  3. Arduino mini pro 3.3 battery optimization code
23 Posts 6 Posters 5.1k Views 5 Watching
  • sundberg84S sundberg84
    @tommas - have a look at the build section: https://www.mysensors.org/build/battery
    Tommas
    @sundberg84
    Oh ok. I have put this in the code, so it is OK, i think. I thought that SLEEP_TIME isnt equal to powerdown, but it seems that i misunderstood.
    I use your easypcb board Sundberg.... Is your battery measurement code better than this standard mysensors one?
    Thank You again!
      @tommas said in Arduino mini pro 3.3 battery optimization code:
      sleep(SLEEP_TIME);
      That is the power down command, usually it is put at the end of loop
      Tommas
      @gohan
      Dear Gohan!
      Thank you! I thought that it isnt equal with this: https://www.mysensors.org/download/sensor_api_20#sleeping ....
      But perhaps I misunderstood something because you says that it is the same sleep mode...
        SLEEP_TIME is defined as the amount of time the node will sleep, but it is the function sleep() that actually puts the node into low power mode and that usually is at the end of loop
        • T Tommas
          @sundberg84
          Thank You again!
          sundberg84S
          sundberg84S
          @tommas - "my" batterycode is due to a booster and a voltage divider. Its not possible to compare this to @Yveaux Vcc library which uses the internal vcc to measure battery level. This is not possible to use since you boost your VCC on the arduino. I think my code works great though for a voltage divider setup.
          G 1 Reply Last reply
          • T
            Tommas
            Hi All!
            Im near to get it work:) .
            Someone could write an example openhab2 thing and item for Battery Voltage handling?
            Thank you!
              G
              G
              ghiglie
              @sundberg84 said in Arduino mini pro 3.3 battery optimization code:
              Sorry, I'm revisiting a temp/hum sensor running on battery, I lost my code so I'm back to work with this (and signing/encryption, doh!)
              I think I have something similar to yours- I'm boosting the arduino and DHT voltage to 3,3v, while the antenna is directly connected. I have a voltage divider where I get the Voltage measure. Can I borrow directly your code, you think?
              atmega328p serial killer
              HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
              • G ghiglie
                sundberg84S
                sundberg84S
                @ghiglie - you can, as long as you have the same divider... (which is the standard divider found @ mysensors website.)
                // BATTERY MEASURER
                // VOLTAGE DIVIDER SETUP
                If not you need to recalculate,
                • T Tommas
                  Dear All!
                  I would like to use the Arduino Mini Pro 3.3 8Mhz (aTMega328) with 2xAA battery. I have read that it useful to put it in powerdown/sleep mode.
                  Could you help me what code/sketch should I use. I copied to here my beta sketch(It works, but it doesnt have the powerdown function)
                  If someone has any other suggestion related to the code, please write it!
                   * Version 1.0: Henrik EKblad
                   * sensor using a DHT11/DHT-22.
                  #define MY_NODE_ID 6
                  // Enable debug prints
                  //#define MY_RS485
                  by m26872, 20151109
                  #include <SI7021.h>
                  #include <RunningAverage.h>
                  #include <BH1750.h> //BH1750
                  #define DEBUG
                  #ifdef DEBUG
                  #define MOTION_DIGITAL_INPUT_SENSOR 3 //MOTION
                  #define NODE_ID 6             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                  #define CHILD_ID_TEMP 0
                  #define CHILD_ID_HUM 1
                  #define CHILD_ID_LIGHT 2 //BH1750
                  #define CHILD_ID_MOTION 3 /*MOTION*/
                  //BATTERY
                  uint32_t SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
                  int oldBatteryPcnt = 0;
                  //#define SLEEP_TIME 15000 // 15s for DEBUG
                  #define SLEEP_TIME 10000   // 5 min
                  //#define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                  #define FORCE_TRANSMIT_CYCLE 1  // 5min*12=1/hour, 5min*36=1/3hour
                  //#define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                  //#define VMIN 1900
                  //#define VMAX 3300
                  #define AVERAGES 2
                  //int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                  int measureCount = 0;
                  float lastTemperature = -100;
                  int lastHumidity = -100;
                  uint16_t lastlux; //BH1750
                  SI7021 humiditySensor;
                  BH1750 lightSensor;
                  //MySensor gw;
                  MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL); //BH1750
                  MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED); //MOTION
                  void presentation(){
                  sendSketchInfo("Node 6, Temp,Hum,Light,Motion", "1.1");
                    present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
                    present(CHILD_ID_HUM, S_HUM);
                    present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); //BH1750
                    present(CHILD_ID_MOTION, S_MOTION); /*MOTION*/
                  //BATTERY
                  sendSketchInfo("Battery Meter", "1.0");
                    //BATTERY
                      analogReference(INTERNAL1V1);
