  3. Cannot run MySensors on RPI 3
32 Posts 9 Posters 6.2k Views 9 Watching
  • kkanedaaK kkanedaa
    @mickecarlsson said in Cannot run MySensors on RPI 3:
    Download the development version of MySensors and try that. I could not get MySensors to work on a RPI 3 with the 2.1.1 version.
    I will try with the dev version and let you guys know again.
    @gohan said in Cannot run MySensors on RPI 3:
    There is a note in the raspberry page to use development version. BTW, did you connect the 5v pin to the nrf24 module? It seems so from the picture and if it's the case, say bye-bye to it. Also the capacitor it is better to be closer to the radio module and not on the raspberry gpio
    Nope, it's connected to 3.3V. Regarding the capacitor, I had it first near the NRF24, but mfalkvidd told me to move it.
    But thank you for your inputs, guys. I'll try the dev version and hope it will work.
    @kkanedaa sorry for being unclear. I meant closer to the nrf24, not further away from it.
    • kkanedaaK
      kkanedaaK
      kkanedaa
      • kkanedaaK
        kkanedaaK
        kkanedaa
        Hey all,
        So I removed the stable version of MySensors and got the development version.
        Let me show you step by step what I did:
        sudo rm -r MySensors
        git clone https://github.com/mysensors/MySensors.git --branch development
        cd MySensors
        ./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=[MY-PI-IP] --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
        make
        sudo ./bin/mysgw -d
        [MY-PI-IP] has been changed to my RPI's IP.
        The output I got first is this:
        pi@rpi-lite:~/MySensors $ sudo ./bin/mysgw -d
        mysgw: Starting gateway...
        mysgw: Protocol version - 2.2.0-rc.2
        mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.2
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        mysgw: GWT:RMQ:MQTT RECONNECT
        mysgw: failed to connect
        mysgw: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
        mysgw: !TSF:MSG:LEN,0!=7
        then it started going non-stop repeating the following output:
        Now I have a problem with the gateway. Did I configure something wrong? Or did I forget a step?
        All help is very much appreciated :)
        • G
          G
          GRDL
          I struggled with RPi gateway for ages without success. The easiest solution by far is to run the gateway on arduino and interface it to RPI through a serial gateway. Its not a very elegant solution but works. I did some investigation and came to the conclusion that the problem with RPi gateway is to do with the low level library that communicates with the radio but never found a fix.
          kkanedaaK gohanG 2 Replies Last reply
          • G GRDL
            kkanedaaK
            kkanedaaK
            kkanedaa
            @grdl said in Cannot run MySensors on RPI 3:
            Hi, thanks for your answer.
            If you are telling me that you have had the same issues as me, I am willing to do your method. True, not an elegant solution but I just want it to get up and running...
            When you say "run the gateway on arduino and interface it to RPI through a serial gateway", do you mean you built a serial gateway as mentioned here: https://www.mysensors.org/build/serial_gateway and then with an USB cable you connect it directly to your RPI? Am I understanding this correct?
            If yes, could you please tell me which parameters you have used while building your MySensors on your RPI. Would this be correct:
            ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
            Did you leave the value for --my-serial-pty was shown above? Did you add any other parameters?
            Sorry for asking so many questions but I cannot fully grasp the concept of MySensors without MQTT.
            I appreciate your response and thank you in advance :)
            • R
              R
              reinhold
              I've been running the Ethernet gateway (port 5003) on my raspi without issues for several months now.
              @kkanedaa It looks like the development version finally works with your nrf module. Regarding the MQTT connection refused: Are you sure your MQTT broker does not need a username and password?
              kkanedaaK 1 Reply Last reply
              • G GRDL
                @grdl on rpi3 is running fine, I have 2 radio modules too
                • rozpruwaczR
                  rozpruwaczR
                  rozpruwacz
                  This weekend a had also issues with nrf24 on rpi3. I'm using openhabian image and it was all working ok. But my sd card got corrupted and i had to reinstall openhabian. So I downloaded the newest image burned and ran my setup script - which should give me running and restored setup of OpenHAB, MySensors and couple more. But mysensors didn't work ... I found that the mysgw was failing to initialise nrf module (!TSM:INIT:TSP FAIL) - wierd because even with the binary that was working in previous setup i got the same error ... same hardware only new software ... So I connected my oscilloscope to spi pins and to my amazement there was no life on MOSI pin ... I even try with python to send something trough SPI - the same result. Then I compiled the mysgw with BCM driver ... and it worked ! Even better, I recompiled again with SPIDEV driver AND STILL WORKED !!!
