  2. Announcements
  3. ๐Ÿ’ฌ Battery Powered Sensors
battery
347 Posts 55 Posters 226.6k Views 53 Watching
  • F FatBeard
    @sundberg84 @gohan. Apologies , that's a typo on my part. It jumps to 1ma do 60ms from 6ua. Which I'm happy with I think. My question was more how I can measure it properly. The multimeter seems to be effecting the circuit.
    @FatBeard actually what you really need to measure is the sleep current as it is the state where the node will be spending all of its time. Where are you connecting the multimeter for measuring current?
    F 1 Reply Last reply
      F
      F
      FatBeard
      @gohan between positive end of one of the two aa batteries and where it enters circuit. If I start off by having battery connected, the release it slowly with the multimeter attached and without breaking circuit I get my 6ua. However after the timer runs out and the radio comes back on I'm stuck at 1ma. The radio at that point doesn't want to work and it doesn't return to 6ua
      • F FatBeard
        @FatBeard the burden voltage of your multimeter might be too large, which would reduce the voltage to the atmega below its working level.
        You're measuring current, so the meter must be in series with the power supply. It's not clear to me how you can remove the multimeter without breaking power to the atmega.
          You could try to add a booster to power the Arduino or change the multimeter ๐Ÿ˜€
            sineverba
            Hi to all!
            I have a issue reading of voltage on pin A0 of an ATMEGA 328 barebone mounted on a breadboard.
            This is the image
            The purple pin goes to A0.
            The rail on the bottom coming direct from batteries, with a multimeter I read that they have 2.73V. On monitor serial, % of battery is about 1-2% and voltage reading is about... 0.004 and floating about 0.004 - 0.010 ....
            Can I imagine an issue with pin A0 itself? I have about 10 Atmega spares :) and I will test another one... but thinking about this issue.
            I did try also removing the 0.1uF cap, without any change.
            The reading function is the same of this sketch.
            Thank you very much!
            • I
              I
              iahim67
              Hi guys, if your Arduino is equipped with an ATMega 328P then it could go down to 1.8V at lower frequencies like 1MHz (8MHz internal RC oscillator / 8 by default).
              Or you can use the internal low power 128KHz RC osc eventually ...
              It means you could power both the Arduino and the radio directly from the battery string and consume even less current.
              Just wondering if anyone tried these cases so far?
                There have been some users that went that way but personally I am preferring to use a single AA LiFePo4 battery with standard voltages and clocks
                  MagnusF
                  I am a newbie and have some thoughts about the battery level that I did not find in this forum.
                  The 8MHz 3.3V Arduino Pro Mini can handle down to roughly 2.8V.
                  If I have understood the calculations in the sketch correctly then the analog value of A0 is 1023 at 3.44V and 0 at 0V.
                  This means that at 2.8V the value is about 830 = 83% and under this, the Arduino stops working. Is this right?
                  If this is correct, I wonder if someone has changed the calculation in the sketch so that the battery percentage becomes 0 at 2.8V?
                  This would mean that the battery percentage becomes a more real value on the battery level.
                    It's a simple percentage calculation that you can do it in the code
                      MagnusF
                      @gohan Thanks for your reply, you can show me how the code should look.
                          delay(500);
                          // Battery monitoring reading
                          delay(500);
                          // Calculate the battery in %
                          float Vbat = sensorValue * VBAT_PER_BITS;
                          send(msgVBat.set(Vbat, 3));
                          int batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN))*100.);
                          if (batLoop > 2) {
                            if (batteryPcnt > 100) {
                              batteryPcnt = 100;
                            batLoop = 0;
                            batLoop++;
                        This is the function I use, I just define the VMAX and VMIN in the beginning of sketch. The function calculates an average of 3 measurements before sending the value
                            delay(500);
                            delay(500);
                            if (batLoop > 2) {
                                batteryPcnt = 100;
                              batLoop = 0;
                              batLoop++;
                          tonnerre33T
                          tonnerre33T
                          tonnerre33
                          @gohan said in ๐Ÿ’ฌ Battery Powered Sensors:
                          Hello, i didn't know why you add 4 measures (batarray) and you divide by 3 the sum .
                          • tonnerre33T tonnerre33
                            @tonnerre33 good catch! maybe it's an optimistic value :)
                              I actually didn't look much at battery percentage, but I prefer looking at the voltage that gives me a better idea of how the battery is doing since I can log the values on a graph
                              • M MagnusF
                                rozpruwaczR
                                rozpruwaczR
                                rozpruwacz
                                @magnusf It is important to know that the battery voltage is non linear in respect to how much juice left. Just search for "battery discharge curve" to see how much it depends on battery type, current and temperature. So calculating the percentage is actually meaningless unless You exactly know how much current your board sucks at what temperature and what type of battery You use.
                                • I
                                  I
                                  Inso
                                  Instead of using "DC-DC Step Up Boost Module 5V" for a HBS, wouldnยดt it make sense to just use 2 AA batteries for the nano and 2 additional batteries (i.e. four in a row) for the HBS?
                                    What's the hbs?
                                    • I
                                      I
                                      Inso
                                      Same as on the motion example - HC-SR501, 4.5V- 12V.
                                      • I
                                        I
                                        Inso
                                        Maybe only a third Battery, as the HBS only needs 4.5V..
                                        • I
                                          I
                                          Inso
                                          To answer my own question: yes, it seems to work. Searched around and read a while, found this:
                                          https://forum.mysensors.org/topic/6511/hc-sr501-3-3v-randomly-sends-tripped-when-radio-is-on/22
                                          Best addition imho ,no need for step up / down. :D
                                          With your input, this post could be even better ๐Ÿ’—