                      analogReference(INTERNAL);
                  //BATTERY
                    DEBUG_SERIAL(115200);
                    //DEBUG_PRINT("Voltage: ");
                    //DEBUG_PRINT(readVcc());
                    //DEBUG_PRINTLN(" mV");
                    delay(500);
                    DEBUG_PRINTLN(" *C");
                    //begin(NULL,NODE_ID);
                    //DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
                    raHum.clear();
                    lightSensor.begin(); //BH1750
                    /* MOTION */
                    pinMode(MOTION_DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
                    DEBUG_PRINTLN("Loop started");
                    measureCount ++;
                    bool forceTransmit = true;
                    //if (measureCount > FORCE_TRANSMIT_CYCLE) {
                    //forceTransmit = true;
                    sleep(SLEEP_TIME);
                    //BATTERY
                  // get the battery Voltage
                  #ifdef MY_DEBUG
                      Serial.println(sensorValue);
                  #ifdef MY_DEBUG
                      Serial.print(batteryV);
                      Serial.println(" V");
                      Serial.print(batteryPcnt);
                      Serial.println(" %");
                          // Power up radio after sleep
                          oldBatteryPcnt = batteryPcnt;
                    //BATTERY
                    //BH1750
                      Serial.println(lux);
                      DEBUG_PRINT("LUX: ");DEBUG_PRINTLN(lux);
                      if (lux != lastlux) {
                          send(msgLight.set(lux));
                          lastlux = lux; }
                    //BH1750
                    /* MOTION */
                    // Read digital motion value
                    bool tripped = digitalRead(MOTION_DIGITAL_INPUT_SENSOR) == HIGH;
                    Serial.println(tripped);
                    send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
                    DEBUG_PRINTLN("Loop ended");
                   * Parameters
                    bool tx = force;
                    DEBUG_PRINTLN("Send TEMP and HUM started");
                    float temperature = data.celsiusHundredths / 100.0;
                    //if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                    //lastTemperature = temperature;
                    //measureCount = 0;
                    DEBUG_PRINTLN("T sent!");
                    raHum.addValue(humidity);
                    //if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                    //lastHumidity = humidity;
                    //measureCount = 0;
                    DEBUG_PRINTLN("H sent!");
                  Thank you in advance!!
                  Tommas
                  @tommas
                  Dear All!
                  Can I use 2xAA 1.6V NiZn battery for 3.3V arduino mini pro?
                  NeverDieN gohanG 2 Replies Last reply
                  • T Tommas
                    @tommas
                    Dear All!
                    @tommas
                    Dear All!
                    Accoding to wikipedia, at 100% SOC each cell would deliver 1.85V, which is a smidge too high if running the pro mini with its voltage regulator removed. Well, actually, the pro mini would tolerate it, just maybe not the radio.
                    • T Tommas
                      @tommas
                      Dear All!
                      @tommas get some LiFePo4 AA and you can use a single cell
                        @tommas
                        Dear All!
                        Tommas
                        Dear @neverdie ,
                        Ok, so I wont use these batteries.
                        • T Tommas
                          Dear All!
                          //#define MY_RS485
                          by m26872, 20151109
                          #include <SI7021.h>
                          #define DEBUG
                          #ifdef DEBUG
                          //BATTERY
                          //#define VMIN 1900
                          //#define VMAX 3300
                          #define AVERAGES 2
                          BH1750 lightSensor;
                          //MySensor gw;
                          //BATTERY
                            //BATTERY
                          //BATTERY
                            delay(500);
                            raHum.clear();
                            /* MOTION */
                            measureCount ++;
                            sleep(SLEEP_TIME);
                            //BATTERY
                          #ifdef MY_DEBUG
                          #ifdef MY_DEBUG
                            //BATTERY
                            //BH1750
                                  lastlux = lux; }
                            //BH1750
                            /* MOTION */
                           * Parameters
                            bool tx = force;
                            //measureCount = 0;
                            //measureCount = 0;
                          Tommas
                          wrote on last edited by Tommas
                          @tommas
                          I did a new code, and it seems that it is do the job.
                          My goal was, that I only send the battery voltage (percent) when:
                          At least one of sensor value transmission occured + The battery report time is elapsed.
                          What do you think about my code? IT IS NOT ONLY MY CODE and it is not clear yet Thank for @gohan , @sundberg84 and mysensors for the base.
