  3. Arduino mini pro 3.3 battery optimization code
23 Posts 6 Posters 5.1k Views 5 Watching
  • T Tommas
    @tommas
    Dear All!
    Can I use 2xAA 1.6V NiZn battery for 3.3V arduino mini pro?
    @tommas said in Arduino mini pro 3.3 battery optimization code:
    @tommas
    Dear All!
    Accoding to wikipedia, at 100% SOC each cell would deliver 1.85V, which is a smidge too high if running the pro mini with its voltage regulator removed. Well, actually, the pro mini would tolerate it, just maybe not the radio.
    • T Tommas
      @tommas
      Dear All!
      @tommas get some LiFePo4 AA and you can use a single cell
        @tommas
        Dear All!
        Tommas
        Dear @neverdie ,
        Ok, so I wont use these batteries.
        • T Tommas
          Dear All!
          I would like to use the Arduino Mini Pro 3.3 8Mhz (aTMega328) with 2xAA battery. I have read that it useful to put it in powerdown/sleep mode.
          Could you help me what code/sketch should I use. I copied to here my beta sketch(It works, but it doesnt have the powerdown function)
          If someone has any other suggestion related to the code, please write it!
           * Version 1.0: Henrik EKblad
           * sensor using a DHT11/DHT-22.
          #define MY_NODE_ID 6
          // Enable debug prints
          //#define MY_RS485
          by m26872, 20151109
          #include <SI7021.h>
          #include <RunningAverage.h>
          #include <BH1750.h> //BH1750
          #define DEBUG
          #ifdef DEBUG
          #define MOTION_DIGITAL_INPUT_SENSOR 3 //MOTION
          #define NODE_ID 6             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
          #define CHILD_ID_TEMP 0
          #define CHILD_ID_HUM 1
          #define CHILD_ID_LIGHT 2 //BH1750
          #define CHILD_ID_MOTION 3 /*MOTION*/
          //BATTERY
          uint32_t SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
          int oldBatteryPcnt = 0;
          //#define SLEEP_TIME 15000 // 15s for DEBUG
          #define SLEEP_TIME 10000   // 5 min
          //#define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
          #define FORCE_TRANSMIT_CYCLE 1  // 5min*12=1/hour, 5min*36=1/3hour
          //#define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
          //#define VMIN 1900
          //#define VMAX 3300
          #define AVERAGES 2
          //int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
          int measureCount = 0;
          float lastTemperature = -100;
          int lastHumidity = -100;
          uint16_t lastlux; //BH1750
          SI7021 humiditySensor;
          BH1750 lightSensor;
          //MySensor gw;
          MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL); //BH1750
          MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED); //MOTION
          void presentation(){
          sendSketchInfo("Node 6, Temp,Hum,Light,Motion", "1.1");
            present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
            present(CHILD_ID_HUM, S_HUM);
            present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); //BH1750
            present(CHILD_ID_MOTION, S_MOTION); /*MOTION*/
          //BATTERY
          sendSketchInfo("Battery Meter", "1.0");
            //BATTERY
              analogReference(INTERNAL1V1);
              analogReference(INTERNAL);
          //BATTERY
            DEBUG_SERIAL(115200);
            //DEBUG_PRINT("Voltage: ");
            //DEBUG_PRINT(readVcc());
            //DEBUG_PRINTLN(" mV");
            delay(500);
            DEBUG_PRINTLN(" *C");
            //begin(NULL,NODE_ID);
            //DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
            raHum.clear();
            lightSensor.begin(); //BH1750
            /* MOTION */
            pinMode(MOTION_DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
            DEBUG_PRINTLN("Loop started");
            measureCount ++;
            bool forceTransmit = true;
            //if (measureCount > FORCE_TRANSMIT_CYCLE) {
            //forceTransmit = true;
            sleep(SLEEP_TIME);
            //BATTERY
          // get the battery Voltage
          #ifdef MY_DEBUG
              Serial.println(sensorValue);
          #ifdef MY_DEBUG
              Serial.print(batteryV);
              Serial.println(" V");
              Serial.print(batteryPcnt);
              Serial.println(" %");
                  // Power up radio after sleep
                  oldBatteryPcnt = batteryPcnt;
            //BATTERY
            //BH1750
              Serial.println(lux);
              DEBUG_PRINT("LUX: ");DEBUG_PRINTLN(lux);
              if (lux != lastlux) {
                  send(msgLight.set(lux));
                  lastlux = lux; }
            //BH1750
            /* MOTION */
            // Read digital motion value
            bool tripped = digitalRead(MOTION_DIGITAL_INPUT_SENSOR) == HIGH;
            Serial.println(tripped);
            send(msgMotion.set(tripped?"1":"0"));  // Send tripped value to gw
            DEBUG_PRINTLN("Loop ended");
           * Parameters
            bool tx = force;
            DEBUG_PRINTLN("Send TEMP and HUM started");
            float temperature = data.celsiusHundredths / 100.0;
            //if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
            //lastTemperature = temperature;
            //measureCount = 0;
            DEBUG_PRINTLN("T sent!");
            raHum.addValue(humidity);
            //if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
            //lastHumidity = humidity;
            //measureCount = 0;
            DEBUG_PRINTLN("H sent!");
          Thank you in advance!!
