  3. 💬 LoRa Ra-01 ATmega328P Node
15 Posts 6 Posters 6.1k Views 5 Watching
    Project completed. It works.
    It runs the RadioHead RH95 library and examples without any need for modification. :)
    • miljumeM
      miljumeM
      miljume
      Nice work! Any chance you can post some code samples to interact with MySensors gateway?
      • miljumeM miljume
        @miljume
        Not anytime soon. Probably better if someone else did.
        • pansenP
          pansenP
          pansen
          Out of curiousity: Why did you use a through-hole AVR and not a SMD one?
          Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
          • pansenP pansen
            @pansen
            Easier/faster to solder.
            pansenP 1 Reply Last reply
              @pansen
              pansenP
              pansenP
              pansen
              I understand but tend to disagree ;)
              • nitroburnN
                nitroburnN
                nitroburn
                any ideal value for the radio decoupling cap? It is the only thing I don't see listed.
                • nitroburnN nitroburn
                  @nitroburn said in 💬 LoRa Ra-01 ATmega328P Node:
                  I'm not sure that it's even needed. I added pads for it in case it might later prove necessary or beneficial, but for now it's optional (unless/until proven otherwise).
                  • giridhararmG
                    giridhararmG
                    giridhararm
                    Is it working ? How to upload sketch using FTDI right
                    • giridhararmG
                      giridhararmG
                      giridhararm
                      Is it working can I use FTDI to post rfm libraries
                      • giridhararmG giridhararm
                        @giridhararm yes
                          Starting with MySensors Release 2.1.1, it appears this module is now supported by MySensors:
                          "New transport layer: RFM95 (LoRa mode)"
