  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    #312
    Here's what @andrew had to say:
    edge cut or hole milling with the 0.8mm endmill:
    feed rate: 170
    z cut: -1.7mm
    multi depth, depth/pass: 0.2mm
    So, I guess by "z cut: -1.7mm", he likely meant that as a Z that's -1.7mm below the depth of the PCB? I'm not sure how else to interpret that. Hmmm.. I think he assumed the board thickness of 1.5mm, so he gave is 0.2mm more than that. Mine (being single sided) is 1.35mm, so I'll set cutting depth to 1.6mm, just to be sure.
    Aside from that, 0.8mm end mill and multiple passes at a feed rate of 170. So, I guess I use flatcam to produce the gcode that conforms to this and then run it in Chilipeppr.
    And, it looks like flatcam adds the cut-out supports automatically. Nice.
      Argh. Another probe failure:
      Moving to {x:4.430000007152557,y:19.430000007152557}
      probe failed, clear controller alarm before resuming
      Paused
      Working on probe for {x:4.430000007152557,y:24.430000007152557} Found lowest Z:0.051000000000000156
      Paused
      even though I have it set to start probing at z=1.0mm. This really needs to be fixed.
        Unfortunately, I botched the third etching pass. My fault. But I decided to try the board cutout anyway:
        I didn't see a way for flatcam to do a circular cut-out, so I just went with the rectangular cut-out. Anyhow, it worked.
        I receive my CNC drill bits on Friday, so after that I should be able to do a complete PCB of some kind. :)
          Paused
          Paused
          I wonder whether increasing the priority of the tasks using the Windows task manager might help at all? Perhaps some background tasks are interfering and slowing things down to the point where cp can't keep up with real-time?
          E 1 Reply Last reply
            E
            E
            executivul
            @neverdie there is a tutorial for custom board cutout in flatcam, "google it baby", it involves manually using open_gerber and follow commands. I'm on the phone and can't find it right now.
            Regarding cutout I sugest you use 0.5mm depth and 100-150mm/min with 0.8mm endmill. Your spindle is pretty low rpm. I use 1mm depth and 300-400mm/min, 2 passes, 1.6mm thick pcb, about 40k rpm.
              #317
              For those who are interested, this is the best solder mask tutorial I was able to find:
              https://www.youtube.com/watch?v=B0Syj4awcc8
              It doesn't look too bad, but I'd still rather not go there if I can avoid it.
              However, this process doesn't seem optimized for people who are doing, say, .1mm etchings around their pads. I mean, couldn't one squeegee in the solder mask, uv cure it, and then remove what trace amounts might remain on the pads themselves by burnishing it off with a scotchbrite pad or something? I mean, for quick and dirty results that work well enough for prototyping, that's what I'd have in mind. Anyone try something like that?
              The techniques on youtube for using solder mask goop aren't optimized for people who have veritable canals around their solder pads. Why not take advantage of that?
              • andrewA
                andrewA
                andrew
                wrote on last edited by andrew
                #318
                @NeverDie oh, you've a lot of stuff and update since my last visit here. I've just a couple of minutes now, so I just quickly checked the new posts. let me give some further details/tips to you based on the issues I see:
                • flatcam does support hole milling. when you select the given drl file (project tab) you can select all of the given holes (selected tab) which you want to mill, then scroll down (see screenshot below) where you can generate the hole milling geometry. 0_1514475910968_Screen Shot 2017-12-28 at 16.36.02.png
                • you can find my edge cutting related details/setting in my previous posts. using the edge cuts grbl file loaded to flatcam you can generate the corresponding milling path. I use multiple passes to be sure that the spindle will be able to handle the process. you can generate the tool path from the gui as well, but I prefer the gui's command line (see the bottom line at the screenshot). use the "help" command there. for non rectangular boards I use the combination of isolate command, together with exteriors or interiors commands and with the geocutout command if it is necessary.
                • in case of the autoleveling there is a safety related parameter which describes the max touch depth/travel. if the spindle has to move more, than that will trigger an error. be sure, that the safe moving Z distance and the max touch probe distance on Z axis is properly configured.
                • some of your isolation results are not too nice. I would double check your cnc assembly. be sure that the x axis is parallel with the cnc bed, which is also "flat" and do not have any angle. autoleveling could make the results better, but properly adjusted xyz axis with bed is essential.
                • for isolation I use multiple passes. usually 3-5 times of the tool width. I do use overlapping, usually I calculate the overlapping to be 10-20% of the given tool width.
                happy hacking with the cnc :)
                • andrewA andrew
                  #319
                  @andrew
                  Are you doing solder mask, or have you been able to avoid that? I take it that you're also not tinning?
