  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    #374
    How many microsteps are being used, anyway? I'm not sure where that's defined. Apparently these drivers support up 1/16 steps, but it might be that larger steps are actually being used (?). If so, then maybe going to smaller steps would help?
    I notice one of the Pololu boards has the potential for doing 1/32 steps: https://www.pololu.com/product/2133
    and might even be drop-in compatible.
    andrewA 1 Reply Last reply
      andrewA
      andrewA
      andrew
      wrote on last edited by andrew
      #375
      How many microsteps are being used, anyway? I'm not sure where that's defined. Apparently these drivers support up 1/16 steps, but it might be that fewer are actually being used (?). If so, then maybe going to smaller steps would help?
      this cnc controller board is directly pulls the drivers' MS1,2,3 pins to high, which means that it is "hardcoded" to 1/16 microstep. you really don't need smoother steps than this.
        @andrew Great that you're back. Did you alter your max speed and max acceleration values at all from the defaults? You didn't list them in your earlier list of magic numbers.
          andrewA
          andrewA
          andrew
          @neverdie I still use my default settings (see below). I re-applied these settings after I flashed the board to grbl 1.1f.
          $0=10 (step pulse, usec)
          $1=25 (step idle delay, msec)
          $6=0 (probe pin invert, bool)
          $12=0.002 (arc tolerance, mm)
          $13=0 (report inches, bool)
          $20=0 (soft limits, bool)
          $21=0 (hard limits, bool)
          $22=0 (homing cycle, bool)
          $100=800.000 (x, step/mm)
          $101=800.000 (y, step/mm)
          $102=800.000 (z, step/mm)
          • andrewA andrew
            #378
            Looks like the only difference is that your default max rates for x and y were 800, whereas mine were 5000, and your max rate for z was 500, whereas my default was 800 before I cut it by 50% to 400.
            In the interest of minimizing differences, I'll adopt your defaults instead.
            • andrewA andrew
              @andrew Are you planning to provide more detail about how to setup and do double sided PCBs, or is it pretty much RTFM at this point? Just wondering. Your earlier posts were very thorough and helped a lot.
              did you manage to create double sided PCB jobs in the meantime based on my suggestion and on flatcam's documentation? it is not a hardcore process, let me know if you stuck at a given step.
              regarding to the mentioned upgrades. I agree with @executivul, it doesn't worth to do that with this machine. feedback from steppers, elevation measuring etc are overkill.
              it's capabilities are more than enough for very precise pcb milling, if you would like to do much more with it, then a different machine could be better instead. if you have issues with the results, then it is configuration / settings / cnc job issue. if you loose steps, then the given stepper driver is not properly adjusted (did you checked the pololu driver configuration from the linked documentation?) or your tool/spindle speed/cutting depth/feed rate is not good for the given job.
              Not sure what kind of pins to use for the alignment.
                Even after all this tweaking, the z-axis was off by 0.048mm after the latest set of probing.
                E andrewA 2 Replies Last reply
                  E
                  E
                  executivul
                  What do you mean by "off"? Afaik grbl doesn't have a M48 equivalent command for probe/machine repeatability... So it can't probe the same place automatically. You have to write your own code for that, based on G32.2 command, take a few measurements and see the difference.
                  If you mean across the whole board, depending on the size of the measured area that's not bad at all.
                    andrewA
                    andrewA
                    andrew
                    @neverdie could you please explain how did you find/measure this? also please let me know the details of the executed job, including the G code generation properties/settings (e.g. feed rate, depth, multiple passes etc.) used in flatcam.
                    • andrewA andrew
                      #383
                      1. Decided upon an origen. Used Chilipeppr to "run test probe" to find the zero z-height. Zeroed x,y,z at that location.
                      2. Did an autolevel, at 1mm spacing, over a 20x10mm area.
                      3. Following this, returned to x=0, y=0. Ran another test probe. Ideally it would have come back as z=0. Instead, it came back as z=-0.048.
