  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • E executivul
    The last bit tested is under 0.1mm wide. WOW!
    Remember to:
    -pre run: set the autolevel probe limits and a speed of 25mm/s
    -run the probing: and DON'T redo Z probing after autolevel, it messes things up, use the same bit for probing and engraving.
    -post run: "send autoleveled gcode to workspace"
    Go slower, 100-150mm/min, afterall you don't need 6mil traces for a huge board so time is not an issue here.
    PS. try some water/shampoo mix, it kinda' helps with engraving, cooling, lube, I don't know.
    PPS. I've moved to opencncpilot lately (last 2 boards), free on github, a short tut on the tube, it has a great feature that is to break long moves in 5mm segments, works better for bowed/wavy boards.
    #288
    @executivul Do you cut everything in one pass, or do you use multiple passes (each pass at a deeper depth)? Flatcam supports multiple passes, though I have been using only 1 pass.
    • E executivul
      Remember to:
      @executivul
      Thanks for the tips. Here is Jack's bit again, this time at F100. Even better!
        #290
        Here are Jack's etching bits: https://www.aliexpress.com/store/product/Freeshipping-10pcs-3-175mm-Flat-Bottom-CNC-wood-Router-machine-Tools-Cutting-Bits-Carving-V-Shape/424291_32718430291.html?spm=2114.12010612.0.0.6cc36820P3WAXu
        It says 30 degree angle and 0.1mm tip.
          Time to see whether this machine can cut the mustard or not. I just did a 5mm autoleveling on the following:
          and now I'll try cutting it using Jack's bit.
            #292
            Here's the result:
            The above was cut at a depth of z=-0.1, and still not all the paths cut completely through. Yet, In the middle one of the traces got obliterated.
            I'm afraid I'm unlikely to make it work at the resolution that I'm able get from the fab. It's close, but no cigar. So I think it's better suited for earlier prototyping work that's not so optimized for space. For that it might be very handy. Then I can both cut deeper and also not worry about trace obliteration.
              By the way, do any of the programs have built-in verification after the cutting, where it can probe to verify that the trace is throughly cut (i.e. no continuity with ground)? Seems like it should be easy to do, at least in theory, by using a method similar to the probing for auto-leveling, except probing each track instead.
              E 1 Reply Last reply
                E
                E
                executivul
                @neverdie Congrats for your result, I use a "copper pour" all over the board, that makes it pass at least 2 times, once for the track and once for the pour isolation. I never mess with flatcam's multiple passes, but I believe you can get the same results. What you see in the middle are copper "silvers" that is copper left behind between traces.
                From the last picture of the width test is seems your bit is engraving 0.1mm wide.
                Try to use OpenCNCPilot instead of Chillipeppr and set the lines to be split at 1-2mm lengths and probing each 2-3mm. That should make the engraving depth more uniform.
                I see a couple copper flakes, maybe go even slower than 100? And give it a light sandpaper with 1000 grit or a scotchbrite sponge and some abrasive detergent for dishes?
                • E executivul
                  @executivul Thanks!
                  For the convenience of others reading this thread, here's a quick youtube:
                  https://www.youtube.com/watch?v=XDCu3cgOjCY
                  I'm surprised to learn that not all auto levelers do it that way, because it seems like the only right way to do it. I'll give it a try.
                    #296
                    Well, for some reason when I connect using OpoenCNCPilot, it turns the spindle on at maximum speed. I tried turning it off with the command 'S0', but it had no effect. So, I manually disconnected the wire that powers the spindle. Surely, there's a better way?
                    Anyhow, after doing that, I notice that the motors are making a really loud shrill sound, even though they're not moving. So, something is definitely FUBAR the moment I connect.
                    I had to disconnect and then connect using chilipeppr to have it all return to normal.
                    Maybe @andrew can try it? Perhaps there's a workaround that's not self-evident to me, but perhaps would be to someone else.
                      E
                      E
                      executivul
                      @neverdie OpenCNCPilot needs latest grbl 1.1f
                        OK, I'll resume the search for my dragon....
                        Meanwhile, I should be receiving my CNC drill bits and routing bits (to cut the board outline) fairly soon. Will I be using Chillipeppr to do those tasks (I'm guessing so) or something else?
                          E
                          E
                          executivul
                          @neverdie I have an idea, why don't you open the gcode in Opencncpilot, simplify it, split long moves, save it and then open in chillipeppr and do the probong and actual milling?
                          • E executivul
                            #300
                            @executivul Brilliant idea! Simplifying, the line count went from 3609 to 3608. Converting arcs to line segments had no effect. Then, splitting every 1mm, it went to 4114. I copied it into a new file, and now I'll see how it runs using chilipeppr.
                              Results look much better this time:
                              Using Chilipeppr, I probed every 3mm and then let it rip. As before, it was cutting at z=-0.1 and a feedrate of 76.2 (the feedrate wasn't a conscience choice but rather just what flatcam gave me, for whatever reason).
                              The good news is that it doesn't have the blatantly obvious trace obliteration that it had the first time. All in all, it looks like a definite improvement. :)
                                E
                                E
                                executivul
                                @neverdie Seems like it's getting better, still some traces in the middle are hairthin, maybe increasing tool size in flatcam a tad? like 0.12mm so it lets the tracks be wider. Bare in mind this is a prototyping machine, I use mine for low batch home automation boards, under 20 boards of the same kind, at the price of a blank pcb I can buy 10 for the price of one fab made 100x150mm, not to speak of wait time.
                                After you are satisfied with the board is time to get some plumber's paste for soldering copper pipes, that is used for tinning, or maybe you can find some liquid tinning solution, but that's more expensive here, I use the paste.
                                Then some soldermask and some uv led strips to make an exposure unit and there you have your own pcb fab at home :sunglasses:
                                • E executivul
                                  #303
                                  @executivul How much overlap in flatcam are you using? I've been using zero. Would changing it to something non-zero help, or is it irrelevant?
                                    E
                                    E
                                    executivul
                                    @neverdie I never do multiple passes, so overlap is irrelevant to me...
                                      #305
                                      When I probe at 2mm, it often randomly fails with messages like this:
                                      Moving to {x:12,y:28}
                                      probe failed, clear controller alarm before resuming
                                      Paused
                                      Working on probe for {x:12,y:26} Found lowest Z:0.17499999999999996
                                      Paused
                                      What is causing these "probe failed" to happen? And how exactly am I supposed to "clear controller alarm"? It always seems that I need to disconnect from the serial port and then reconnect to get any further movement. But if I do that, it clears the x,y,z positions, effectively preventing any kind of sensible resumption. :(
                                        Argh, it just happened again. This time when doing 3mm probing.
                                        Moving to {x:12,y:27}
                                        Paused
                                        Working on probe for {x:12,y:24} Found lowest Z:0.23000000000000004
                                        Paused
                                        How does it even decide that a probe error has happened?
                                          Paused
                                          Paused
                                          E
                                          E
                                          executivul
                                          @neverdie timing racing condition is f*king spjs, ugly hack is to try to increase probing starting height from 0.5mm to 1.0mm
