  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.0k Views 31 Watching
  • TigroenotT
    TigroenotT
    Tigroenot
    Please help to debug:
    0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 !TSM:INIT:TSP FAIL
    14 TSM:FAIL:CNT=1
    16 TSM:FAIL:PDT
    LorenzoL 1 Reply Last reply
    • TigroenotT Tigroenot
      4 TSM:INIT
      4 TSF:WUR:MS=0
      14 TSM:FAIL:CNT=1
      16 TSM:FAIL:PDT
      LorenzoL
      LorenzoL
      Lorenzo
      @Tigroenot Hi,
      TSM Transmission
      TSP Transport
      PDT Power Down
      !TSM:INIT:TSP FAIL Error during Transport initialization (Radio)
      TSM:FAILURE Error on Transmition (of course, you have a radio error)
      TSM:FAILURE:PDT Radio in Power Down (due to the error)
      Check your radio cabling. If all ok add a capacitor on radio power pins
      • TigroenotT
        TigroenotT
        Tigroenot
        The radio is not wired, it's directly soldered as a chip. I use MySensors Stable Node by @Koresh, but the nrf chips I got from China are probably counterfeit or don't work at all :)
        • karlheinz2000K
          karlheinz2000K
          karlheinz2000
          After flasing a node with ISP (bootloader+sketch) the node will not start since the eeprom is emty (forgot to enable eeprom safe). Node needs to get a ID from controller, even if ID is defined in the sketch. After receiving a ID from controller the node starts and uses the ID from sketch.
          Any solution to overcome this?
          • karlheinz2000K karlheinz2000
            #68
            @karlheinz2000 that should not happen. Starting from empty eeprom is normal, that's what all nodes do the first time.
            Could you post debug output of the node and the gateway when it fails to use the defined id?
            Just to check: the id was defined before including MySensors.h right?
            • karlheinz2000K
              karlheinz2000K
              karlheinz2000
              Attached the log file from MYSC. After activating AUTO ID the node starts. No other GW active.
              No serial output during this time.
              Node ID is defined before including .h.
              Node is flashed via ISP (Dragon) with "...with_bootloader.hex".
              0_1483653188071_MySensors_20170105-223345.log
              tekkaT 1 Reply Last reply
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                #70
                @karlheinz2000 I'm not sure I understand you correctly:
                With a cleared EEPROM, the bootloader will not know any ID defined in the sketch. Instead, the bootloader will fetch a new ID from the controller and store it in EEPROM. Once the sketch starts it will either overtake this newly assigned ID (if MY_NODE_ID == AUTO) or overwrite and use a static ID (if MY_NODE_ID != AUTO) from now on. Does this answer your question?
                • karlheinz2000K
                  karlheinz2000K
                  karlheinz2000
                  Understood.
                  But if I'm not using MYSB, I can flash a sketch with defined ID and this will work instantly in the network.
                  With MYSB I always have to do assign a new ID just to get the node to run the first time after flashing.
                  Any chance to get MYSB to know, if a sketch is an flash?
                  And start this sketch, which then will use the defined ID or request a new ID from controller and writes the eeprom?
                    Understood.
                    tekkaT
                    tekkaT
                    tekka
                    Yes
                    Only true if EEPROM (i.e. ID address location) was cleared.
                    During booting, MYSBootloader calculates the FW CRC in flash and verifies it against the FW CRC stored in EEPROM (which is written after a successful OTA FW update) - if it matches, the sketch starts, if not, the bootloader remains active.
                    • berkseoB
                      berkseoB
                      berkseo
