  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • E executivul
    @neverdie I use a wood screw in the sacrificial board holding a piece of metal as a "clamp" I slide it over the board (1mm overlap) and clip one alligator clip to the screw, the other to the bit. After probing I slide it out of the way. The metal piece is about 10cm long and it's left in place for the life of the wood board.
    #444
    Do you have a photo of that?
      #445
      @andrew
      NeverDieN E 2 Replies Last reply
        @andrew
          @andrew
          E
          E
          executivul
          wrote on last edited by executivul
          #447
          @neverdie
          • E executivul
            @neverdie
            #448
              andrewA 1 Reply Last reply
                NeverDieN andrewA 2 Replies Last reply
                  #451
                    E 1 Reply Last reply
                      E
                      E
                      executivul
                      @neverdie 0.4-0.5mm for vias using 0.3mm silver plated "wrapping wire". 0.9 for TH and alignment holes.
                        #454
                          #455
                            andrewA
                            andrewA
                            andrew
                            wrote on last edited by andrew
                            #456
                            @neverdie the order of the process should be the following:
                            • flipping the pcb
                            • moving and not stable pcb
                              andrewA
                              andrewA
                              andrew
                                andrewA
                                andrewA
                                andrew
                                #458
                                maybe my pins also have different factors, but indeed, the given holes are pretty tight. this helps to prevent unnecessary pcb movements, which is very important if you work with 6mil traces/isolation, as a small unwanted movement could result in wasted pcb. if you work with bigger traces/clearings then it is not as important.
                                I would recommend to stick to one size which is good for your selected pins and which does not let the pcb to move.
                                  Here's the final product:
                                  Three of the vias are located under an SMD module, so I'll just have to try to minimize any solder bumps over them.
                                    Unfortunately, even a tiny solder bump prevents the module from being soldered. I would have to redesign this so that the vias are not under the module.
                                    • dbemowskD
                                      dbemowskD
                                      @NeverDie Just have to say, I have been following this thread for a while now and you have come a long way with this. Great job.
                                        Another good thing for people to know is that you can leave a single-sided blank PCB installed in the CNC and then, as the need arises, cut out additional modules from it:
                                        For instance, this morning I cut this module carrier out of the above, already used, copper clad PCB:
                                        So, for simple small things, it's a handy arrangement, and the incremental cost is negligible.
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @neverdie Perhaps a clearer explanation ?
