  3. Arduino mini pro 3.3 battery optimization code
23 Posts 6 Posters 5.1k Views 5 Watching
    SLEEP_TIME is defined as the amount of time the node will sleep, but it is the function sleep() that actually puts the node into low power mode and that usually is at the end of loop
    • T Tommas
      @sundberg84
      Oh ok. I have put this in the code, so it is OK, i think. I thought that SLEEP_TIME isnt equal to powerdown, but it seems that i misunderstood.
      I use your easypcb board Sundberg.... Is your battery measurement code better than this standard mysensors one?
      Thank You again!
      sundberg84S
      sundberg84S
      @tommas - "my" batterycode is due to a booster and a voltage divider. Its not possible to compare this to @Yveaux Vcc library which uses the internal vcc to measure battery level. This is not possible to use since you boost your VCC on the arduino. I think my code works great though for a voltage divider setup.
      G 1 Reply Last reply
      • T
        Tommas
        Hi All!
        Im near to get it work:) .
        Someone could write an example openhab2 thing and item for Battery Voltage handling?
        Thank you!
        • sundberg84S sundberg84
          G
          G
          ghiglie
          @sundberg84 said in Arduino mini pro 3.3 battery optimization code:
          Sorry, I'm revisiting a temp/hum sensor running on battery, I lost my code so I'm back to work with this (and signing/encryption, doh!)
          I think I have something similar to yours- I'm boosting the arduino and DHT voltage to 3,3v, while the antenna is directly connected. I have a voltage divider where I get the Voltage measure. Can I borrow directly your code, you think?
          atmega328p serial killer
          HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
          • G ghiglie
            sundberg84S
            sundberg84S
            @ghiglie - you can, as long as you have the same divider... (which is the standard divider found @ mysensors website.)
            // BATTERY MEASURER
            // VOLTAGE DIVIDER SETUP
            If not you need to recalculate,
            • T Tommas
              Dear All!
              I would like to use the Arduino Mini Pro 3.3 8Mhz (aTMega328) with 2xAA battery. I have read that it useful to put it in powerdown/sleep mode.
              Could you help me what code/sketch should I use. I copied to here my beta sketch(It works, but it doesnt have the powerdown function)
              If someone has any other suggestion related to the code, please write it!
               * Version 1.0: Henrik EKblad
               * sensor using a DHT11/DHT-22.
              #define MY_NODE_ID 6
              // Enable debug prints
              //#define MY_RS485
              by m26872, 20151109
              #include <SI7021.h>
              #include <RunningAverage.h>
              #include <BH1750.h> //BH1750
              #define DEBUG
              #ifdef DEBUG
              #define MOTION_DIGITAL_INPUT_SENSOR 3 //MOTION
              #define NODE_ID 6             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
              #define CHILD_ID_TEMP 0
              #define CHILD_ID_HUM 1
              #define CHILD_ID_LIGHT 2 //BH1750
              #define CHILD_ID_MOTION 3 /*MOTION*/
              //BATTERY
              uint32_t SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
              int oldBatteryPcnt = 0;
              //#define SLEEP_TIME 15000 // 15s for DEBUG
              #define SLEEP_TIME 10000   // 5 min
              //#define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
              #define FORCE_TRANSMIT_CYCLE 1  // 5min*12=1/hour, 5min*36=1/3hour
              //#define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
              //#define VMIN 1900
              //#define VMAX 3300
              #define AVERAGES 2
              //int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
              int measureCount = 0;
              float lastTemperature = -100;
              int lastHumidity = -100;
              uint16_t lastlux; //BH1750
              SI7021 humiditySensor;
              BH1750 lightSensor;
              //MySensor gw;
              MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL); //BH1750
              MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED); //MOTION
              void presentation(){
              sendSketchInfo("Node 6, Temp,Hum,Light,Motion", "1.1");
                present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
                present(CHILD_ID_HUM, S_HUM);
                present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); //BH1750
                present(CHILD_ID_MOTION, S_MOTION); /*MOTION*/
              //BATTERY
              sendSketchInfo("Battery Meter", "1.0");
                //BATTERY
                  analogReference(INTERNAL1V1);
                  analogReference(INTERNAL);
              //BATTERY
                DEBUG_SERIAL(115200);
                //DEBUG_PRINT("Voltage: ");
                //DEBUG_PRINT(readVcc());
