  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.5k Views 27 Watching
  • dbemowskD dbemowsk
    @neverdie I just wasn't sure if your CNC had any way of manually leveling the bed. My 3D printer has screws in the 4 corners of the bed for me to manually level. I have been sticking to manual leveling on it because I have heard of people that have switched to auto-leveling that have had a number of problems. Maybe you need to switch to a different type of auto-leveling sensor.
    E
    E
    executivul
    wrote on last edited by executivul
    #476
    What firmware? BEST sensor ever = piezo sensor. I get 3 micron accuracy and repeatability. I use it on Marlin 1.1.8 with UBL on a corexy printer and also on a Smoothie delta.
    dbemowskD 2 Replies Last reply
    • E executivul
      dbemowskD
      dbemowskD
      @executivul I don't have a sensor yet. If I was going to switch to one I would have to flash a different firmware on my board. It is a newer version of Marlin.
      E 1 Reply Last reply
        E
        E
        executivul
        #478
        Marlin=Arduino (usually Mega2560). So UBL. What type of printer?
        • E executivul
          dbemowskD
          dbemowskD
          @executivul I do manual leveling and I rarely have to level the bed itself.
            @neverdie I can see that the left side looks like it cut deeper, which would cause that. I still think it is the thin traces though. Can you do any manual leveling of the bed? If so, I would attempt that. My Anet A8 3D printer, though not a CNC, is all manual leveling and I do have to check it from time to time.
            I suppose I could shim under the sacrifice board with slips of paper to get the right height.
            I would have thought that the autoleveling would have accurately compensated though. Not sure why it isn't, especially if I'm autoleveling at 2mm spacing. Maybe this is an area where a future version of the GRBL driver will get it right.
            andrewA
            andrewA
            andrew
            @neverdie for pcb milling a small height difference across the board's area could result in a big negative effect if autoleveling is not performed properly.
            I would double check your autoleveling process, on the other hand, you could also try to use bed flattening with a bigger endmill tool first, then place the pcb to the flattened area. this could help you to eliminate or decrease the cnc assembly or the sacrificial board caused roughness.
            for further details please see the following link:
            http://flatcam.org/manual/procedures.html#bed-flattening
              E
              E
              executivul
              #481
              "If it works don't break it!"
              To end the offtopic, for anybody interested RepRap forum piezo discussion and https://www.precisionpiezo.co.uk/ the store of the guys who brought the piezo to the world, there are 1:1 clones on aliexpress, but the price is almost the same if you buy only the board and print your own holder and they provide warranty, fast shipping and are really great people so they deserve some support! (I'm not affiliated in any way to their store)
              LE. @NeverDie if you read this please look up 4-5 posts and tell me if your gcode has the autoleveling
              NeverDieN dbemowskD 2 Replies Last reply
              • E executivul
                #482
                yes. In Chilipeppr I send the autoleveling to the workspace, at which point it modifies the gcode.
                • andrewA andrew
                  What's the best type of sacrifice board to use if doing bed flattening? Regular wood, or should I stick with particle board or MDF?
                  andrewA zboblamontZ 2 Replies Last reply
                    It seems the z-height only needs to be off by a small amount (say 0.02mm) to have a noticeably negative effect on the trace width.
                    • E executivul
                      dbemowskD
                      dbemowskD
                      Amen to that
                        andrewA
                        andrewA
                        andrew
                        I never had to try it, so I don't know. for me the regular wood seems to be logical...
                          zboblamontZ
                          zboblamontZ
                          zboblamont
                          @neverdie Sorry @andrew, wood is not a stable material, it is not inert and changes shape, it breathes if you will.
                          Artificial materials such as particle board or MDF have a stable matrix, but of the two, MDF is the more uniform and least reactive, hence it's popularity for kitchen cupboards, loudspeaker cases, etc..
                          It is easily machined, but is hard on the typical router bits, although nowhere near that of HDF.
                          The bigger problem with mdf is the very fine dust produced when milling or cutting it with power tools, it gets everywhere, including your lungs, and can even get through vacuum cleaners without hepa filters....
                          I would suggest either a thick MDF or layers glued together, cut the sides to requirements, lock it in place and set a 6 or 8mm router bit for MDF in a collet, and set it to work, ideally outside where you can hose it down after sweeping up and vacuuming.
                            I think there may be some kind of coating that comes on these PCB's. Maybe it's to prevent corrosion of the copper? It seems to come off using IPA. Here one is before cleaning with IPA:
                            And here is the same PCB after cleaning with IPA:
                            Not sure whether it interferes with soldering. Anyone know? For now I'm cleaning it off.
                            dbemowskD 1 Reply Last reply
                              dbemowskD
                              dbemowskD
                              @neverdie Looks like you have that board dialed in...
                              • dbemowskD
                                dbemowskD
                                So a CNC question as I build my prototype machine. I have an arduino with CNC shield on order that should arrive tomorrow. My question is, does this allow for a display and keypad for local control or is everything just done through GRBL?
                                https://www.amazon.com/SODIAL-Arduino-Compatible-DRV8825-StepStick/dp/B074FVTTR7/ref=sr_1_7?s=electronics&ie=UTF8&qid=1517499916&sr=1-7&keywords=arduino+uno+cnc
                                ben999B 1 Reply Last reply
                                  ben999B
                                  ben999B
                                  ben999
                                  wrote on last edited by ben999
                                  #491
                                  @dbemowsk
                                  All done via GCodeSender and similar i'm afraid... which is not a problem as far as i can see
                                  Your Arduino is fully populated with this board :
                                  • driving stepper drivers
                                  • end-stops
                                  • coolant (or wathever) enable
                                  • spindle control (speed and rotation) (V3 shield can do PWM control if your spindle driver can). Be aware that this board doesn't drive any kind of motor. Just sends signal
                                  • cloning axis of your choice
                                  • emergency stop, pause and resume
                                  • i might forget some details but i'm sure you get the point
                                  But it's a pretty cool board for veeeery reasonable price. I love it !
                                  • ben999B ben999
                                    @dbemowsk
                                    • end-stops
                                    dbemowskD
                                    dbemowskD
                                    #492
                                    @ben999 Thanks can't wait to try it out.
                                    • ben999B ben999
                                      @dbemowsk
                                      • end-stops
                                      dbemowskD
                                      dbemowskD
                                      @ben999 So reading through your specs, everything seems pretty straight forward. I get that the spindle motor will need it's own controller which can be driven by the CNC board. One thing I am confused on though, what is "cloning axis of your choice". I am new to CNC.
                                        ben999B
                                        ben999B
                                        ben999
                                        @dbemowsk this board can accept up to 4 stepper drivers
                                        your machine is probably a 3-axis CNC, so in most cases one stepper per axis could do the trick.
                                        BUT sometimes some CNC designs require a 2nd stepper for an axis (usually the x-axis). Then add a 4th driver and some jumpers and you're done. You end up with 2 steppers doing exactly the same job
                                        • ben999B ben999
                                          dbemowskD
                                          dbemowskD
                                          @ben999 That makes sense. My 3D printer has 2 Z axis steppers.
