be easier to just ask what depth others who are doing this successfully are using.
            dbemowskD andrewA 2 Replies Last reply
              dbemowskD
              dbemowskD
              @neverdie See what depth you need to go with that bit to get 6 mil routing, and that will be your max. I would think that would be more than 0.01mm, but I haven't seen your bit, so I don't know.
                andrewA
                andrewA
                andrew
                @neverdie you should use one depth, regardless of the trace width. for me 0.05mm worked, see my shared settings above. you should decide the isolation width, this is the main property for the given config, but you should stick for one milling depth only. if the requires isolation width is bigger than the tool width at a given depth, then it will use multiple rounds to reach the given width, but still, with one milling depth.
                  #238
                  I'm stuck. I converted my gerber to gcode using flatcam, and imported it into Chilipeppr:
                  On the one hand, it seems to have gotten the dimensioning right, as indicated by the Y1.48in and X1.43in. However, the grid that it's showing is out of sync with that. Each square on the grid is 5mm. It's as though Chilipeppr thinks the entire design fits easily inside a 5mm square, and so when I attempt to do the autoleveling, it comes out completely wrong.
                  andrewA 1 Reply Last reply
                    andrewA
                    andrewA
                    andrew
                    you can mark the zero point in the pcb designer tool before you export the gergbel, or in flatcam, during the post processing. if you do not define it, then maybe the given zero point could have some "offset" to the effective design. it is not problem, but it could make your life easier if your zero is e.g. at the pcb's corner.
                    if you don't want to update the files, then in chilipeppr you can update the probe area to not start from 0,0 but from a given offset.
                      Thanks! I don't know why, but somehow that fixed the problem:
                        I found these copper clad boards that seem to be made out of bakelite (?) rather than fiberglass. So, hopefully not the same level of toxic dust concern as with FR4's.
                        I double sided taped the non-copper side:
                        and soldered a ground wire on the copper clad side:
                        Now I'm ready for autoleveling and then my first PCB etch.
                          Here are the results of the autoleveling:
                          For some reason it's hard to read some of the numbers.
                            dbemowskD
                            dbemowskD
                            @neverdie It looks like everything in the top right corner is above the level bed surface. which puts it above the grid that is shown. Looks like the bed is tilted.
                              #244
                              @dbemowsk Fortunately the auto-leveling should render it a moot issue.
                                #245
                                LOL, except that unfortunately it did not:
                                OK, my bad. I hadn't sent the auto-leveled g-code to the workspace (I had thought this would be done automatically, but no), so this picture shows what would happen without auto-leveling.
                                I've made the change and am now re-running the job with the auto-leveled g-code.
                                  dbemowskD
                                  dbemowskD
                                  @neverdie Looks about on par with your final matrix, only it is following the grid and not the auto leveling values.
                                    So, I re-ran the job over the same area with the g-code modified by auto-leveling, and this time I got a better result:
                                    So, now I'll try it on a fresh area of the PCB, after doing a new auto-leveling.
                                    rmtuckerR 1 Reply Last reply
                                      #248
                                      Judging from the looks of the photo directly above though, it looks like quite a bit of copper wasn't removed where it needed to be. I'm guessing I will need to:
                                      1. etch to a deeper depth; and/or,
                                      2. use a finer mesh for auto-leveling; and/or
                                      3. ???
                                      • E
                                        E
                                        executivul
                                        Etch 0.1mm. The groove between tracks also helps with soldering. I currently use 0.1mm and even 0.15 when in a hurry.
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          @neverdie
                                          The last photo looks like the tip is missing from the cutter?