                //DEBUG_PRINTLN(" mV");
                delay(500);
                DEBUG_PRINTLN(" *C");
                //begin(NULL,NODE_ID);
                //DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
                raHum.clear();
                lightSensor.begin(); //BH1750
                /* MOTION */
                pinMode(MOTION_DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
                DEBUG_PRINTLN("Loop started");
                measureCount ++;
                bool forceTransmit = true;
                //if (measureCount > FORCE_TRANSMIT_CYCLE) {
                //forceTransmit = true;
                sleep(SLEEP_TIME);
                //BATTERY
              // get the battery Voltage
              #ifdef MY_DEBUG
                  Serial.println(sensorValue);
              #ifdef MY_DEBUG
                  Serial.print(batteryV);
                  Serial.println(" V");
                  Serial.print(batteryPcnt);
                  Serial.println(" %");
                      // Power up radio after sleep
                      oldBatteryPcnt = batteryPcnt;
                //BATTERY
                //BH1750
                  Serial.println(lux);
                  DEBUG_PRINT("LUX: ");DEBUG_PRINTLN(lux);
                  if (lux != lastlux) {
                      send(msgLight.set(lux));
                      lastlux = lux; }
                //BH1750
                /* MOTION */
                // Read digital motion value
                bool tripped = digitalRead(MOTION_DIGITAL_INPUT_SENSOR) == HIGH;
                Serial.println(tripped);
                send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
                DEBUG_PRINTLN("Loop ended");
               * Parameters
                bool tx = force;
                DEBUG_PRINTLN("Send TEMP and HUM started");
                float temperature = data.celsiusHundredths / 100.0;
                //if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                //lastTemperature = temperature;
                //measureCount = 0;
                DEBUG_PRINTLN("T sent!");
                raHum.addValue(humidity);
                //if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                //lastHumidity = humidity;
                //measureCount = 0;
                DEBUG_PRINTLN("H sent!");
              Thank you in advance!!
              Tommas
              @tommas
              Dear All!
              Can I use 2xAA 1.6V NiZn battery for 3.3V arduino mini pro?
              NeverDieN gohanG 2 Replies Last reply
              • T Tommas
                @tommas
                Dear All!
                @tommas said in Arduino mini pro 3.3 battery optimization code:
                @tommas
                Dear All!
                Accoding to wikipedia, at 100% SOC each cell would deliver 1.85V, which is a smidge too high if running the pro mini with its voltage regulator removed. Well, actually, the pro mini would tolerate it, just maybe not the radio.
                • T Tommas
                  @tommas
                  Dear All!
                  @tommas get some LiFePo4 AA and you can use a single cell
                    @tommas
                    Dear All!
                    Tommas
                    Dear @neverdie ,
                    Ok, so I wont use these batteries.
                    • T Tommas
                      Dear All!
                      //#define MY_RS485
                      by m26872, 20151109
                      #include <SI7021.h>
                      #define DEBUG
                      #ifdef DEBUG
                      //BATTERY
                      //#define VMIN 1900
                      //#define VMAX 3300
                      #define AVERAGES 2
                      BH1750 lightSensor;
                      //MySensor gw;
                      //BATTERY
                        //BATTERY
                      //BATTERY
                        delay(500);
                        raHum.clear();
                        /* MOTION */
                        measureCount ++;
                        sleep(SLEEP_TIME);
                        //BATTERY
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                        //BATTERY
                        //BH1750
                              lastlux = lux; }
                        //BH1750
                        /* MOTION */
                       * Parameters
                        bool tx = force;
                        //measureCount = 0;
                        //measureCount = 0;
                      Tommas
                      wrote on last edited by Tommas
                      @tommas
                      I did a new code, and it seems that it is do the job.
                      My goal was, that I only send the battery voltage (percent) when:
                      At least one of sensor value transmission occured + The battery report time is elapsed.
                      What do you think about my code? IT IS NOT ONLY MY CODE and it is not clear yet Thank for @gohan , @sundberg84 and mysensors for the base.
