  3. Home Assistant
  4. Invalid Message, Sensor not being added
16 Posts 3 Posters 6.1k Views 3 Watching
  • David PinnockD
    David PinnockD
    David Pinnock
    Having managed to get HASS to connect to the USB I am now unable to get the sensor recognised :)
    HASS is logging the following error:
    My sketch appears similar to the example here: https://home-assistant.io/components/sensor.mysensors/
    I'm using an S_MULTIMETER to send V_VOLTAGE and V_CURRENT values but not V_IMPEDANCE.
    Tried changing the child_id to 255 in the sketch but no luck so switched it back to 1.
    //#define DEBUG_ON  // comment out this line to disable serial debug
    #define CHILD_ID 1
    MyMessage msgVolts(CHILD_ID, V_VOLTAGE);
    MyMessage msgAmps(CHILD_ID, V_CURRENT);
    // Possible variable types for multimeter:  V_VOLTAGE, V_CURRENT, V_IMPEDANCE
    unsigned long SLEEP_TIME = 5000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldVoltage = 0;
    int oldCurrent = 0;
    int VOLTAGE_SENSE_PIN = A1;  // select the input pin for the battery sense point
    int CURRENT_SENSE_PIN = A2;  // select the input pin for the battery sense point
      gw.begin();
      gw.present(CHILD_ID, S_MULTIMETER);
       gw.sendSketchInfo("Battery Charger", "1.0");
      pinMode(VOLTAGE_SENSE_PIN, INPUT);
      pinMode(CURRENT_SENSE_PIN, INPUT);
      #ifdef DEBUG
        Serial.begin(9600);
       // get the battery Voltage
      int     voltageLevel = analogRead(VOLTAGE_SENSE_PIN);
      int     currentLevel = analogRead(CURRENT_SENSE_PIN);
      double  levelinVolts = voltageLevel*0.0492903225806452;
      double  levelinAmps  = currentLevel*0.041125;
      #ifdef DEBUG
        Serial.println(voltageLevel);
        Serial.println(currentLevel);
        Serial.print("Voltage:");
        Serial.print(levelinVolts);
        Serial.print("v ");
        Serial.print(" Current:");
        Serial.print(levelinAmps);
        Serial.print("a MaxAmps:");
        //Serial.print(maxAmps);
        Serial.println("a ");
    //   if (oldVoltage != levelinVolts) {
         // Power up radio after sleep
          gw.send(msgVolts.set(levelinVolts,1));
         oldVoltage = levelinVolts;
    //  if (oldCurrent != levelinAmps) {
        gw.send(msgAmps.set(levelinAmps,1));
        oldCurrent = levelinAmps;
       gw.sleep(SLEEP_TIME);
    (I'm no Arduino expert and most of the sketch was adapted from a similar example I found.)
    Looking at how its set in Domoticz it does seem like the node itself has an id of 255 but I don't see anywhere to set that? Maybe I should add this manually to the configuration.yaml some how?!
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      What version of mysensors are you using? Your sketch is using a pre 2.0 library api. I suggest you use the latest mysensors library version and update your sketch to use the current api.
      Read the api documentation on the mysensors site for more info.
      • David PinnockD
        David PinnockD
        David Pinnock
        Ok that seems to have worked... once...
        The sensors appeared in HASS but are not now updating, getting these errors:
        I think I read another thread about Pyserial being an issue so wondering if this is causing these errors..
        • David PinnockD
          David PinnockD
          David Pinnock
          Damn it still not managed to get this working properly :(
          This is an extract from the log:
          2018-01-16 21:56:57 INFO (MainThread) [homeassistant.loader] Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
          2018-01-16 21:56:57 INFO (MainThread) [homeassistant.loader] Loaded mysensors from homeassistant.components.mysensors
          2018-01-16 21:56:57 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mysensors
          2018-01-16 21:56:58 INFO (MainThread) [homeassistant.setup] Setting up mysensors
          2018-01-16 21:56:58 INFO (MainThread) [homeassistant.setup] Setup of domain mysensors took 0.4 seconds.
          2018-01-16 21:56:58 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=mysensors>
          2018-01-16 21:57:00 DEBUG (Thread-7) [homeassistant.components.mysensors] Invalid values: {38: '3.6', 39: '8.1'}: sensor platform: node 1 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
          2018-01-16 21:57:00 INFO (Thread-14) [mysensors.gateway_serial] Trying to connect to /dev/ttyUSB0
          2018-01-16 21:57:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event platform_discovered[L]: service=load_platform.sensor, discovered=name=mysensors, devices=[(1843074256, 1, 1, 38), (1843074256, 1, 1, 39)], platform=mysensors>
          2018-01-16 21:57:00 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mysensors
          2018-01-16 21:57:00 INFO (Thread-14) [mysensors.gateway_serial] /dev/ttyUSB0 is open...
