  2. Announcements
  • Richard van der PlasR
    Is there anyway where i can see if i have IRQ configured ?
    ive build it a long time ago, but now upgraded to a nrf24 PA/LNA and have more an more sensors.
      look inside makefile.inc in mysensors folder, that should contain the parameters you set in ./configure
      Richard van der PlasR 1 Reply Last reply
        wrote on last edited by Richard van der Plas
        #752
        @gohanm, as it seems not ?, can i rebuild it easily? ```
        SOC=BCM2837
        CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003
        LDFLAGS=-pthread
        PREFIX=/usr/local
        CC=gcc
        CXX=g++
        BUILDDIR=build
        BINDIR=bin
        GATEWAY_DIR=/usr/local/bin
        INIT_SYSTEM=systemd
        SPI_DRIVER=BCM```
          make a copy of it and make a ./configure with the IRQ enabled and see what you get
            @gohan make a copy of the makefile.inc and restart the ./configure command again you mean ?
            ill try it tomorrow, too afraid to break things late in the evening ;)
              as far as you don't execute the MAKE command you are ok. Also make a copy of the mysgw executable just as backup if you never did it
                but ill have to do it sometime , just ./configure with all the options, build , test and install ?
                  if you only want to check if irq is enabled, otherwise you could just build it fresh with irq enabled and you can go back by replacing the mysgw executable
                  Richard van der PlasR 2 Replies Last reply
                    @gohan ty
                        #760
                        Moved to normal troubleshooting forum
                          • alowhumA
                            alowhumA
                            alowhum
                            @MasMat Yes I was able to build it on a Pi Zero. I did a fresh install on Dietpi. It worked fine when I didn't give any configuration options.
                            Now, however, I am still trying to run something on the PGIO pins in paralel to MySensors again, and this is not working. As I speak the Pi reboots every 5 minutes.. Not sure what to blame yet. Domoticz, PiGPIO, or MySensors.
                            Latest DietPi Stretch, latest Domoticz beta, latest MySensors beta.
                            MasMatM 1 Reply Last reply
                              PiGPIO
                              what are you using that for?
                              • alowhumA alowhum
                                MasMatM
                                MasMatM
                                MasMat
                                @alowhum I'm not using the GPIO for anything else.
                                I had everything working (mysgw-MQTT, Mosquitto, Node-Red and OH2) for almost 6h. Then I moved the set-up and everything went south: cant get mosquitto to start, cant get mysgw to connect to that or another Mosquitto broker, OH2 seems to ignore everything...
                                Spent the last 24h trying to resurrect Mosquitto but it's beyond me what's wrong.
                                I remember reading that mysgw renders rest of the gpio unusable. Maybe that's giving you problems.
                                alowhumA 1 Reply Last reply
                                  I am running 2 gateway instances, one nrf24 and one rfm69 so I guess you can run other things
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    @gohan: but you had to do a lot of black magic to get there right?
                                      not at all, I just followed the guide in the forum
                                      • MasMatM MasMat
                                        alowhumA
                                        alowhumA
                                        alowhum
                                        @masmat I got the Pi Zero W working fine with other things using the GPIO.
                                        • A fresh install helped
                                        • It could be that I now use the PiGPIO library for the project.
                                        • It could be the switch to another powersupply. I was using the official pi powersupply, but I suspect something was wrong with it. A cheap 3A chinese adapter is working fine.
                                        Either way: it all works now.
                                        I have a few n00bish questions about enabling encryption (without signing, so save space and ram):
                                        • Is putting an AES key in MyConfig.h really all I have to do? Don't I also have to put that in all the sensor nodes? And is that proces complicated, using a signing sketch and whatnot?
                                        • Can I have an 'opportunistic' network, where I have some encrypted nodes, and some unencrypted ones? If I could mix them this would make switching to encryption less stressful. I can't easily change two of my nodes.
                                        • If I change the network, I'd like to move the NRF to channel 100 (juist outside of the normal WiFi frequencies). Do I also have to set that in all nodes, or is setting it in the gateway enough?
                                        gohanG 1 Reply Last reply
                                        • AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @alowhum encryption is all or nothing. You can't leave one node without encryption if your gateway encrypts the messages it send.
                                          And you will need to personalize your nodes to get the AES key into them. The documentation on security describes that process.
