  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • E executivul
    @neverdie
    #448
      andrewA 1 Reply Last reply
        NeverDieN andrewA 2 Replies Last reply
          #451
            E 1 Reply Last reply
              E
              E
              executivul
              @neverdie 0.4-0.5mm for vias using 0.3mm silver plated "wrapping wire". 0.9 for TH and alignment holes.
                #454
                  #455
                    andrewA
                    andrewA
                    andrew
                    wrote on last edited by andrew
                    #456
                    @neverdie the order of the process should be the following:
                    • flipping the pcb
                    • moving and not stable pcb
                      andrewA
                      andrewA
                      andrew
                        andrewA
                        andrewA
                        andrew
                        #458
                        maybe my pins also have different factors, but indeed, the given holes are pretty tight. this helps to prevent unnecessary pcb movements, which is very important if you work with 6mil traces/isolation, as a small unwanted movement could result in wasted pcb. if you work with bigger traces/clearings then it is not as important.
                        I would recommend to stick to one size which is good for your selected pins and which does not let the pcb to move.
                          Here's the final product:
                          Three of the vias are located under an SMD module, so I'll just have to try to minimize any solder bumps over them.
                            Unfortunately, even a tiny solder bump prevents the module from being soldered. I would have to redesign this so that the vias are not under the module.
                            • dbemowskD
                              dbemowskD
                              @NeverDie Just have to say, I have been following this thread for a while now and you have come a long way with this. Great job.
                                Another good thing for people to know is that you can leave a single-sided blank PCB installed in the CNC and then, as the need arises, cut out additional modules from it:
                                For instance, this morning I cut this module carrier out of the above, already used, copper clad PCB:
                                So, for simple small things, it's a handy arrangement, and the incremental cost is negligible.
                                  zboblamontZ
                                  zboblamontZ
                                  zboblamont
                                  @neverdie Perhaps a clearer explanation ?
                                    #464
                                    One problem I've run into though is that the foil traces can sometimes lift up in the course of ordinary soldering. For instance, the traces connecting the second to the right pin on the Fanstel module seems to have utterly disappeared, leaving that pin unconnected:
                                    Maybe it's the quality of the blank PCB? I just don't know.
                                    dbemowskD 1 Reply Last reply
                                      dbemowskD
                                      dbemowskD
                                      @neverdie It looks like you could potentially make those traces just a touch wider looking at the receiving end of the module. Woulld that be an option?
                                      • dbemowskD dbemowsk
                                        Maybe: I'll try a 10 degree bit and tighter autoleveling to see if that gives wider traces.
                                          dbemowskD
                                          dbemowskD
                                          @neverdie i say that because in your previous pic of the board it looked like that trace was a bit narrow. Because of that it probably couldn't take the heat.
