  3. Some help to port MySensors to PCDUINO?
pcduino
5 Posts 2 Posters 2.0k Views 1 Watching
  • M Offline
    M Offline
    msantang
    wrote on last edited by msantang
    Hi
    Im just planing to implement a home automation system using mysensors and I have a PCDuino3 that i want to use like gateway(serial) and controller.
    Someone could make MySensors works on PCDuino?
    • hekH Offline
      hekH Offline
      @msantang
      Are you talking about running the gateway on the PCDuino or just attaching a serial arduino-gateway to it?
      • M Offline
        M Offline
        msantang
        I want to run the gateway on the PCDuino. It's currently possible or need a complete rewrite?
        • hekH Offline
          hekH Offline
          wrote on last edited by hek
          A complete rewrite is probably not necessary. I suggest you have a look at the raspberry code.
          You might also want to check out id there are any RF24-library ports available.
          • M Offline
            M Offline
            msantang
            thank you! i will have a look to raspberry code.
