  3. 💬 Multi-Sensor: Temp/Humidity/PIR/ Leak/Magnet/Light/Accel
117 Posts 18 Posters 44.9k Views 17 Watching
    @nca78 What would be a good tiny buzzer to put on it, for making one of those ever popular location tags? I'm guessing something piezo? I'm not finding anything tiny though.
    For instance, anything smaller than this?
    https://www.aliexpress.com/item/2731HZ-3x4-5x1-9mm-Super-small-miniature-AAC-electromagnetic-DET402-G-1-SMD-Passive-buzzer-3/32839766133.html?spm=2114.search0204.3.177.AclxtY&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_5000015_10151_10344_10068_10130_10345_10324_10342_10547_10325_10343_51102_10546_10340_10341_10548_10545_5130015_10541_10084_10083_10307_5690015_10539_5080015_10312_10059_10313_10314_10534_100031_10604_10603_10103_10605_10594_5060015_10596_10142_10107,searchweb201603_14,ppcSwitch_4_ppcChannel&algo_expid=692cffc2-e301-4616-a6f8-76921652c1ba-23&algo_pvid=692cffc2-e301-4616-a6f8-76921652c1ba&rmStoreLevelAB=0
    Nca78N 1 Reply Last reply
      @neverdie this looks pretty small for a buzzer already. Sorry no idea about smaller ones, but please post your results I'm interested :)
      • Nca78N Nca78
        #88
        @nca78 Will do. I ordered 20 of them. Might be a nice addition on a leak detector also.
          #89
          I finally received the MAX44009 board:
          https://www.aliexpress.com/item/Smart-Electronics-5PCS-lot-MAX44009-ambient-light-sensor-is-the-I2C-digital-output-module-development-board/32767691971.html?spm=a2g0s.9042311.0.0.sOFetX
          I'm able to read lux values by pulling A0 on the board to Vcc and using this library and sketch:
          https://github.com/dantudose/MAX44009/blob/master/Example/Luxmeter.ino
          Very easy. :)
            Very easy. :)
            @neverdie you don't even need to bother with a lib, just 2 functions are enough.
            https://blog.kkessler.com/tag/max44009/
              #91
              even if it's two functions only, if i need to reuse them in others sketch, I would prefer them in a lib. Only "one line" (include) in the sketch compared to x lines ;)
              • Nca78N Nca78
                #92
                @nca78 said in 💬 Multi-Sensor: Temp/Humidity/PIR/ Leak/Magnet/Light/Accel:
                Received it today. Putting just DC across it produces no sound at all. Driving it with a pulsed voltage (say 10K hertz at 50% duty cycle) directly from an arduino pin produces sound, but at very low volume. Since it draws 220ma with a straight 3v DC voltage across it, I'm guessing a current more like that is what it will take to get it to produce louder sound, but that's only just a wild guess.
                  #93
                  I tried driving it from a load switch controlled by the arduino, and that helped increase the volume somewhat.
                  Doing that, and using this script, I think it will be audible if you're in the same room as it (and if the room is otherwise quiet).
                  long lastMicrosTime=0;  //timestamp in microseconds
                    pinMode(10,OUTPUT);
                    for (int x=0;x<1000;x++) {
                      digitalWrite(10,HIGH);
                      lastMicrosTime=micros();
                      while ((micros()-lastMicrosTime)<300) {} //wait until 300 microseconds have passed
                      digitalWrite(10,LOW);
                      while ((micros()-lastMicrosTime)<x) {} //wait until another x microseconds have passed
                  So, if you were to use it as a locator beacon attached to something you wanted to find, it might be good enough for that.
                      pinMode(10,OUTPUT);
                    @neverdie said in 💬 Multi-Sensor: Temp/Humidity/PIR/ Leak/Magnet/Light/Accel:
                    Guess this is not made for Vietnam then :D
                    I supposed this type of buzzer is made more for user feedback for things like touch sensors, than for raising alert.
                    • Nca78N Nca78
                      #95
                      @nca78 What strange is that if I cup my hand over it, it actually becomes louder. Not sure what's up with that. So, maybe I'm just not driving it right.
                        Here's the latest version of the PIR sensor embodiment:
                        It runs from two CR2032's.
                        Very compact! :)
                          Very compact! :)
                          ahmedadelhosniA
                          ahmedadelhosniA
                          ahmedadelhosni
                          @neverdie how do you connect thr two Cr batteries ?
                          Another question ? I read in another comments that you need 100-200 uF capacitor so that the radio can work since thr CR battery wont be strong enough. Did you add this ?
                            @ahmedadelhosni said in 💬 Multi-Sensor: Temp/Humidity/PIR/ Leak/Magnet/Light/Accel:
                            This was recently discussed in the Bluetooth action! thread.
                              Isn't that the principle for most speakers, using a sound box ?
                              • T
                                Tiwo85
                                Wich board do you use in arduino? I can only use Waveshare BLE4.0. At Generic etc. It seems, that the oscillator doesn't work probably.
                                • T Tiwo85
                                  @tiwo85 said in 💬 Multi-Sensor: Temp/Humidity/PIR/ Leak/Magnet/Light/Accel:
                                  Not sure what you're asking.
                                    Tiwo85
                                    wrote on last edited by Tiwo85
                                    #102
                                    @neverdie I mean this:
                                    When I use Generic nRF51 or something else, the onboard LED turns on and doesn't turns off. When I use Waveshare BLE400 the sketch works as usual
                                    • T Tiwo85
                                      #103
                                      @tiwo85
                                      I use this:
                                      You download it from @d00616 on github.
                                        For PIR capability, the multi-sensor can simply plug into this PIR module: https://www.openhardware.io/view/420/AM612-Passive-Infrared-Sensor-Breakout-Board
                                        Tiwo85
                                        @neverdie do you have a working example sketch. I try the example sketch from the 10years pir sensor an d modify a little bit, but it doesn't work. The sketch awake every 5 minutes and send the state from the pir and that's it.
                                        • T Tiwo85
                                          @tiwo85
                                          https://www.openhardware.io/view/510/Multi-Sensor-TempHumidityPIR-LeakMagnetLightAccel#tabs-source
