  2. Bug Reports
  3. sendBatteryLevel: wrong nodeId?
nodeidmqttsendbatteryleve
5 Posts 3 Posters 3.8k Views 1 Watching
  • XanderX
    XanderX
    Xander
    Hi.
    My battery powerd sensor node is connected to OpenHAB via mqtt/ethernet gateway. The switch works well in OpenHAB. But not the battery level.
    For testing every time the switch changed a hardcoded value of "77" is send after the switch message.
    Log MQTT-Gateway:
    Started!
    0;0;3;0;9;read: 26-26-0 s=4,c=1,t=16,pt=2,l=2:0
    0;0;3;0;9;read: 26-26-0 s=255,c=3,t=0,pt=1,l=1:77
    0;0;3;0;9;read: 26-26-0 s=4,c=1,t=16,pt=2,l=2:1
    The PC-MQ-Client MQTT.fx also only shows the switch messages.
    The nodeId is 4. Why is there "255" in line 2 and 4? Or is this OK?
    • D
      diamantmatch
      bump
      I also wonder what the S, T, PT & L values stand for..
      i see them coming and going but never understood what they are here for ;)
      happy new year!
        s=child-sensor-id,
        c=message-type
        t=sub-type
        pt=payload-type (see MyMessage.h)
        l=payload length
        You will understand it better if you have a look at the code:
        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyMessage.h#L175
        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.cpp#L273
        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.cpp#L220
        XanderX 1 Reply Last reply
          s=child-sensor-id,
          c=message-type
          t=sub-type
          l=payload length
          XanderX
          XanderX
          Xander
          @hek
          Thanks for reply.
          I know the meaning of "s". But I was wondering about the value "255". Is this OK? I think it should be "4" - the value of "CHILD_ID" in my sketch.
            sensor id is not the same as node id.
            sensor id = 255 is used for internal stuff like id request and battery level for node. You can assign 0-254 to your own attached sensors (to the arduino node).