                      //#define MY_RS485
                      #include <SI7021.h>
                      #include <Math.h>
                      #define DEBUG
                      #ifdef DEBUG
                      #define CHILD_ID_VBAT 254
                      /*BATTERY*/
                      // BATTERY MEASURER
                      #define VMIN 2.1                                  //  Vmin (radio Min Volt)=1.9V (564v)
                      #define VMAX 3.1                                  //  Vmax = (2xAA bat)=3.0V (892v)
                      int battAveragePcnt;
                      int battSumPcnt = 0;
                      float VbatAverage=0;
                      float VbatSum=0;
                      /*BATTERY*/
                      //#define SLEEP_TIME 180000   // 3 min
                      //#define FORCE_TRANSMIT_CYCLE 10  // SLEEP_TIME*FORCE_TRANSMIT_CYCLE=Mindenképp küldi az értéket (Temp+HUM), különben akkor ha HUMI_TRANSMIT_THRESHOLD vagy TEMP_TRANSMIT_THRESHOLD igaz,
                      //#define BATT_MEASURE_CYCLE 10   // SLEEP_TIME/1000*BATTERY_Measure_CYCLE=Ennyi időnként Veszünk mintát (BATTERY)
                      //#define BATT_REPORT_CYCLE 15   // SLEEP_TIME/1000*BATTERY_REPORT_CYCLE=Ennyi időnként küldi az értéket (BATTERY)
                      #define SLEEP_TIME 300000   // 15sec
                      #define FORCE_TRANSMIT_CYCLE 24  // 30sec SLEEP_TIME*FORCE_TRANSMIT_CYCLE=Mindenképp küldi az értéket (Temp+HUM), különben akkor ha HUMI_TRANSMIT_THRESHOLD vagy TEMP_TRANSMIT_THRESHOLD igaz,
                      #define BATT_MEASURE_CYCLE 2   // Hányszor vegyünk mintát a küldés előtt
                      #define BATT_REPORT_CYCLE 60     // SLEEP_TIME/1000*BATTERY_REPORT_CYCLE*2=Ennyi időnként küldi az értéket (BATTERY)
                      #define LUX_TRANSMIT_THRESHOLD 10
                      #define AVERAGES 2
                      int battreportCount=-2;
                      int lastLux = 0; //BH1750
                      boolean transmission_occured = false;
                      BH1750 lightSensor;
                      //MySensor gw;
                      MyMessage msgVBat(CHILD_ID_VBAT, V_VOLTAGE); //BH1750
                      sendSketchInfo("Node 6, Temp,Hum,Light", "1.1");
                        present(CHILD_ID_VBAT, S_MULTIMETER); //BH1750
                        raHum.clear();
                        /*BATTERY*/
                        // BATTERY MEASURER
                        //Set internal ref to internal to be able to measure bat 0-1v
                        //Make sure this fits other sensors using analogRead()!
                        //If you have a sensor reporting 0-5v you need to change analogReference() before reading that sensor.
                        //DEFAULT: the default analog reference of 5 volts (on 5V Arduino boards) or 3.3 volts (on 3.3V Arduino boards)
                        //INTERNAL: an built-in reference, equal to 1.1 volts on the ATmega168 or ATmega328 and 2.56 volts on the ATmega8 (not available on the Arduino Mega)
                        //EXTERNAL: the voltage applied to the AREF pin (0 to 5V only) is used as the reference.
                        //Battery inital calc
                        Serial.print("With Battery VMax (100%) = "); Serial.print(VMAX); Serial.print("volts and Vmin (0%) = "); Serial.print(VMIN); Serial.println(" volts");
                        Serial.print("Battert Percent 25%/50%/75% should be: "); Serial.print(((VMAX - VMIN) / 4) + VMIN); Serial.print("/"); Serial.print(((VMAX - VMIN) / 2) + VMIN); Serial.print("/"); Serial.println(VMAX - ((VMAX - VMIN) / 4));
                        delay(500);
                        delay(50);
                        int batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN)) * 100.);
                        Serial.print("Current battery are measured to (please confirm!): "); Serial.print(batteryPcnt); Serial.print(" % - Or "); Serial.print(Vbat); Serial.println(" Volts");
                        /*BATTERY*/
                        boolean forceTransmit = false;
                        battreportCount ++;
                        measureCount ++;
                        if (measureCount == FORCE_TRANSMIT_CYCLE) {
                        measureCount = 0;
                        sendLightMeasurements(forceTransmit);
                        Serial.print("battreportCount");Serial.println(battreportCount);
                          /*BATTERY*/
                          // BATTERY MEASURER
                          if(((transmission_occured) && (battreportCount>=BATT_REPORT_CYCLE)) || (battreportCount == -1)){
                                  Serial.print("----BATTERY SEND/Measure CYCLE---- ");
                                  MeasureBattery();
                                  send(msgVBat.set(VbatAverage, 3));
                                  sendBatteryLevel(battAveragePcnt);
                                  Serial.print("Battery Average (Send): "); Serial.print(battAveragePcnt); Serial.println(" %");
                                  Serial.print("Battery Average Voltage (Send): "); Serial.print(VbatAverage); Serial.println(" V");
                                  battreportCount=0;
                                  battAveragePcnt=0;
                                  VbatAverage=0;
                                  VbatSum=0;
                                  battSumPcnt=0;
                                  measureCount=0;
                        /*BATTERY*/
                        sleep(SLEEP_TIME);
                       * Parameters
                        bool tx = force;
                          DEBUG_PRINTLN("TEMP sent!");
                          transmission_occured = true;
                          DEBUG_PRINTLN("HUM sent!");
                      //BH1750
                      void sendLightMeasurements(bool force){
