  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • TheoLT TheoL
    Today I soldered the headers to a new sensebender and try to start it. I've uploaded the 2.0 example but it can't find the gateway:
    Started
    Starting sensor (RNONA-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    My other sense benders worked flawelessly. But this one can't communicate. Does anyone have any idea, what might be wrong?
    Q
    Q
    Qu3Uk
    @TheoL I had this problem last night, its unable to find the parent/gateway. I ended up swapping out the radio with one I'd extended the antenna on and it worked. I then attached a piece of wire to the original radio and that was worked too. I put it down to knock off components.
    I think there is a video detailing the correct length etc.
    • TheoLT
      TheoLT
      TheoL
      Solved. I had forgotten to config the correct baudrate. My network is on one 1 mbyte, because of the mixed NRF24L01 and NRF24L01+ radios.
      • stefaanvS
        stefaanvS
        stefaanv
        I get "not in sync" errors from avrdude if I try uploading a sketch to the sensorbender.
        I do have correct serial communication, when I open the serial monitor, I get the info from the default sketch (which unfortunately uses the 1.4.1 API).
        I tried with a different SenseBender board, same result. Tried with an older IDE version (1.6.9) on an other computer, same result.
        Any suggestions ?
        avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x20
        avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2d
        avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x20
        avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4f
        avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6e
        avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6c
        avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x69
        avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6e
        avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x65
        avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x21
        alexsh1A 1 Reply Last reply
        • stefaanvS stefaanv
          Any suggestions ?
          alexsh1A
          alexsh1A
          alexsh1
          @stefaanv sounds like you have a wrong board in Arduino. Did you install the correct board in Arduino IDE? I'm programming the Sensebender in 1.6.9 via the FTDI adapter without any difficulties
          stefaanvS 1 Reply Last reply
          • alexsh1A alexsh1
            stefaanvS
            stefaanvS
            stefaanv
            @alexsh1 I'm using the Uno board. Which one should I use ? Can't find anything in the SenseBender page.
              alexsh1A
              alexsh1A
              alexsh1
              @stefaanv well, that's the problem - you must install Sensebender Micro (or I think you can use Arduino Pro Mini 3.3V) board. You MUST NOT provide more than 3.3V otherwise you may damage the board or radio. Please double check
              Please refer to this link below to install the correct board in Arduino:
              https://github.com/mysensors/ArduinoBoards
              • alexsh1A alexsh1
                stefaanvS
                stefaanvS
                stefaanv
                @alexsh1 Thanks, got it working now.
                • J
                  J
                  jovo
                  Is there anybody who can comment if the battery usage is increased in V2.0?
                  I feel that my batteries are draining faster then with 1.4 I had installed before.
                  Also I am seeing issues with the Force Retransmit. I dont see this working either. it just transmits when Transmit_Treshhold is kicked.
                  My sketch is pretty default. As far as I can see, I only turned Batt_Sensor on.
                  • J jovo
                    mvader
                    @jovo what is your usage? I'm getting 8+ months easily
                    I have a sensor in my deep freeze, been there for 8+ months and still working fine.
                    J 1 Reply Last reply
                    • M mvader
                      J
                      J
                      jovo
                      @mvader Hi,
                      I guess you are not for 8 months on v2?
                      I had a long time on the previous version as well.
                      Haven't done the measurements, but I noticed my batteries were depleted quickly since v2 was on.
                      I am more concerned about the fact that the force transmission doesn't seem to be working.
                      • J jovo
                        @mvader Hi,
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @jovo how exactly do you define "quicker" please? I do not think anyone had enough time to test it. My batteries dropped 0.2V for 2 months (reporting temp/humidity/pressure every minute) but that does not mean anything at all. I would need to run it for another 6 months at least to say what I think.
                        • Mitja BlazinsekM
                          Mitja BlazinsekM
                          Mitja Blazinsek
                          i have some problems with sensbender micro it all work fine it shows temp and hum in mycontroller bu then i try to program the board to test my FTDI programmer, for test i was try to upload default sketch but since then it showing me only node in mycontroller without any sensors :(
                          this is my log from debug:
                          0 MCO:BGN:INIT NODE,CP=RNONA--,VER=2.1.1
                          4 TSM:INIT
                          4 TSF:WUR:MS=0
                          12 TSM:INIT:TSP OK
                          14 TSF:SID:OK,ID=5
                          16 TSM:FPAR
                          53 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          2062 !TSM:FPAR:NO REPLY
                          2064 TSM:FPAR
                          2101 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          4110 !TSM:FPAR:NO REPLY
                          4112 TSM:FPAR
                          4149 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          6158 !TSM:FPAR:NO REPLY
                          6160 TSM:FPAR
                          6197 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          8206 !TSM:FPAR:FAIL
                          8208 TSM:FAIL:CNT=1
                          8210 TSM:FAIL:PDT
                          18214 TSM:FAIL:RE-INIT
                          18216 TSM:INIT
                          18225 TSM:INIT:TSP OK
                          18227 TSF:SID:OK,ID=5
                          18229 TSM:FPAR
                            That looks like there is no communication with gateway. Did you check gw log? You could also update mysensors to latest 2.2
                            • Mitja BlazinsekM
                              Mitja BlazinsekM
                              Mitja Blazinsek
                              but before it was working im using sensebender gateway and i see node in controler, i update my sensors and still nothing
                              • Mitja BlazinsekM
                                Mitja BlazinsekM
                                Mitja Blazinsek
                                OK i found the problem i just needed to clear the eeprom and it works i remembered that i had this problem before with binary switch sample
                                • Mitja BlazinsekM
                                  Mitja BlazinsekM
                                  Mitja Blazinsek
                                  sory still not workinkg i was thinking that i solve the problem but i didn't now i was try to connect other sensebender micro and it's working with no problem and i noticed that the red led flash on micro when i connect power i dont se that led on previous not working micro is it possible that i burn micro when programming, bu ti upload program with no problems i also had 3,3V jumper on the programer :(
                                    You could try with a basic blink sketch and see if you can blink an led
                                    • Mitja BlazinsekM
                                      Mitja BlazinsekM
                                      Mitja Blazinsek
                                      nothing happened just upload blink code but no blinking :(
                                      // the setup function runs once when you press reset or power the board
                                        // initialize digital pin LED_BUILTIN as an output.
                                        pinMode(LED_BUILTIN, OUTPUT);
                                      // the loop function runs over and over again forever
                                        digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
                                        delay(1000);                       // wait for a second
                                        digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
                                        have you tried another led?
                                        • Mitja BlazinsekM
                                          Mitja BlazinsekM
                                          Mitja Blazinsek
                                          it work when i try button example, had no diode at the hand
                                          tbowmoT 1 Reply Last reply
