  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 179.3k Views 38 Watching
  • H
    H
    helvetian
    thx for your fast reply. i'm in the train right now. so i can't provide you now with any pics. as soon as possible i will do that!
    I am using a battery booster (as it seems the same as you use), i have the battery jumpers connected, all the resistors and caps for the battery measurement.
    It is just wired that it functions while the nrf24 is powered separately. maybe i got some bad radios?
    One more question: the cap just below the booster. is this necessary to reduce the noice for the radio? might that help and if yes what size do you recommend? i didn't solder any cap yet there.
    "Did you by any chance connect both batteries and ftdi Vcc at the same time?"
    Yes! I did try this as well. Same results...
    I should also mention i got my Arduino Pro mini battery powered hacked. So no more LED and Voltage regulator. But then again i also tried it with a untouched one.
      I am using 2 10uF ceramic caps both on booster and radio side, so I strongly recommend to get a bunch of those as they are working better than the electrolics and can be used in many ways.
      • H helvetian
        sundberg84S
        sundberg84S
        #226
        @helvetian - good, sounds like a good start.
        If you have a booster + battery jumper in place this powers the radio separately. The most critical capacitor is the one close to VCC/GND on the Nrf24 radio. What value do you use here? Sometimes it helps to try higher values. I use 4,7 in normal cases but sometimes I either replace it or add in parallel a 47uF as well.
        This is not uncommon... noice from the booster (also common) combined with a bad radio might do this.
        Yes and No - I dont have any hard evidence (there are caps on the booster itself) but I have had good results with a 0,1 cheramic cap for a node that didnt work. It doesnt hurt to add.
        Dont do this - only 1 Vcc allowed :)
        When you have the time, upload a picture - it will probably help us more to help you.
        • H
          H
          helvetian
          here are some pics form my pcb board!
          0_1516654067507_20180122_213519.jpg 0_1516654074837_20180122_213527.jpg 0_1516654086429_20180122_213538.jpg
          • H helvetian
            sundberg84S
            sundberg84S
            @helvetian looks good! Nice work.
            I would start by soldering in/change capacitor on the radio and booster as mentioned. Try some other radio of you have. I have never connected the jumper for irq so just to test of nothing else works you can de-solder the irq jumper.
            • H
              H
              helvetian
              ok. thanks for the tips and your promt assistance! such a great community!
              i will try to experiment with some caps.
              i tested already a couple of different radios. but maybe i will get once a decent one which will work
              gohanG 1 Reply Last reply
              • H helvetian
                get some of these, I am very happy I got them
                https://www.aliexpress.com/item/Free-shipping-100PCS-Multilayer-ceramic-capacitor-10UF-106-50V-P-5-08mm/32783039097.html
                H 1 Reply Last reply
                  H
                  H
                  helvetian
                  @gohan
                  just bought them on ali. What would you recommend in the meantime till they arrive here in snowy switzerland? i got a assortement of electrolyt caps.
                  i got a bunch of 0.1uf ceramics. could i just solder(or test it on a breadboard) 10 of them to try out?
                    try adding first one on the booster and see what happens
                    • H
                      H
                      helvetian
                      wrote on last edited by helvetian
                      #233
                      just a quick update.
                      i ran some more tests with different radios and a 10uf electroltyte cap on the booster. And some different batteries.
                      Heureka! It works. For now. It is running now with a 3.7v lipo battery without the voltage regulator. Does anybody know if this is safe in the long run?
                        I wouldn't do it if I were you. You are going to fry the radio
                        • sundberg84S
                          sundberg84S
                          If you bypassed the booster and that works it seems like you have a booster which generates alot of noice. Try bypassing it with 2xaa and see what happens.
                          • sundberg84S sundberg84
                            H
                            H
                            helvetian
                            @sundberg84 do you experience the same thing when you are using boosters? Some are better than other even tough they are the same model? Same with the radios?
                            sundberg84S gohanG 2 Replies Last reply
                            • H helvetian
                              sundberg84S
                              sundberg84S
                              @helvetian correct. I can buy a batch with 10 boosters and some works and some don't. Most can work with the right capacitors as support but a few was just impossible.
                              • H helvetian
                                @helvetian when dealing with cheap Chinese stuff, you always have to consider that you may have got a poor quality product and because of this I also bought LiFePo4 batteries that run at 3.3v so no regulator needed making it easy to figure out if it is a power issue or else
                                • H
                                  H
                                  helvetian
                                  Thanks for clarifications
                                  Awesome forum!
                                  • H helvetian
                                    Awesome forum!
                                    sundberg84S
                                    sundberg84S
                                    @helvetian - just so you dont miss this. A Atmega328 (Pro mini if you are using EasyPCB) can be run without a booster by reprogramming the fuses/bootloader. This is more advanced but possible. Then you can run the pro mini with a 8mhz or 1mhz internal clock down to the radio minimum 1.9v. This is a better option compared to boosters but harder to achieve.
                                    Nca78N 1 Reply Last reply
                                      @sundberg84 said in Easy/Newbie PCB for MySensors:
                                      No it is not "hard". You just need to copy files in a directory, edit a text file and flash ISP sketch on a nano or uno bard. Easier than dealing with unreliable boosters :p
                                      • Nca78N Nca78
                                        sundberg84S
                                        sundberg84S
                                        @nca78 ... can be discussed. Wiring needs to be right. It's not hard when you know what to do but it's harder compared to a working booster.
