  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
    I was just about to make a test board using my CNC when out of the blue my CNC died during setup. So, I did this board instead and will have it fabbed:
    Nca78N 1 Reply Last reply
      @neverdie for a test board why are you not using standard headers and mapping all pins available ?
      • Nca78N Nca78
        #1356
        @nca78 Because originally I was going to do the board on my CNC (that is, before my CNC dropped dead on me), and I wanted to make it as easy as possible for the CNC to succeed. Also, for testing purposes, I'm most interested in how well it sends/receives, and I don't need many pins to test that. Also, soldering this module may be tricky, so I wanted only the minimum number of pins in case soldering it proves to be difficult.
        • korttomaK
          korttomaK
          korttoma
          #1357
          Just received these tiny NRF51822 devices and would like to turn them in to MySensors 1 button scencontroller.
          Where should I start?
          1. I guess I will need some kind of USB adapter ti program them. Think I read somewhere about JLink. Would this do?
          • Tomas
          Nca78N T 2 Replies Last reply
          • korttomaK korttoma
            @korttoma did you check here ?
            https://forum.mysensors.org/topic/6705/mysensors-nrf5-platform
            For programming the best solution is probably the NRF52 DK, it's not very expensive (30€) and you avoid all the problems related to license of the fake JLINKs (and bricking of the device if you happen to accept the invitation to update the outdated firmware on it), as it includes official licence for programming all nrf5 chips.
            https://www.arrow.com/en/products/nrf52-dk/nordic-semiconductor
            • MiKaM
              MiKaM
              MiKa
              Working without problem with mysensors, I use STLink v2 from Aliexpress. LED and Button are mapped on pins 28 and 29 :)
              korttomaK MiKaM 2 Replies Last reply
              • MiKaM MiKa
                korttomaK
                korttomaK
                korttoma
                @mika :+1:
                Now I feel stupid ordering the NRF52 DK for 28€. Well atleast I don't need to worry about bricking any devices.
                Do you have an example sketch for the device you can share?
                Is it possible to somehow monitor the battery status?
                • Tomas
                  @mika :+1:
                  @korttoma said in nRF5 Bluetooth action!:
                  One of @d00616 's demo sketches allows you to read the voltage that's powering the nRF5. Assuming there is no booster involved on this device (seems unlikely), that would be the same as the battery voltage.
                    Toyman
                    @korttoma do you have an Aliexpress link to them?
                    korttomaK 1 Reply Last reply
                    • T Toyman
                      korttomaK
                      korttomaK
                      korttoma
                      @toyman sure do LINK
                      • Tomas
                      T korttomaK 2 Replies Last reply
                        Toyman
                        @korttoma thx. Do they have a CR2032 slot? Sorry, it's not clear from the pictures
                        • T Toyman
                          korttomaK
                          korttomaK
                          korttoma
                          @toyman yes
                          • Tomas
                            It would probably do well as a "one button scene controller," but is it good for anything else I wonder?
                              korttomaK
                              korttomaK
                              korttoma
                              @neverdie does not seem to be any easy way to get access to any of the pins on the board but who does not need a bunch of "one button scene controllers"?
                              • Tomas
                              • Nca78N
                                I was tempted to try adding the missing accelerometer too, but in the end it's easier and cheaper to make a board with the 2$ module.
                                  #1369
                                  Speaking of which, I shrunk the HolyIOT board a bit and added the small buzzer:
                                  Hopefully this is small enough that it can be used as a locator beacon.
                                  It turns out this is pretty nearly the minimum size, even if the HolyIOT were smaller, because of the CR2032 battery underneath it. Anyway, that's an interesting result, because the BC182 is smaller than the HolyIOT, but I wouldn't get the benefit of it.
                                    @neverdie said in nRF5 Bluetooth action!:
                                    small buzzer:
                                    CR2032 battery
                                    If I'm not wrong this buzzer needs over 100mA, not sure it's a good match for a CR2032 ?
                                    • MiKaM MiKa
                                      MiKaM
                                      MiKaM
                                      MiKa
                                      @mika said in nRF5 Bluetooth action!:
                                      Im just reporting sketch from NeverDie ;)
                                      https://www.openhardware.io/view/510/Multi-Sensor-TempHumidityPIR-LeakMagnetLightAccel
                                      • Nca78N Nca78
                                        small buzzer:
                                        CR2032 battery
                                        @nca78 said in nRF5 Bluetooth action!:
                                        small buzzer:
                                        CR2032 battery
                                        I like how nothing slips past you! Yes, it's a pretty severe trade-off in exchange for its small size. So, I'll be using two CR2032's and make it run only in very short bursts. I honestly don't know how well or badly it will turn out.
                                          small buzzer:
                                          CR2032 battery
                                          I don't see anything to co trim such a high current on your board ? Maybe it's the reason the sound level is low on your other board, max current of the MCU pin is much lower than what the buzzer needs ?