          2018-01-16 21:57:00 INFO (Thread-2) [homeassistant.components.mysensors] Adding new devices: [<Entity Battery Charger 1: None>, <Entity Battery Charger 1: None>]
          2018-01-16 21:57:00 INFO (Thread-14) [mysensors.gateway_serial] Connected to /dev/ttyUSB0
          2018-01-16 21:57:00 DEBUG (Thread-12) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
          2018-01-16 21:57:00 DEBUG (Thread-12) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.1
          2018-01-16 21:57:00 DEBUG (Thread-4) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
          2018-01-16 21:57:00 DEBUG (Thread-4) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.1
            File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/sensor/mysensors.py", line 68, in unit_of_measurement
          2018-01-16 21:57:03 WARNING (Thread-14) [mysensors] Error decoding message from gateway, bad data received: 0=1,c=1,t=38,pt=7,l=5,sg=0:3.6
          2018-01-16 21:57:03 WARNING (Thread-14) [mysensors] Not a valid message:
          2018-01-16 21:57:03 DEBUG (Thread-14) [homeassistant.components.mysensors] Node update: node 1 child 1
          2018-01-16 21:57:03 DEBUG (Thread-14) [homeassistant.components.mysensors] Invalid values: {38: '3.6', 39: '8.1'}: sensor platform: node 1 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
          2018-01-16 21:57:03 DEBUG (Thread-9) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
          2018-01-16 21:57:03 DEBUG (Thread-9) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.1
          2018-01-16 21:57:03 DEBUG (Thread-14) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,1-1-0,s=1,c=1,t=39,pt=7,l=5,sg=0:8.2
          2018-01-16 21:57:03 DEBUG (Thread-7) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
          2018-01-16 21:57:03 DEBUG (Thread-7) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.1
          2018-01-16 21:57:03 DEBUG (Thread-14) [homeassistant.components.mysensors] Invalid values: {38: '3.6', 39: '8.2'}: sensor platform: node 1 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
          2018-01-16 21:57:03 DEBUG (Thread-4) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
          2018-01-16 21:57:03 DEBUG (Thread-4) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.2
          2018-01-16 21:57:03 DEBUG (Thread-8) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
          2018-01-16 21:57:03 DEBUG (Thread-8) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.2
          2018-01-16 21:57:08 DEBUG (Thread-14) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,1-1-0,s=1,c=1,t=38,pt=7,l=5,sg=0:3.6
          2018-01-16 21:57:08 DEBUG (Thread-14) [homeassistant.components.mysensors] Node update: node 1 child 1
          2018-01-16 21:57:08 DEBUG (Thread-14) [homeassistant.components.mysensors] Invalid values: {38: '3.6', 39: '8.2'}: sensor platform: node 1 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
          2018-01-16 21:57:08 DEBUG (Thread-5) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
          2018-01-16 21:57:08 DEBUG (Thread-5) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.2
          To me, this looks like it should be working. There are some invalid data messages but there are also valid ones which appear to post valid sensor data.
          This looks like a valid update for example:
          Current configuration in HASS:
          mysensors:
            gateways:
              - device: '/dev/ttyUSB0'
                persistence_file: '/home/homeassistant/.homeassistant/mysensors.json'
                baud_rate: 115200
                nodes:
                   1:
            optimistic: false
            persistence: true
            retain: true
            version: 2
          Maybe I need to define the sensors here?! I've tried updating pyserial but whatever I do (including uninstall and reinstall) it still seems to remain on 2.6.
          • David PinnockD
            David PinnockD
            David Pinnock
            wrote on last edited by David Pinnock
            Well I've had about enough of this nothing I do seems to work.
            • Upgraded both my gateway and node to MySensors 2
            • Configuration.yaml seems correct as per previous post
            • Some messages seem like they are accepted but no sensors show up
              • It also seems like the Gateway may store messages or values, as some that are logged are older values?
            • PySerial is 2.6 and I can't seem to down/upgrade it whatever I do
            • strange script errors also but this could also be because of the bad data errors
            Script Error:
                set_req.V_ORP: 'mV',
            I'm about ready to give up now, very frustrating when Domoticz is working just fine on the same RaspberryPi and gateway. I've even considered having Domoticz forward the messages on to Home Assistant! :)
            Could really use some help before I throw the damn Arduino out completely and buy a PiZero to see if I can use that!
            • David PinnockD
              David PinnockD
              David Pinnock
              Given up!