                          //#define MY_RS485
                          #include <SI7021.h>
                          #include <Math.h>
                          #define DEBUG
                          #ifdef DEBUG
                          #define CHILD_ID_VBAT 254
                          /*BATTERY*/
                          // BATTERY MEASURER
                          #define VMIN 2.1                                  //  Vmin (radio Min Volt)=1.9V (564v)
                          #define VMAX 3.1                                  //  Vmax = (2xAA bat)=3.0V (892v)
                          int battAveragePcnt;
                          int battSumPcnt = 0;
                          float VbatAverage=0;
                          float VbatSum=0;
                          /*BATTERY*/
                          //#define SLEEP_TIME 180000   // 3 min
                          //#define FORCE_TRANSMIT_CYCLE 10  // SLEEP_TIME*FORCE_TRANSMIT_CYCLE=Mindenképp küldi az értéket (Temp+HUM), különben akkor ha HUMI_TRANSMIT_THRESHOLD vagy TEMP_TRANSMIT_THRESHOLD igaz,
                          //#define BATT_MEASURE_CYCLE 10   // SLEEP_TIME/1000*BATTERY_Measure_CYCLE=Ennyi időnként Veszünk mintát (BATTERY)
                          //#define BATT_REPORT_CYCLE 15   // SLEEP_TIME/1000*BATTERY_REPORT_CYCLE=Ennyi időnként küldi az értéket (BATTERY)
                          #define SLEEP_TIME 300000   // 15sec
                          #define FORCE_TRANSMIT_CYCLE 24  // 30sec SLEEP_TIME*FORCE_TRANSMIT_CYCLE=Mindenképp küldi az értéket (Temp+HUM), különben akkor ha HUMI_TRANSMIT_THRESHOLD vagy TEMP_TRANSMIT_THRESHOLD igaz,
                          #define BATT_MEASURE_CYCLE 2   // Hányszor vegyünk mintát a küldés előtt
                          #define BATT_REPORT_CYCLE 60     // SLEEP_TIME/1000*BATTERY_REPORT_CYCLE*2=Ennyi időnként küldi az értéket (BATTERY)
                          #define LUX_TRANSMIT_THRESHOLD 10
                          #define AVERAGES 2
                          int battreportCount=-2;
                          int lastLux = 0; //BH1750
                          boolean transmission_occured = false;
                          BH1750 lightSensor;
                          //MySensor gw;
                          MyMessage msgVBat(CHILD_ID_VBAT, V_VOLTAGE); //BH1750
                          sendSketchInfo("Node 6, Temp,Hum,Light", "1.1");
                            present(CHILD_ID_VBAT, S_MULTIMETER); //BH1750
                            raHum.clear();
                            /*BATTERY*/
                            // BATTERY MEASURER
                            //Set internal ref to internal to be able to measure bat 0-1v
                            //Make sure this fits other sensors using analogRead()!
                            //If you have a sensor reporting 0-5v you need to change analogReference() before reading that sensor.
                            //DEFAULT: the default analog reference of 5 volts (on 5V Arduino boards) or 3.3 volts (on 3.3V Arduino boards)
                            //INTERNAL: an built-in reference, equal to 1.1 volts on the ATmega168 or ATmega328 and 2.56 volts on the ATmega8 (not available on the Arduino Mega)
                            //EXTERNAL: the voltage applied to the AREF pin (0 to 5V only) is used as the reference.
                            //Battery inital calc
                            Serial.print("With Battery VMax (100%) = "); Serial.print(VMAX); Serial.print("volts and Vmin (0%) = "); Serial.print(VMIN); Serial.println(" volts");
                            Serial.print("Battert Percent 25%/50%/75% should be: "); Serial.print(((VMAX - VMIN) / 4) + VMIN); Serial.print("/"); Serial.print(((VMAX - VMIN) / 2) + VMIN); Serial.print("/"); Serial.println(VMAX - ((VMAX - VMIN) / 4));
                            delay(500);
                            delay(50);
                            int batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN)) * 100.);
                            Serial.print("Current battery are measured to (please confirm!): "); Serial.print(batteryPcnt); Serial.print(" % - Or "); Serial.print(Vbat); Serial.println(" Volts");
                            /*BATTERY*/
                            boolean forceTransmit = false;
                            battreportCount ++;
                            measureCount ++;
                            if (measureCount == FORCE_TRANSMIT_CYCLE) {
                            measureCount = 0;
                            sendLightMeasurements(forceTransmit);
                            Serial.print("battreportCount");Serial.println(battreportCount);
                              /*BATTERY*/
                              // BATTERY MEASURER
                              if(((transmission_occured) && (battreportCount>=BATT_REPORT_CYCLE)) || (battreportCount == -1)){
                                      Serial.print("----BATTERY SEND/Measure CYCLE---- ");
                                      MeasureBattery();
                                      send(msgVBat.set(VbatAverage, 3));
                                      sendBatteryLevel(battAveragePcnt);
                                      Serial.print("Battery Average (Send): "); Serial.print(battAveragePcnt); Serial.println(" %");
                                      Serial.print("Battery Average Voltage (Send): "); Serial.print(VbatAverage); Serial.println(" V");
                                      battreportCount=0;
                                      battAveragePcnt=0;
                                      VbatAverage=0;
                                      VbatSum=0;
                                      battSumPcnt=0;
                                      measureCount=0;
                            /*BATTERY*/
                            sleep(SLEEP_TIME);
                           * Parameters
                            bool tx = force;
                              DEBUG_PRINTLN("TEMP sent!");
                              transmission_occured = true;
                              DEBUG_PRINTLN("HUM sent!");
                          //BH1750
                          void sendLightMeasurements(bool force){
                              bool tx = force;
                              int lux = lightSensor.readLightLevel();// Get Lux value
