  2. Announcements
  • Richard van der PlasR
      if you only want to check if irq is enabled, otherwise you could just build it fresh with irq enabled and you can go back by replacing the mysgw executable
      wrote on last edited by Richard van der Plas
      #760
      Moved to normal troubleshooting forum
        • alowhumA
          alowhumA
          alowhum
          @MasMat Yes I was able to build it on a Pi Zero. I did a fresh install on Dietpi. It worked fine when I didn't give any configuration options.
          Now, however, I am still trying to run something on the PGIO pins in paralel to MySensors again, and this is not working. As I speak the Pi reboots every 5 minutes.. Not sure what to blame yet. Domoticz, PiGPIO, or MySensors.
          Latest DietPi Stretch, latest Domoticz beta, latest MySensors beta.
          MasMatM 1 Reply Last reply
            PiGPIO
            what are you using that for?
            • alowhumA alowhum
              MasMatM
              MasMatM
              MasMat
              @alowhum I'm not using the GPIO for anything else.
              I had everything working (mysgw-MQTT, Mosquitto, Node-Red and OH2) for almost 6h. Then I moved the set-up and everything went south: cant get mosquitto to start, cant get mysgw to connect to that or another Mosquitto broker, OH2 seems to ignore everything...
              Spent the last 24h trying to resurrect Mosquitto but it's beyond me what's wrong.
              I remember reading that mysgw renders rest of the gpio unusable. Maybe that's giving you problems.
              alowhumA 1 Reply Last reply
                I am running 2 gateway instances, one nrf24 and one rfm69 so I guess you can run other things
                • alowhumA
                  alowhumA
                  alowhum
                  @gohan: but you had to do a lot of black magic to get there right?
                    not at all, I just followed the guide in the forum
                    • MasMatM MasMat
                      alowhumA
                      alowhumA
                      alowhum
                      @masmat I got the Pi Zero W working fine with other things using the GPIO.
                      • A fresh install helped
                      • It could be that I now use the PiGPIO library for the project.
                      • It could be the switch to another powersupply. I was using the official pi powersupply, but I suspect something was wrong with it. A cheap 3A chinese adapter is working fine.
                      Either way: it all works now.
                      I have a few n00bish questions about enabling encryption (without signing, so save space and ram):
                      • Is putting an AES key in MyConfig.h really all I have to do? Don't I also have to put that in all the sensor nodes? And is that proces complicated, using a signing sketch and whatnot?
                      • Can I have an 'opportunistic' network, where I have some encrypted nodes, and some unencrypted ones? If I could mix them this would make switching to encryption less stressful. I can't easily change two of my nodes.
                      • If I change the network, I'd like to move the NRF to channel 100 (juist outside of the normal WiFi frequencies). Do I also have to set that in all nodes, or is setting it in the gateway enough?
                      gohanG 1 Reply Last reply
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        @alowhum encryption is all or nothing. You can't leave one node without encryption if your gateway encrypts the messages it send.
                        And you will need to personalize your nodes to get the AES key into them. The documentation on security describes that process.
                        • alowhumA alowhum
                          @alowhum if you put it in myconfig.h also on the arduino library you can just recompile the nodes and you are good.
                          AnticimexA 1 Reply Last reply
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @gohan not anymore. Only for pre 2.2.0 releases.
                              It is still working on mine 😅
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @gohan in other words, you use an old release ;)
                                  I can assure you I am using 2.2 from development as I am also running new driver. So unless you changed something in the last 3 weeks on the development branch it still works, unless the nodes are keeping the key saved.
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @gohan have you verified your communications are actually encrypted?
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      #776
                                      @gohan If you see here, you will find that unless you use the simple password option, AES key is fetched from EEPROM: https://github.com/mysensors/MySensors/blob/28c4f3f19e7026f56fd9bbc61d566f770fd7a9d2/hal/transport/MyTransportRF24.cpp#L68
                                      So either you are using the simple flag, nothing at all, or not using the key you think you use.
                                        I ll have to check, but I put the key in the gateway myconfig.h
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @gohan Perhaps on a rpi GW where there is no EEPROM, but I am talking about the nodes.
