  3. My new project : texboard pcb
9 Posts 3 Posters 3.5k Views 3 Watching
  • L Offline
    L Offline
    linkos
    Hello
    I want to share with you my new little project. It's a pcb board (designed with eagle/produced by pcbway) for an easy integration of my future mysensors nodes.
    the functionalities are :
    • socket for atmega328p-pu
      -socket for nrf24l01
      -isp socket for programming the board
      -power supply : 3v - 20v
      -support for mesuring and reporting the battery level to the gateway
      -i2c socket
      -digital i/o for the sensor
    Some pictures of the board :
    I'm actually working on a v2 of the board with a micro usb port and smd mounting with atmega328p-au (to save place)
    S 1 Reply Last reply
    • L linkos
      Hello
        -i2c socket
      @linkos nice work! One small suggestion is that you move the antenna on the radio outside the pcb. All the metal in traces and components might interfere with the signal.
      • L Offline
        L Offline
        linkos
        Thanks for your answer.
        Yes it's a good idea to move the nrf because I've allready experienced reception problems. It's possible that's the cause was the position of the antenna. Thanks for the tip
        • N Offline
          N Offline
          I agree with @sundberg84 suggestion. I think turning the radio around (180°) should be enough: no traces below antenna and no ISP header right in front. I would try to move the capacitor closer to the VCC/GND pins of the radio, too.
          Good job anyway, compact and clean looking sensor !
          • L Offline
            L Offline
            linkos
            Thanks for your answer. I'll keep them in mind for the future version of my board.
            However thanks for the compliments
            • L Offline
              L Offline
              linkos
              Hi
              I just finish the box for my new sensors. Just want to share it with you :)
              • N Offline
                N Offline
                Very clean, now you can make a v2 with button cell to make the same with a tiny size ;)
                • L Offline
                  L Offline
                  linkos
                  Yes. you're right
                  I just buy some CR2032 supports for pcb on ebay. I hope it will drain enouth power to run the node
                  N 1 Reply Last reply
                  • L linkos
                    Yes. you're right
                    N Offline
                    N Offline
                    @linkos you need to include a capacitor (100-200uF) in parallel to the battery to help it during peak load. And if possible in your sketch add short sleeps between successive TX/RX to let capacitor recharge.
                    12.1k