                              float diffLux = abs(lastLux - lux);
                              //Serial.println(lux);
                              DEBUG_PRINT("LuxDiff: ");DEBUG_PRINTLN(diffLux);
                              if (diffLux > LUX_TRANSMIT_THRESHOLD || tx) {
                                lastLux = lux;
                                DEBUG_PRINTLN("LUX sent!");
                          //BH1750
                          /*BATTERY*/
                          // BATTERY MEASURER
                          void MeasureBattery() //The battery calculations
                           if (batteryPcnt > 100) {
                               batteryPcnt = 100;
                                for (int i = 1 ; i <= BATT_MEASURE_CYCLE; i++)
                                  delay(500);
                                  // Battery monitoring reading
                                  delay(500);
                                  // Calculate the battery in %
                                  Serial.print("I: ");Serial.println(i);
                                  Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.print(" %"); Serial.print("Battery Voltage: "); Serial.print(Vbat); Serial.println(" Volts");
                                  battSumPcnt += batteryPcnt;
                                  Serial.print("battSumPcnt:::");Serial.println(battSumPcnt);
                                  battAveragePcnt = battSumPcnt / i;
                                  VbatSum += Vbat;
                                  VbatAverage = VbatSum / i;
                                  Serial.print("battAveragePcnt Calculated: ");Serial.println(battAveragePcnt);
                          /*BATTERY*/
                          • T Tommas
                            @tommas
                            //#define MY_RS485
                            #include <SI7021.h>
                            #include <Math.h>
                            #define DEBUG
                            #ifdef DEBUG
                            /*BATTERY*/
                            // BATTERY MEASURER
                            float VbatSum=0;
                            /*BATTERY*/
                            #define AVERAGES 2
                            BH1750 lightSensor;
                            //MySensor gw;
                              raHum.clear();
                              /*BATTERY*/
                              // BATTERY MEASURER
                              delay(500);
                              delay(50);
                              /*BATTERY*/
                              battreportCount ++;
                              measureCount ++;
                              measureCount = 0;
                                /*BATTERY*/
                                // BATTERY MEASURER
                                        MeasureBattery();
                                        battreportCount=0;
                                        battAveragePcnt=0;
                                        VbatAverage=0;
                                        VbatSum=0;
                                        battSumPcnt=0;
                                        measureCount=0;
                              /*BATTERY*/
                              sleep(SLEEP_TIME);
                             * Parameters
                              bool tx = force;
                            //BH1750
                                bool tx = force;
                                  lastLux = lux;
                            //BH1750
                            /*BATTERY*/
                            // BATTERY MEASURER
                                 batteryPcnt = 100;
                                    delay(500);
                                    delay(500);
                                    VbatSum += Vbat;
                            /*BATTERY*/
                            Tommas
                            @tommas
                            Should I use any other sleep "code"? How I know that the nrf24L01 go to sleep?
                            gohanG 1 Reply Last reply
                              Tommas
                              @gohan said in Arduino mini pro 3.3 battery optimization code:
                              LiFePo4 AA
                              THank You! I will try!
                              • T Tommas
                                @tommas
                                @tommas
                                If you measure current while the node is sleeping, if it is in the range 6 to 20 uA you are good
                                  Tommas
                                  loop
                                  What kind of sleep is it? There are parameters out there. ADC_OFF and some and some... Is this sleep turn off adc?
                                    Just use the sleep () function, that's it
                                      Tommas
                                      @gohan
                                      Ok! After the "loop ended " the node should go to sleep. On the console I see these lines:
                                      Loop ended
                                      62763 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                      62773 MCO:SLP:TPD
                                      What does it mean?
                                      • korttomaK
                                        korttomaK
                                        korttoma
                                        #22
                                        @gohan
                                        Loop ended
                                        62773 MCO:SLP:TPD
                                        What does it mean?
                                        Log Parser is your friend ;)
                                        • Tomas
                                        • korttomaK korttoma
                                          @gohan
                                          Loop ended
                                          62773 MCO:SLP:TPD
                                          What does it mean?
                                          Tommas
                                          @korttoma
                                          Thank you very much, and sorry....
