  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
        #440
        There's a huge difference between being able to evolve a single PCB design to perfect it rather than having to work on a "dumbed down" design (for a CNC or some other DIY etching process) before being able to get "the real deal" from a PCB fabricator. So, I'm very relieved that the first option now seems possible. :)
        andrewA 2 Replies Last reply
          andrewA
          andrewA
          andrew
          @neverdie I told you since the very beginning to make the firmware upgrade! ;)
            andrewA
            andrewA
            andrew
            @neverdie as I see from the picture, you can decrease the cutting depth. this could help you to soften the force against the carving bits and it could also help you to use faster feed rates without risking a missing step or bit damage.
            • andrewA andrew
              @andrew
              Cutting depth: 0.03
              Feedrate:80mm
              • E executivul
                @neverdie I use a wood screw in the sacrificial board holding a piece of metal as a "clamp" I slide it over the board (1mm overlap) and clip one alligator clip to the screw, the other to the bit. After probing I slide it out of the way. The metal piece is about 10cm long and it's left in place for the life of the wood board.
                #444
                Do you have a photo of that?
                  #445
                  @andrew
                  NeverDieN E 2 Replies Last reply
                    @andrew
                      @andrew
                      E
                      E
                      executivul
                      wrote on last edited by executivul
                      #447
                      @neverdie
                      • E executivul
                        @neverdie
                        #448
                          andrewA 1 Reply Last reply
                            NeverDieN andrewA 2 Replies Last reply
                              #451
                                E 1 Reply Last reply
                                  E
                                  E
                                  executivul
                                  @neverdie 0.4-0.5mm for vias using 0.3mm silver plated "wrapping wire". 0.9 for TH and alignment holes.
                                    #454
                                      #455
                                        andrewA
                                        andrewA
                                        andrew
                                        wrote on last edited by andrew
                                        #456
                                        @neverdie the order of the process should be the following:
                                        • flipping the pcb
                                        • moving and not stable pcb
                                          andrewA
                                          andrewA
                                          andrew