                  BTW, @executivul 's suggestion of using the OpenCNCPilot to break line segments into smaller lengths prior to autoleveling is genius. A+ Recommended.
                    It's hard to photograph these etchings.
                    Do you have a flatbed scanner? Not sure if the copper reflects too much light, but the focus should be good.
                    #320
                    @mfalkvidd said in CNC PCB milling:
                    Yes, I may give that a try. Also, I think using a usb microscope to pan over the surface might make a lot of sense, since it would show more detail.
                    • andrewA andrew
                      #321
                      To that end, it sure would help to have some adjustment knobs. Is there a kit for that? Then I could dial it in exactly.
                      Lacking that, though, I suppose if the sacrifice board is flat enough then I could just shim it with sheets of paper at the corners near the hold-downs. That might be more precise than just loosening and re-tightening (after nudging) the guide rail bolts, hoping for improvement.
                        #322
                        So, I decided to relax the constraints and go for something easier, like a simple circuit for a load switch that uses an SOT23-6 and three 0603 SMD components:
                        The etching came out perfect the very first time. :) I cut it using a new Jack bit, and I cut it to a depth of z=-0.15 using three flatcam passes, each -0.05 deeper than the prior one. I tested it with a contuinity meter, and isolation is perfect. :)
                        BTW, I used OpenCNCPilot to break line segments down to 0.5mm, and I probed the board surface at 1mm for the autoleveling.
                        Next, I need to try soldering it to see what life without solder mask is like. To that end, would I be better off with wider cuts?
                        E NeverDieN 3 Replies Last reply
                          E
                          E
                          executivul
                          wrote on last edited by executivul
                          #323
                          @neverdie perfect result. I would however go for -0.15 depth from the start and maybe more passes for wider engraving, or using a 0.2mm bit. The small copper between pads of the chip should be gone, at least for my sloppy soldering sessions😉
                          LE. I always try to look in flatcam at the cnc paths (blue) if they cover completely the space between pads.
                            E
                            E
                            executivul
                            @neverdie I've had a nasty idea: try using a sharpie (very thin permanent marker) as soldermask, a few lines between the pads, just enough to stop the solder from bridging.
                            Might resist the heat for a short while and do the job, specially the nasty chemical smelling ones, I believe they are more like a paint than like water colours.
                            PS. It's just a never tested idea, don't blame me for weird drawings on your pcb.
                            • E executivul
                              #325
                              @executivul Yes, or use solder mask with a fountain pen or syringe or something to get it into those crevices. I do think the squeegee idea might work. Pack it in, wipe off the copper with a paper towel, and then bake it with uv. Seems like it might be fast and easy. Seems like you could always burnish any remainder off the pads. Not having tried it, but I don't see what can go wrong. And you only need it around the tricky pads, not the entire board.
                                Also, there's this solder mask, which you can cure with a heat gun:
                                https://www.amazon.com/MG-Chemicals-Peelable-Solder-Mask/dp/B009V1JZE6/ref=sr_1_1?ie=UTF8&qid=1514496094&sr=8-1&keywords=solder+mask
                                and maybe you can peel it off any pads that it accidently stick to.
                                • mfalkviddM
                                  #327
                                  Solder maks repair pens do exist. Maybe that could work?
                                  https://www.mgchemicals.com/products/prototyping-and-circuit-repair/pens/overcoat-pen-419d
                                  Edit: no, it won't work :(
                                  Reference: http://www.digikey.com/en/pdf/c/chemtronics/solder-resist-repairs
                                  • E executivul
                                    #328
                                    Why is that better than multiple passes to get that depth? Isn't the tip less likely to break if multiple passes are used?
                                    BTW, I ordered the peelable solder mask, so I'll see how that goes. It should arrive tomorrow.
                                      Exact same procedure as last time, except this time using the Model 20 and a different etching pattern:
                                      Meh, I'm not sure it's really an improvement. The model 20 jbit ust doesn't seem to cut as cleanly as a Jack bit.
                                      BTW, I increased the windows task priority of the browser (and, there, Chilipeppr) and also the serial port jason server, both to High. Since then I haven't had any probe failures. Causation, or luck? Time will tell.
                                        #330
                                        I think ideally the CNC would remove all of the extraneous copper that's near the pads. That way there'd be no risk of solder bridging to the extraneous copper. However, how to do that? The software doesn't obviously support removing extraneous copper.
                                        Here's an example:
                                        ![alt text](image url)
                                          #331
                                          Here's the Model 20 bit again, but this time with flatcam being told that its width is 0.25mm:
                                          The pad widths are just not as uniform as with the Jack bit. On the other hand, it looks like it should be less prone to solder bridging.