              Written a simple flow in NodeRed that forwards the messages on just fine.
              [{"id":"a0e7c229.c1b2","type":"serial in","z":"c20914f0.8b8318","name":"MySensorsInput","serial":"4ba29f87.c500a","x":100,"y":68,"wires":[["c275b371.0a92a"]]},{"id":"2c003b62.b3ca04","type":"debug","z":"c20914f0.8b8318","name":"","active":true,"console":"false","complete":"true","x":976,"y":57,"wires":[]},{"id":"c275b371.0a92a","type":"function","z":"c20914f0.8b8318","name":"Decode Message","func":"var message = msg.payload;\nvar result = message.split(\";\");\nvar arrlength = result.length;\n\nmsg.payload = {};\n\nif(arrlength==6){\nmsg.payload.nodeid = result[0];\nmsg.payload.childid = result[1];\nmsg.payload.command = result[2];\nmsg.payload.ack = result[3];\nmsg.payload.type = result[4];\nmsg.payload.payload = result[5];\n} else {\n    msg.payload = \"Ignore\";\n}\n\n\n//1;1;1;0;39;8.8\n\n//1;;1;0;38;3.6\n\nreturn msg;","outputs":1,"noerr":0,"x":324,"y":68,"wires":[["5e07aa77.6b3884"]]},{"id":"5e07aa77.6b3884","type":"switch","z":"c20914f0.8b8318","name":"Filter Update Messages","property":"payload.command","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"}],"checkall":"true","outputs":1,"x":581,"y":68,"wires":[["764204f4.fe8bdc"]]},{"id":"a9be705b.07cec","type":"mqtt out","z":"c20914f0.8b8318","name":"","topic":"","qos":"","retain":"","broker":"9ccc9e2b.1b109","x":1018,"y":157,"wires":[]},{"id":"764204f4.fe8bdc","type":"function","z":"c20914f0.8b8318","name":"Format MQTT Message","func":"var nodeid = msg.payload.nodeid;\nvar type =  msg.payload.type;\nvar value = msg.payload.payload;\n\nmsg.payload = {}\n\nmsg.topic = \"haas/mySensors/\"+ nodeid +\"/\" + type;\nmsg.payload.string = value;\n\nreturn msg;","outputs":1,"noerr":0,"x":785,"y":157,"wires":[["a9be705b.07cec","2c003b62.b3ca04"]]},{"id":"4ba29f87.c500a","type":"serial-port","z":"","serialport":"/dev/ttyUSB0","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":false},{"id":"9ccc9e2b.1b109","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""}]
              This sends updates to a couple of MQTT sensors set up in my config.
              sensor:
                - platform: mqtt
                  state_topic: "haas/mySensors/1/39"
                  value_template: '{{ value_json.string }}'
                  unit_of_measurement: 'a'
                - platform: mqtt
                  state_topic: "haas/mySensors/1/38"
                  unit_of_measurement: 'V'
              Not sure if there's a better value template than string? Couldn't find any detail on what options there were..
              • martinhjelmareM
                martinhjelmareM
                martinhjelmare
                Pymysensors and home assistant requires pyserial version 3.1.1 or higher. This should be installed automatically when installing and running home assistant with mysensors activated. If it doesn't do that something with your install and environment is not operating normally.
                How have you installed home assistant?
                • David PinnockD
                  David PinnockD
                  David Pinnock
                  Installed Home Assistant manually on Raspian following the install guide
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    What version of pyserial is installed inside the virtual environment?
                    sudo su -s /bin/bash homeassistant
                    cd /srv/homeassistant
                    source bin/activate
                    pip3 show pyserial
                    • David PinnockD
                      David PinnockD
                      David Pinnock
                      Version: 3.4
                      Summary: Python Serial Port Extension
                      Home-page: https://github.com/pyserial/pyserial
                      Author: Chris Liechti
                      Author-email: cliechti@gmx.net
                      License: BSD
                      Location: /srv/homeassistant/lib/python3.4/site-packages
                      • martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        That's good at least. Then the home assistant core feature of installing requirements seems to work in your installation.
                        I'll have a look at the log messages and see if I can find the problem.
                        I'll post back later tonight.
                        • David PinnockD
                          David PinnockD
                          David Pinnock
                          Brilliant thanks very much for the help!
                          • martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            I've looked at the home assistant log you've provided. Unfortunately I think I would need a serial log from the node to get more info. It's weird that you get an error about unit of measurement, since all values should be validated when leaving pymysensors before entering the home assistant layer.
                            If I would guess, I'd say that some message is not sent/received and presentation not fully performed.