                      So, if at that point I were to actually run g-code with a cutting depth of z=-0.05, it would barely scratch the surface. Somehow during the 1mm autolevel probing, z became uncalibrated. If I were to re-zero z based on the second test probe, it would cut, but the cutting depth wouldn't be uniform.
                      Anyhow, my new rule is that if I come across a situation like the above, I throw out the auto-leveling and start over rather than executing the g-code. Often, the next autoleveling will have less discrepancy by step 3.
                      rmtuckerR andrewA 2 Replies Last reply
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        @neverdie
                        Maybe run step 1
                        Then run some g-code but above the job.(for a few mins).
                        Then run step 3.
                        This could be an autolevel problem.
                        • rmtuckerR rmtucker
                          @neverdie
                          Maybe run step 1
                          Then run step 3.
                          Maybe run step 1
                          Then run step 3.
                          How might that help?
                          rmtuckerR 1 Reply Last reply
                            Maybe run step 1
                            Then run step 3.
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            @neverdie
                            What if you have broken .048 off the end of the tool during autolevel?
                            So run some g-code above the job then re-probe so you know you have not twatted the tool.:relaxed:
                              @neverdie
                              #387
                              Good point. I'll have a closer look for that the next time it happens.
                              Also, I'll try repeating the test using a dull bit (which presumably won't break) and see whether it still happens or not.
                              • E
                                E
                                executivul
                                wrote on last edited by executivul
                                #388
                                @NeverDie grbl 1.1 probing command is G38.2 Z-10 F25 where Z tells it how low should go before erroring if it doesn't touch and F is the speed.
                                You should try manually issuig G38, then G92 Z0 to set new Z0 position and then finally G0 Z10 F100 to lift the probe, rinse and repeat without the G92, how repeatable is the reading, does it stay at 10.00?
                                Then do the air job, or some simple moving (G0 X5 Y5 Z5, G0 X0 Y0 Z10 a few times )and retest manually with G38
                                LE. The probing command is G38.2, I've edited the post to correct it.
                                  andrewA
                                  andrewA
                                  andrew
                                  if your probe speed is too fast, then it could push the pcb at the given points and also it could damage your tip's end, as it was mentioned by @rmtucker, which could cause this issue as well.
                                    andrewA
                                    andrewA
                                    andrew
                                    I missed this reply from you.
                                    so, you have to define the alignment holes, typically outside of the actual pcb area, in the "frame".
                                    you have to define two of them, the rest will be calculated automatically.
                                    the steps are exactly the same as that you can see on http://flatcam.org/manual/procedures.html#side-pcb
                                    see the pic below. note, that you don't have to write the coordinates to the input boxes manually, once you click on the design area the corresponding coordinates will be copied to the clipboard, so you can use ctrl-v to fill out the settings.
                                    • click on the picture to define the axis (X in this example)
                                    • copy the corresponding coordinates to the point/box input filed
                                    • click on the design area to define the exact location of the first alignment hole (left side of the actual pcb)
                                    • copy the corresponding coordinates to the alignment holes input filed
                                    • click on the design area to define the exact location of the first alignment hole (right side of the actual pcb)
                                    • copy the corresponding coordinates to the alignment holes input filed. the two set of coordinates have to be separated by coma.
                                    • configure the alignment holes' drill size
                                    • click on the create align drill button and you're done. back on the project tab you can find a new drill job which you have to further process to create the belonging G code from it.
                                    • andrewA andrew
                                      @andrew Are you using male header pins for your alignment? How deep are you drilling the holes them?
                                        andrewA
                                        andrewA
                                        andrew
                                        @neverdie yes, I use male pins, with 0.7mm drill (so it is tight for the pin), 5mm depth. but this is really up to you, choose anything which you have easy access to.
                                        • andrewA andrew
                                          @andrew
                                          With single sided PCB, I soldered the ground wire (for probing) to the copper cladding, just as the Chilipeppr author did. How are you handling it for two sided? If I do it that way for two sided, the solder bump may prevent the board laying flat on the wasteboard.
