  3. Cannot get Sensebender_GW / W5100 to connect to router.
9 Posts 5 Posters 2.0k Views 4 Watching
  • JohnRobJ Offline
    JohnRobJ Offline
    JohnRob
    wrote on last edited by JohnRob
    I've built a gateway using:
    Sensebender GW
    W5100 Ethernet board (the small board, not the arduino shield)
    RFM69HW 915Mhz.
    At the moment I have no sensor nodes. My plan was to get the gateway talking to the router, then add a potientiometer to the gateway (simple analog read of the wiper) to wring out the connection to my VeraPlus.
    I connected it up and making a few modifications to the example code "GatewayW5100.ino". Downloaded the code to the GW board and could not get it to connect to my router.
    I setup a MAC IP reservation on my router.
    I triple checked the MAC address.
    the result was:
    No connection shown on my router
    Serial monitor showed:
    0;255;3;0;9;MCO:BGN:STP
    I don't know where to look next. Is there a documentation that will decipher the debug info shown in the serial port monitor?
    JohnRob
    my code: (I annotated any changes from the downloaded code)
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69            // enabled
    #define MY_RFM69_FREQUENCY RF69_915MHZ      // <-- added, info from forum
    #define MY_IS_RFM69HW                       // <-- added, info from forum
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4                               //<   <---- enabled this line after not response without
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,xxx,xxx,xx7   // If this is disabled, DHCP is used to retrieve address    <-- changed to reserved IP
    #define MY_PORT 5003
    #define MY_MAC_ADDRESS 0xFE, 0xED, 0xDE, 0xAD, 0xBE, 0xEF                   //<-- changed to not be default.
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    • T Offline
      T Offline
      tbowmo
      Have you tried a simple network sketch? For example "Examples/Ethernet/WebServer" ? This is to prove that the ethernet module is up and running on your hardware
      If that is succesful, then proceed to the MySensors sketch shown above, if not you should have a look at the hardware / router setup.
      • JohnRobJ JohnRob
        Sensebender GW
        RFM69HW 915Mhz.
        the result was:
        JohnRob
         * LED purposes:
        #define MY_SOFTSPI
        // Enable to UDP
        zboblamontZ Offline
        zboblamontZ Offline
        zboblamont
        @johnrob Deciphering the messages is via the log parser, https://www.mysensors.org/build/parser
        • JohnRobJ Offline
          JohnRobJ Offline
          JohnRob
          Many thanks for both replies.
          I tried the Ethernet/Webserver and found the hardware OK. The issue appears to be the operator not knowing what to expect from the Gateway.
          I found the response parser, however I'm still too much a novice to put the message information to good use.
          • T Offline
            T Offline
            tomkxy
            @johnrob said in Cannot get Sensebender_GW / W5100 to connect to router.:
            From what I see you probably should try to define an IP address in your sketch...
            • JohnRobJ Offline
              JohnRobJ Offline
              JohnRob
              @tomkxy,
              I can't say exactly what is happening but the router does not show the MySensors gateway in the DHCP Client list. However, both the Webserver example and the Sensebender_GW are running through the router.
              1. The webserver example output can be seen by directing Chrome to the Webserver IP address.
              2. The Sensebender_GW can connect to my VeraPlus which is connected to the LAN.
              I have a feeling that the MySensor code is designed to connect - send payload - disconnect. However I don't currently know how to test this or if its even a possibility.
              For me right now, the lack of Router listing is not an issue as I still have a ways to go to setup my 1st sensor -> VeraPlus network.
              gohanG 1 Reply Last reply
              • JohnRobJ JohnRob
                @tomkxy,
                @johnrob if you don't comment out the ip address define, it is normal that the gw doesn't show up on the dhcp list
                • JohnRobJ Offline
                  JohnRobJ Offline
                  JohnRob
                  @gohan,
                  Thanks I see that now. After I commented out the IP address the router assigned (dhcp) an address.
                  All seems to be working now. I still have to wait to get my sensor board going to test the actual communication. I had been hoping to perform the initial test of data from the gateway Analog input to my VeraPlus, however I don't know how to include a sensor on the gateway.
                  JohnRob
                    It works the same as a node, just don't use delay and sleep in code but use only wait() at the end of loop if you don't want to flood the controller