                            I would recommend to change your sketch and keep one sensor value per child sensor, ie not both V_VOLTAGE and V_CURRENT in one child. Home assistant expects one value per child for normal sensors. Only complex entities like cover should report more than one value. It will avoid entity_id clashes.
                            • David PinnockD
                              David PinnockD
                              David Pinnock
                              Ok I'll try that. Think I have already tried with just sending one value in the sketch but perhaps I would also need to delete the persistent mysensors.json file for it to have a chance.
                              • T
                                terxw
                                I have same problem, on both my GWs using MQTT (ESP2866 nodes ) in homeassistant i get lots of these errors
                                At my parents:
                                2018-11-24 15:23:51 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '0.4'}: sensor platform: node 18 child 7: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
                                2018-11-24 15:23:51 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Lifepo solar node G 18 7: value_type 38, value = 0.4
                                2018-11-24 15:24:00 DEBUG (SyncWorker_18) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
                                2018-11-24 15:24:17 INFO (MainThread) [homeassistant.components.http.view] Serving / to 127.0.0.1 (auth: False)
                                2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/255/3/0/0: b'50'
                                2018-11-24 15:24:21 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;255;3;0;0;50
                                2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 255
                                2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 28
                                2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/1/1/0/38: b'2604.0'
                                2018-11-24 15:24:21 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;1;1;0;38;2604.0
                                2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 1
                                2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2604.0'}: sensor platform: node 28 child 1: S_MULTIMETER requires value_type V_CURRENT @ data[39]
                                2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2604.0'}: sensor platform: node 28 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
                                2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: detska_dole 28 1: value_type 38, value = 2604.0
                                2018-11-24 15:24:22 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/0/1/0/0: b'20.3'
                                2018-11-24 15:24:22 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;0;1;0;0;20.3
                                2018-11-24 15:24:22 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 0
                                2018-11-24 15:24:22 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: detska_dole 28 0: value_type 0, value = 20.3
                                2018-11-24 15:24:30 DEBUG (SyncWorker_0) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
                                2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/21/255/3/0/0: b'80'
                                2018-11-24 15:24:47 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 21;255;3;0;0;80
                                2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 21 child 255
                                2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 21
                                2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/21/1/1/0/38: b'3033.0'
                                2018-11-24 15:24:47 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 21;1;1;0;38;3033.0
                                2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 21 child 1
                                2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node 21 is missing sketch name
                                2018-11-24 15:24:47 INFO (MainThread) [homeassistant.components.http.view] Serving / to 127.0.0.1 (auth: False)
                                2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/21/0/1/0/0: b'22.5'
                                2018-11-24 15:24:47 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 21;0;1;0;0;22.5
                                2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 21 child 0
                                2018-11-24 15:24:50 DEBUG (SyncWorker_16) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
                                2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/18/255/3/0/0: b'255'
                                2018-11-24 15:24:55 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 18;255;3;0;0;255
                                2018-11-24 15:24:55 WARNING (MainThread) [mysensors] Not a valid message: value must be integer between 0 and 100 for dictionary value @ data['payload']
                                2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/18/7/1/0/38: b'0.3'
                                2018-11-24 15:24:55 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 18;7;1;0;38;0.3
                                2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 18 child 7
                                2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '0.3'}: sensor platform: node 18 child 7: S_MULTIMETER requires value_type V_CURRENT @ data[39]
                                2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '0.3'}: sensor platform: node 18 child 7: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
                                2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Lifepo solar node G 18 7: value_type 38, value = 0.3
                                2018-11-24 15:25:00 DEBUG (SyncWorker_12) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
                                2018-11-24 15:25:17 INFO (MainThread) [homeassistant.components.http.view] Serving / to 127.0.0.1 (auth: False)
                                2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/255/3/0/0: b'50'
                                2018-11-24 15:25:25 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;255;3;0;0;50
                                2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 255
                                2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 28
                                2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/1/1/0/38: b'2604.0'
                                2018-11-24 15:25:25 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;1;1;0;38;2604.0
                                2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 1
                                2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2604.0'}: sensor platform: node 28 child 1: S_MULTIMETER requires value_type V_CURRENT @ data[39]
                                2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2604.0'}: sensor platform: node 28 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
                                2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: detska_dole 28 1: value_type 38, value = 2604.0
                                2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/0/1/0/0: b'20.3'
                                2018-11-24 15:25:25 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;0;1;0;0;20.3
                                2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 0
                                And at home:
                                2018-11-24 15:26:07 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;255;3;0;0;13
                                2018-11-24 15:26:07 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 255