                  So @kkanedaa try to compile with BCM driver - maybe it will work, for me it did.
                  gohanG 1 Reply Last reply
                  • rozpruwaczR rozpruwacz
                    @rozpruwacz did you use mysensors 2.1 or 2.2?
                      rozpruwaczR
                      rozpruwaczR
                      rozpruwacz
                      @gohan I was trying both master and developement branches (I believe ...).
                      • rozpruwaczR
                        rozpruwaczR
                        rozpruwacz
                        @gohan I am sure that the old binary mysgw that was working before openhabian update and was not working after openhabian update was 2.1.
                          A lot of users reported 2.1 no longer working with the more recent raspian images, while development version is known to be working better.
                          • R reinhold
                            kkanedaaK
                            kkanedaaK
                            kkanedaa
                            Hello all,
                            Thank you for all the replies. It is very much appreciated :)
                            @reinhold said in Cannot run MySensors on RPI 3:
                            I am starting to think that I am misunderstanding the concept of MySensors. I thought that the RPI would handle both RF24 communication and MQTT. That is not correct...right?
                            And your Ethernet gateway, did you use an Arduino to make the gateway and connected it to your RPI, or is the RPi itself the gateway?
                            Can't I just install Mosquitto on my RPI and use it as a gateway? I'm really confused here.
                            All I did was add MySensors (dev) to a fresh install of Raspbian Stretch Lite.
                            Could you please tell me what exactly you did, I would appreciate it a lot.
                            @rozpruwacz Unfortunately I am still fairly new to this, and I do not know what you mean by BCM and SPIDEV... but my ultimate goal is what you are doing: using MySensors in combination with openHABian (but currently I am trying with MyController since it seems easier).
                            Anyways, I hope some of you guys can help me out setting up MySensors on RPI3 :)
                            Thanks again for all the replies.
                            • rozpruwaczR
                              rozpruwaczR
                              rozpruwacz
                              wrote on last edited by rozpruwacz
                              #28
                              @kkanedaa said in Cannot run MySensors on RPI 3:
                              to compile the gateway with BCM driver You need to add to ./configure invocation special option, I don't remember now how it is named ... run ./configure --help and find this option - look for spidev and bcm keywords.
                              and after that run make install :)
                              • kkanedaaK
                                kkanedaaK
                                kkanedaa
                                Hi all! Good news! I managed to make it work, finally :)
                                Here is what I did (for those who might face the same problem):
                                1. Fresh install of Raspbian Stretch Lite
                                2. Install Mosquitto MQTT
                                3. Install MySensors
                                ./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=[RPI-IP] --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
                                (Replace [RPI-IP] with your IP)
                                1. "make" then "sudo ./bin/mysgw -d"
                                I got the following output
                                pi@rpi-mycontroller:~/MySensors $ sudo ./bin/mysgw -d
                                mysgw: Config file /etc/mysensors.dat does not exist, creating new config file.
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: MCO:BGN:STP
                                mysgw: connected to 192.168.xx.166
                                mysgw: GWT:RMQ:MQTT CONNECTED
                                mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                                mysgw: Received SIGINT
                                1. Auto start service with "sudo systemctl enable mysgw.service"
                                Thank you for all your inputs, guys. Really really appreciated. I am looking forward playing with MySensors. Very excited :D
                                • rozpruwaczR
                                  rozpruwaczR
                                  rozpruwacz
                                  Install MySensors
                                  developement branch as 2.2.0-rc.2 suggests that.
                                  So you only added --my-transport=nrf24 to what You started with ? (which seems to be the default so it shouldn't matter ...)
                                    Install MySensors
                                    kkanedaaK
                                    kkanedaaK
                                    kkanedaa
                                    @rozpruwacz said in Cannot run MySensors on RPI 3:
                                    Yea, I'm confused too. But basically a fresh install of Raspbian did the trick..
                                      If you had failed mqtt connection it was most likely caused by mqtt broker non accepting anonymous connections
