  3. Whole house power monitoring.
hardware sensor power
44 Posts 11 Posters 14.8k Views 11 Watching
    Of course there are, you could also make one out of an Arduino Uno one clamp an a small transformer, it depends if you want to go DIY or go with commercial product
      shabba
      DIY all the way! I assumed posting here would imply mysensors based but I guess I really should have been clear.
      • D
        dakipro
        Interested in the topic as well.
        Also, would it be possible get the power for arduino from the clamp itself, wirelessly? :D
        or you must have separate power source for arduino (I know this later is the case, but... you never know what smart people here can come up with)
        • rozpruwaczR
          rozpruwaczR
          rozpruwacz
          lately I discovered EnOcean. They produce energy harvesting sensors for home automation. E.g. a batteryless push button :) It harvests energy from button presses - how cool is that :D They also have other energy harvesting technologies, but I don't think they would provide enough power for arduino board that measures the current and voltage continuously ...
          gohanG 1 Reply Last reply
          • D
            dakipro
            quick google search gave me this https://electronics.stackexchange.com/questions/189425/leach-circuit-to-power-microcontroller
            • rozpruwaczR rozpruwacz
              @rozpruwacz Why would want energy harvesting on an energy meter that is actually measuring the mains? You can just use a power supply and you are fine. Anyway, if you want to go DIY look at openenergymonitor site on how to build the sensor
              D 1 Reply Last reply
              • rozpruwaczR
                rozpruwaczR
                rozpruwacz
                @gohan I don't know, I just pointed out that it may be possible ;)
                  I have looked at enocean stuff some time ago, and it works similarly to zwave but with energy harvesting in mind. Btw since I brought up zwave... https://aeotec.com/z-wave-home-energy-measure
                    shabba
                    All I am looking for really is a sensor/circuit that I can hook up to a mini and mysensors network.
                      https://openenergymonitor.org/forum-archive/node/58.html then you add the mysensors code for communication.
                      S 1 Reply Last reply
                        shabba
                        @gohan Thank you!
                          dakipro
                          @gohan said in Whole house power monitoring.:
                          I live in building where meter is in a common locker, thus no plugs nor power supplies.
                          • D dakipro
                            @dakipro then you should probably have a breaker box in the apartment, so you could put it there instead
                            Nca78N 1 Reply Last reply
                              That's a good idea but it's a bit tight in there :(
                              • Nca78N Nca78
                                @nca78 nobody said life is easy :sweat_smile:
                                • TmasterT
                                  TmasterT
                                  Tmaster
                                  I'm using an arduino pro mini with an W500 Ethernet module connected directly to router,and a clamp from ebay(100amps i think). arduino and w500 fits inside a small box and its inside main power box,clamped to the main wire from main eletric deferential . I have the (ATI) Telecomonication box at side of power box so its easy to connect to the router. i dont use transformer for volt read,just read Amps because my power its very stable at 230/235v and this is just for " power waste "control
                                  on first moth that i build it i saved 30€/moth in power(i not a commercial advertisement :P ).i had the electric resistance from water solar heating panel (3000w) working during the night,useless because we don't need hot water in morning,only at end of the day. so now i have another arduino that handle the hot water if there is no enough sun during the day... ( arduino pro minifor the win!!!:+1: )
                                  This is a screenshot from my emoncms page. like you see my wife its doing cakes and dinner,and the oven and induction plate eat a lot of power ![0_1515953751100_1.jpg
                                  i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                                    superczar
                                    +1 to that
                                    I have been using a single clamp sensor on my neutral at the power meter (SCT-030) hooked to an arduino/ESP8266
                                    It's been working great close to 3 years now with an accuracy of +- 7%
                                    I even use the readings to detect brown-outs and trigger devices to original state after power flips back to mains from the back-up (I live in an area where brown-outs , or power-cuts as we call them , are quite common)
                                    • K
                                      K
                                      kimot
                                      wrote on last edited by kimot
                                      +/-7% is good, because Domoticz has it own error -8% when energy consumption calculation is done by Domoticz.
                                      When I send 660 W constantly a few hours, I obtain energy consumption 604 - 609 Wh in this interval :o(
                                      They do not add last 5 min energy consumption in one hour interval ( Argument - because data arrived not at xx:00:00 but XX:00:05 )
                                      Look at Domoticz forum about this bug, if interested.
                                      Boys from Domoticz said - it is not important ....
                                      gohanG Nca78N 2 Replies Last reply
                                      • K kimot
                                        @kimot yeah, 5 minutes intervals are not the best for that kind of statistics; you'd probably better look at influxDB for more accurate statistics
                                        zboblamontZ K 2 Replies Last reply
                                        • K kimot
                                          @kimot thank you for that information. One more nail in Domoticz' coffin for me...