                                2018-11-24 15:26:07 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 14
                                2018-11-24 15:26:08 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/4/1/0/0: b'0.0'
                                2018-11-24 15:26:08 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;4;1;0;0;0.0
                                2018-11-24 15:26:08 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 4
                                2018-11-24 15:26:08 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: balkon_polievanie 14 4: value_type 0, value = 0.0
                                2018-11-24 15:26:08 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/5/1/0/16: b'0.0'
                                2018-11-24 15:26:08 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;5;1;0;16;0.0
                                2018-11-24 15:26:08 WARNING (MainThread) [mysensors] Not a valid message: value must be either 0 or 1 for dictionary value @ data['payload']
                                2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/2/1/0/37: b'0.0'
                                2018-11-24 15:26:09 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;2;1;0;37;0.0
                                2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 2
                                2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {37: '0.0'}: binary_sensor platform: node 14 child 2: S_MOISTURE requires value_type V_TRIPPED @ data[16]
                                2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {37: '0.0'}: switch platform: node 14 child 2: S_MOISTURE requires value_type V_ARMED @ data[15]
                                2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: balkon_polievanie 14 2: value_type 37, value = 0.0
                                2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/255/3/0/22: b'17283381'
                                2018-11-24 15:26:09 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;255;3;0;22;17283381
                                2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 255
                                2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 14
                                2018-11-24 15:26:09 DEBUG (SyncWorker_12) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
                                2018-11-24 15:26:15 INFO (MainThread) [homeassistant.components.http.view] Serving / to 127.0.0.1 (auth: False)
                                2018-11-24 15:26:25 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/16/255/3/0/0: b'53'
                                2018-11-24 15:26:25 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 16;255;3;0;0;53
                                2018-11-24 15:26:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 16 child 255
                                2018-11-24 15:26:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 16
                                2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/16/1/1/0/38: b'2654.0'
                                2018-11-24 15:26:26 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 16;1;1;0;38;2654.0
                                2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 16 child 1
                                2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2654.0'}: sensor platform: node 16 child 1: S_MULTIMETER requires value_type V_CURRENT @ data[39]
                                2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2654.0'}: sensor platform: node 16 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
                                2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: cerman_kuchyna 16 1: value_type 38, value = 2654.0
                                2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/16/0/1/0/0: b'25.0'
                                2018-11-24 15:26:26 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 16;0;1;0;0;25.0
                                2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 16 child 0
                                2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: cerman_kuchyna 16 0: value_type 0, value = 25.0
                                2018-11-24 15:26:29 DEBUG (SyncWorker_10) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
                                2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/255/3/0/0: b'13'
                                2018-11-24 15:26:44 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;255;3;0;0;13
                                2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 255
                                2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 14
                                2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/4/1/0/0: b'0.0'
                                2018-11-24 15:26:44 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;4;1;0;0;0.0
                                2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 4
                                2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: balkon_polievanie 14 4: value_type 0, value = 0.0
                                2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/5/1/0/16: b'0.0'
                                2018-11-24 15:26:44 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;5;1;0;16;0.0
                                2018-11-24 15:26:44 WARNING (MainThread) [mysensors] Not a valid message: value must be either 0 or 1 for dictionary value @ data['payload']
                                2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/2/1/0/37: b'0.0'
                                2018-11-24 15:26:45 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;2;1;0;37;0.0
                                2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 2
                                2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {37: '0.0'}: binary_sensor platform: node 14 child 2: S_MOISTURE requires value_type V_TRIPPED @ data[16]
                                2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {37: '0.0'}: switch platform: node 14 child 2: S_MOISTURE requires value_type V_ARMED @ data[15]
                                2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: balkon_polievanie 14 2: value_type 37, value = 0.0
                                2018-11-24 15:26:45 INFO (MainThread) [homeassistant.components.http.view] Serving / to 127.0.0.1 (auth: False)
                                2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/255/3/0/22: b'17287055'
                                2018-11-24 15:26:45 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;255;3;0;22;17287055
                                2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 255
                                2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 14
                                My config (same on both hass dockers only prefixes are different):
                                mysensors:
                                  gateways:
                                    - device: mqtt
                                      topic_in_prefix: 'cerman/mygateway1-out'
                                      topic_out_prefix: 'cerman/mygateway1-in'
                                      persistence_file: '/config/mysensors.json'
                                      nodes:
                                        1:
                                #        3:
                                #          name: 'living_room'
                                  optimistic: false
                                  persistence: true
                                  retain: true
                                  version: '2.0'
                                • T
                                  terxw
                                  Ok so after further reading I found info on the issue, it seems that these are debug messages, we can safaly ignore them.
                                  homeassistant forum