          Tommas
          wrote on last edited by Tommas
          @tommas
          I did a new code, and it seems that it is do the job.
          My goal was, that I only send the battery voltage (percent) when:
          At least one of sensor value transmission occured + The battery report time is elapsed.
          What do you think about my code? IT IS NOT ONLY MY CODE and it is not clear yet Thank for @gohan , @sundberg84 and mysensors for the base.
          //#define MY_RS485
          #include <SI7021.h>
          #include <Math.h>
          #define DEBUG
          #ifdef DEBUG
          #define CHILD_ID_VBAT 254
          /*BATTERY*/
          // BATTERY MEASURER
          // VOLTAGE DIVIDER SETUP
          #define VMIN 2.1                                  //  Vmin (radio Min Volt)=1.9V (564v)
          #define VMAX 3.1                                  //  Vmax = (2xAA bat)=3.0V (892v)
          int battAveragePcnt;
          int battSumPcnt = 0;
          float VbatAverage=0;
          float VbatSum=0;
          /*BATTERY*/
          //#define SLEEP_TIME 180000   // 3 min
          //#define FORCE_TRANSMIT_CYCLE 10  // SLEEP_TIME*FORCE_TRANSMIT_CYCLE=Mindenképp küldi az értéket (Temp+HUM), különben akkor ha HUMI_TRANSMIT_THRESHOLD vagy TEMP_TRANSMIT_THRESHOLD igaz,
          //#define BATT_MEASURE_CYCLE 10   // SLEEP_TIME/1000*BATTERY_Measure_CYCLE=Ennyi időnként Veszünk mintát (BATTERY)
          //#define BATT_REPORT_CYCLE 15   // SLEEP_TIME/1000*BATTERY_REPORT_CYCLE=Ennyi időnként küldi az értéket (BATTERY)
          #define SLEEP_TIME 300000   // 15sec
          #define FORCE_TRANSMIT_CYCLE 24  // 30sec SLEEP_TIME*FORCE_TRANSMIT_CYCLE=Mindenképp küldi az értéket (Temp+HUM), különben akkor ha HUMI_TRANSMIT_THRESHOLD vagy TEMP_TRANSMIT_THRESHOLD igaz,
          #define BATT_MEASURE_CYCLE 2   // Hányszor vegyünk mintát a küldés előtt
          #define BATT_REPORT_CYCLE 60     // SLEEP_TIME/1000*BATTERY_REPORT_CYCLE*2=Ennyi időnként küldi az értéket (BATTERY)
          #define LUX_TRANSMIT_THRESHOLD 10
          #define AVERAGES 2
          int battreportCount=-2;
          int lastLux = 0; //BH1750
          boolean transmission_occured = false;
          BH1750 lightSensor;
          //MySensor gw;
          MyMessage msgVBat(CHILD_ID_VBAT, V_VOLTAGE); //BH1750
          sendSketchInfo("Node 6, Temp,Hum,Light", "1.1");
            present(CHILD_ID_VBAT, S_MULTIMETER); //BH1750
            raHum.clear();
            /*BATTERY*/
            // BATTERY MEASURER
            //Set internal ref to internal to be able to measure bat 0-1v
            //Make sure this fits other sensors using analogRead()!
            //If you have a sensor reporting 0-5v you need to change analogReference() before reading that sensor.
            //DEFAULT: the default analog reference of 5 volts (on 5V Arduino boards) or 3.3 volts (on 3.3V Arduino boards)
            //INTERNAL: an built-in reference, equal to 1.1 volts on the ATmega168 or ATmega328 and 2.56 volts on the ATmega8 (not available on the Arduino Mega)
            //EXTERNAL: the voltage applied to the AREF pin (0 to 5V only) is used as the reference.
