  3. ClearEprom does not work for Sensebender GW
12 Posts 5 Posters 3.1k Views 5 Watching
  • T
    tomkxy
    I just tried to delete the EEPROM of my Sensebender GW with the sample sketch coming with the MySensor library (ClearEepromConfig) It does not seem to work. At least as far I can deduce from the debug statements I inserted. I put a print just before the for loop in the setup function and one after hwWriteConfig. The code does not reach the hwWriteConfig.
    I am using MySensors 2.1.1
    • Nca78N
      Hello @tomkxy it seems your post was missed by the "specialists" of the Sensebender boards.
      On Sensebender GW the chip doesn't have EEPROM so it's using an external EEPROM, maybe it's related.
      What is it printing if you put the following lines at the beginning of the script ?
      Serial.print("EEPROM_LOCAL_CONFIG_ADDRESS: ");
      Serial.println(EEPROM_LOCAL_CONFIG_ADDRESS);
      • Nca78N
        @tbowmo is any special action needed to clear EEPROM on Sensebender gateway ?
        • tbowmoT
          tbowmoT
          tbowmo
          @tomkxy @Nca78
          the ClearEEPROM sketch does use the hw abstraction layer, so it should work with the sensebender gateway. We did have some timing issues at one point in time, if I remember right. But I think we solved it.
          Which version of arduino are you using? And which version of the Arduino SAMD and MySensors SAMD board packages are you using?
          • T
            tomkxy
            The changed the sketch as follows:
            #define MY_CORE_ONLY
              while (hwMillis() - enter < (unsigned long)15000);
            	Serial.begin(MY_BAUD_RATE);
            		hwWriteConfig(i,0xFF);
            	// Nothing to do here...
            The output is:
            EEPROM_LOCAL_CONFIG_ADDRESS: 413
            I use the following versions:
            My Arduino version is: 1.8.5
            MySensors Board Version: 1.0.5
            Arduino SAMD Board Version: 1.6.11 (M3), 1.6.17 (M0+)
            Interesting observation which might be hinting at a fundamental problem:
            I need to double the baud rate in the serial monitor. So in order to get any output I need to set the baud rate to 230400
            • NiklasON
              NiklasON
              NiklasO
              wrote on last edited by NiklasO
              I have the same problem:
               while(!Serial);
              	for (uint16_t i=0; i<EEPROM_LOCAL_CONFIG_ADDRESS; i++) {
                  Serial.println("Clearing");
              	Serial.println("Clearing done.");
              Output:
              Clearing
              Edit:
              Changed to
              //#define MY_CORE_ONLY
              and added the code to before() and it works?
              • tbowmoT
                tbowmoT
                tbowmo
                @NiklasO @tomkxy
                Could any of you open an issue on github? Then we can track it with the project (and include it in an upcoming core group hackaton in February)
                alexsh1A 1 Reply Last reply
                • tbowmoT tbowmo
                  @NiklasO @tomkxy
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @tbowmo Any luck on fixing it please?
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @alexsh1
                    I thought that we had it solved, during our last collaboration code-sprint-evening a couple of months ago. But now I see that the bug was re-opened..
                    I'll see if I can have a look later this week, when I'm in the lab.. (But I am terrible at remembering stuff at the moment... :( )
                    alexsh1A 2 Replies Last reply
                    • tbowmoT tbowmo
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @tbowmo I'll give you heads-up :-)
                      Thanks for sorting it out!
                      • tbowmoT tbowmo
                        @alexsh1
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @tbowmo Any luck please?
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @alexsh1
                          Sorry, didn't have access to my hardware lab, so got thrown off by other projects.
                          The upcoming weekend will probably go with looking at old nasty php code, fixing issues in a 7 year old project I made for a former employer..
                          / Thomas