                          bool tx = force;
                          int lux = lightSensor.readLightLevel();// Get Lux value
                          float diffLux = abs(lastLux - lux);
                          //Serial.println(lux);
                          DEBUG_PRINT("LuxDiff: ");DEBUG_PRINTLN(diffLux);
                          if (diffLux > LUX_TRANSMIT_THRESHOLD || tx) {
                            lastLux = lux;
                            DEBUG_PRINTLN("LUX sent!");
                      //BH1750
                      /*BATTERY*/
                      // BATTERY MEASURER
                      void MeasureBattery() //The battery calculations
                       if (batteryPcnt > 100) {
                           batteryPcnt = 100;
                            for (int i = 1 ; i <= BATT_MEASURE_CYCLE; i++)
                              delay(500);
                              // Battery monitoring reading
                              delay(500);
                              // Calculate the battery in %
                              Serial.print("I: ");Serial.println(i);
                              Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.print(" %"); Serial.print("Battery Voltage: "); Serial.print(Vbat); Serial.println(" Volts");
                              battSumPcnt += batteryPcnt;
                              Serial.print("battSumPcnt:::");Serial.println(battSumPcnt);
                              battAveragePcnt = battSumPcnt / i;
                              VbatSum += Vbat;
                              VbatAverage = VbatSum / i;
                              Serial.print("battAveragePcnt Calculated: ");Serial.println(battAveragePcnt);
                      /*BATTERY*/
                      • T Tommas
                        @tommas
                        //#define MY_RS485
                        #include <SI7021.h>
                        #include <Math.h>
                        #define DEBUG
                        #ifdef DEBUG
                        /*BATTERY*/
                        // BATTERY MEASURER
                        float VbatSum=0;
                        /*BATTERY*/
                        #define AVERAGES 2
                        BH1750 lightSensor;
                        //MySensor gw;
                          raHum.clear();
                          /*BATTERY*/
                          // BATTERY MEASURER
                          delay(500);
                          delay(50);
                          /*BATTERY*/
                          battreportCount ++;
                          measureCount ++;
                          measureCount = 0;
                            /*BATTERY*/
                            // BATTERY MEASURER
                                    MeasureBattery();
                                    battreportCount=0;
                                    battAveragePcnt=0;
                                    VbatAverage=0;
                                    VbatSum=0;
                                    battSumPcnt=0;
                                    measureCount=0;
                          /*BATTERY*/
                          sleep(SLEEP_TIME);
                         * Parameters
                          bool tx = force;
                        //BH1750
                            bool tx = force;
                              lastLux = lux;
                        //BH1750
                        /*BATTERY*/
                        // BATTERY MEASURER
                             batteryPcnt = 100;
                                delay(500);
                                delay(500);
                                VbatSum += Vbat;
                        /*BATTERY*/
                        Tommas
                        @tommas
                        Should I use any other sleep "code"? How I know that the nrf24L01 go to sleep?
                        gohanG 1 Reply Last reply
                          Tommas
                          @gohan said in Arduino mini pro 3.3 battery optimization code:
                          LiFePo4 AA
                          THank You! I will try!
                          • T Tommas
                            @tommas
                            @tommas
                            If you measure current while the node is sleeping, if it is in the range 6 to 20 uA you are good
                              Tommas
                              loop
                              What kind of sleep is it? There are parameters out there. ADC_OFF and some and some... Is this sleep turn off adc?
                                Just use the sleep () function, that's it
                                  Tommas
                                  @gohan
                                  Ok! After the "loop ended " the node should go to sleep. On the console I see these lines:
                                  Loop ended
                                  62763 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  62773 MCO:SLP:TPD
                                  What does it mean?
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    #22
                                    @gohan
                                    Loop ended
                                    62773 MCO:SLP:TPD
                                    What does it mean?
                                    Log Parser is your friend ;)
                                    • Tomas
                                    • korttomaK korttoma
                                      @gohan
                                      Loop ended
                                      62773 MCO:SLP:TPD
                                      What does it mean?
                                      Tommas
                                      @korttoma
                                      Thank you very much, and sorry....