            //Battery inital calc
            Serial.print("With Battery VMax (100%) = "); Serial.print(VMAX); Serial.print("volts and Vmin (0%) = "); Serial.print(VMIN); Serial.println(" volts");
            Serial.print("Battert Percent 25%/50%/75% should be: "); Serial.print(((VMAX - VMIN) / 4) + VMIN); Serial.print("/"); Serial.print(((VMAX - VMIN) / 2) + VMIN); Serial.print("/"); Serial.println(VMAX - ((VMAX - VMIN) / 4));
            delay(500);
            delay(50);
            int batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN)) * 100.);
            Serial.print("Current battery are measured to (please confirm!): "); Serial.print(batteryPcnt); Serial.print(" % - Or "); Serial.print(Vbat); Serial.println(" Volts");
            /*BATTERY*/
            boolean forceTransmit = false;
            battreportCount ++;
            measureCount ++;
            if (measureCount == FORCE_TRANSMIT_CYCLE) {
            measureCount = 0;
            sendLightMeasurements(forceTransmit);
            Serial.print("battreportCount");Serial.println(battreportCount);
              /*BATTERY*/
              // BATTERY MEASURER
              if(((transmission_occured) && (battreportCount>=BATT_REPORT_CYCLE)) || (battreportCount == -1)){
                      Serial.print("----BATTERY SEND/Measure CYCLE---- ");
                      MeasureBattery();
                      send(msgVBat.set(VbatAverage, 3));
                      sendBatteryLevel(battAveragePcnt);
                      Serial.print("Battery Average (Send): "); Serial.print(battAveragePcnt); Serial.println(" %");
                      Serial.print("Battery Average Voltage (Send): "); Serial.print(VbatAverage); Serial.println(" V");
                      battreportCount=0;
                      battAveragePcnt=0;
                      VbatAverage=0;
                      VbatSum=0;
                      battSumPcnt=0;
                      measureCount=0;
            /*BATTERY*/
            sleep(SLEEP_TIME);
           * Parameters
            bool tx = force;
              DEBUG_PRINTLN("TEMP sent!");
              transmission_occured = true;
              DEBUG_PRINTLN("HUM sent!");
          //BH1750
          void sendLightMeasurements(bool force){
              bool tx = force;
              int lux = lightSensor.readLightLevel();// Get Lux value
              float diffLux = abs(lastLux - lux);
              //Serial.println(lux);
              DEBUG_PRINT("LuxDiff: ");DEBUG_PRINTLN(diffLux);
              if (diffLux > LUX_TRANSMIT_THRESHOLD || tx) {
                lastLux = lux;
                DEBUG_PRINTLN("LUX sent!");
          //BH1750
          /*BATTERY*/
          // BATTERY MEASURER
          void MeasureBattery() //The battery calculations
           if (batteryPcnt > 100) {
               batteryPcnt = 100;
                for (int i = 1 ; i <= BATT_MEASURE_CYCLE; i++)
                  delay(500);
                  // Battery monitoring reading
                  delay(500);
                  // Calculate the battery in %
                  Serial.print("I: ");Serial.println(i);
                  Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.print(" %"); Serial.print("Battery Voltage: "); Serial.print(Vbat); Serial.println(" Volts");
                  battSumPcnt += batteryPcnt;
                  Serial.print("battSumPcnt:::");Serial.println(battSumPcnt);
                  battAveragePcnt = battSumPcnt / i;
                  VbatSum += Vbat;
                  VbatAverage = VbatSum / i;
                  Serial.print("battAveragePcnt Calculated: ");Serial.println(battAveragePcnt);
          /*BATTERY*/
          • T Tommas
            @tommas
            //#define MY_RS485
            #include <SI7021.h>
            #include <Math.h>
            #define DEBUG
            #ifdef DEBUG
            /*BATTERY*/
            // BATTERY MEASURER
            float VbatSum=0;
            /*BATTERY*/
            #define AVERAGES 2
            BH1750 lightSensor;
            //MySensor gw;
              raHum.clear();
              /*BATTERY*/
              // BATTERY MEASURER
              delay(500);
              delay(50);
              /*BATTERY*/
              battreportCount ++;
              measureCount ++;
              measureCount = 0;
                /*BATTERY*/
                // BATTERY MEASURER
                        MeasureBattery();
                        battreportCount=0;
                        battAveragePcnt=0;
                        VbatAverage=0;
                        VbatSum=0;
                        battSumPcnt=0;
                        measureCount=0;
              /*BATTERY*/
              sleep(SLEEP_TIME);
             * Parameters
              bool tx = force;
            //BH1750
                bool tx = force;
                  lastLux = lux;
            //BH1750
            /*BATTERY*/
            // BATTERY MEASURER
                 batteryPcnt = 100;
                    delay(500);
                    delay(500);
                    VbatSum += Vbat;
            /*BATTERY*/
            Tommas
            @tommas
            Should I use any other sleep "code"? How I know that the nrf24L01 go to sleep?
            gohanG 1 Reply Last reply
              Tommas
              @gohan said in Arduino mini pro 3.3 battery optimization code:
              LiFePo4 AA
              THank You! I will try!
              • T Tommas
                @tommas
                @tommas
                If you measure current while the node is sleeping, if it is in the range 6 to 20 uA you are good
                  SLEEP_TIME is defined as the amount of time the node will sleep, but it is the function sleep() that actually puts the node into low power mode and that usually is at the end of loop
                  Tommas
                  loop
                  What kind of sleep is it? There are parameters out there. ADC_OFF and some and some... Is this sleep turn off adc?
                    Just use the sleep () function, that's it
                      Tommas
                      @gohan
                      Ok! After the "loop ended " the node should go to sleep. On the console I see these lines:
                      Loop ended
                      62763 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
                      62773 MCO:SLP:TPD
                      What does it mean?
                      • korttomaK
                        korttomaK
                        korttoma
                        #22
                        @gohan
                        Loop ended
                        62773 MCO:SLP:TPD
                        What does it mean?
                        Log Parser is your friend ;)
                        • Tomas
                        • korttomaK korttoma
                          @gohan
                          Loop ended
                          62773 MCO:SLP:TPD
                          What does it mean?
                          Tommas
                          @korttoma
                          Thank you very much, and sorry....
