  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • Mitja BlazinsekM
    Mitja BlazinsekM
    Mitja Blazinsek
    but why fail i upload officially sketches from my sensors also try same radio from sensebender that works also try blink test on sensebender and it works so what else could be i have everything latest version my controler mysensor libary...
      Could be noisy power supply, not adequate decoupling capacitor on the radio, radio interference from other devices nearby (wifi or else)
      • Mitja BlazinsekM
        Mitja BlazinsekM
        Mitja Blazinsek
        wrote on last edited by Mitja Blazinsek
        #562
        i try at least three different radios with and without capacitors gw an sensors are close (20cm) and like i said sensbender worked fine till i try to upload program on it
        AnticimexA 1 Reply Last reply
          Did you try a completely different radio module from another manufacturer?
          • Mitja BlazinsekM Mitja Blazinsek
            AnticimexA
            AnticimexA
            Anticimex
            @mitja-blazinsek how do you supply power to the radio module?
            • Mitja BlazinsekM
              Mitja BlazinsekM
              Mitja Blazinsek
              yust plug in socket on sensbender micro
              • Mitja BlazinsekM
                Mitja BlazinsekM
                Mitja Blazinsek
                is it possible that si some problem with my arduino IDE maybe some library tomorrow i will try to reinstall arduino
                • D
                  dklinkman
                  @MITJA BLAZINSEK - So I built my first Sensebender Micro this weekend and it works great. Radio works at distance (>10Meters). Advertises temp and hum at proper intervals. Plus battery level occasionally. And I can update the firmware via Arduino IDE (v1.8.1) and USB. Everyone's path and experience is different so here's what I did.
                  The build was simple. I just added the socket for the radio. Oh and a piece of right angle pin header for the FTDI interface.
                  For powering I currently use a FTDI Basic 3v3 from Sparkfun. Provides power plus USB serial for programming and debugging. I have a few 2xAAA cell holders on order for powering from battery.
                  Once built I also plugged in a radio. I have tried the generic NRF24 low and high power versions with no problems either way. The high power is the PA LNA type with the external antenna. The low power is what is in the picture down below.
                  Setting up the Arduino IDE was a bit of a chore but the instructions at > link < are very good.
                  At the end make sure you use the Boards Manager to install the MySensors AVR Boards (add MySensors to the search) so you can choose the "Sensebender Micro" as your 'board'. This last step isn't explicitly mentioned on the link. If that board isn't selected your results will be disappointing. I know from experience.
                  For the MySensors library be sure to install the latest release which is 2.2.0. I had to use the drop down list for the MySensors library in the Library Manager to install that version. But I l already had a lower version installed, plus a development release installed manually, and this was right around the official 2.2.0 release date, so who knows.
                  I run Windows 7 Professional SP1 and the Arduino IDE version 1.8.1. Updating the firmware via USB works fine. I have not tried OTA updates yet though I plan to. That should be interesting.
                  Your mileage may vary. I hope this helps anyone dipping their toe for the first time.
                  -d
                  • Mitja BlazinsekM
                    Mitja BlazinsekM
                    Mitja Blazinsek
                    i did all this i try even downgrade my sensor library and its same the interest thing that even other boards not working (arduino nano) a had some assembled and programmed nano that i play with about 6month ago and it work fine, then try to upload relay code on it and nothing everything (didn't touch wiring) i try to program it doesn't work even if it was working before, so i think it must be something with my arduino ide
                    • Mitja BlazinsekM
                      Mitja BlazinsekM
                      Mitja Blazinsek
                      reinstal arduino, libary, clear eprom nothing gonna lose my mind i think i'm gonna throw everything in trash :rage:
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @mitja-blazinsek how do you power your board? USB from pc? That might not work. Try a USB power supply instead. Or a different pc. Or a completely different power source, like batteries.
                        • Mitja BlazinsekM
                          Mitja BlazinsekM
                          Mitja Blazinsek
                          i just try this and its same
                          is it possible that is anythig with gw i'm using official sensebender gw
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @Mitja-Blazinsek
                            Just to be sure, you haven't used a customized channel / network address on the gateway, that you forgot to set on the nodes?
                              You could also try moving the node further away (5-10 m) from the gateway.
                              • Mitja BlazinsekM
                                Mitja BlazinsekM
                                Mitja Blazinsek
                                i try new serial gw on nano but same problem i delete all nodes and when i turn on some sensors my controller find it only one node without name. My only working sensor (one of the woking sensebender out the box) display 2 nodes one without name and node with sensebender micro name what for is that first node ID 0
                                screen shot how it display every sensor:
                                • Mitja BlazinsekM
                                  Mitja BlazinsekM
                                  Mitja Blazinsek
                                  now even sensbender micro that it work on sensbender gw don't work on my gw it work only if i connect sensbender gw
                                  • Mitja BlazinsekM
                                    Mitja BlazinsekM
                                    Mitja Blazinsek
                                    look like everything that i programmed not working about half years ago when i start with my sensors everything that i try work bu when i have time to play with mysensors again nothing worked make me crazy i have full box of sensors and boards but nothing cant get to work only sensbender gw and sensbender micro that i didn't touch i think that must be something with arduino ide
                                    • Mitja BlazinsekM
                                      Mitja BlazinsekM
                                      Mitja Blazinsek
                                      ok my gw now work sorry i forget to connect radio vcc :relaxed: but everything else not working every sensor i try triple check wiring bothing :rage:
                                        without any debug info nobody can help you
                                        • Mitja BlazinsekM
                                          Mitja BlazinsekM
                                          Mitja Blazinsek
                                          25 TSM:INIT
                                          26 TSF:WUR:MS=0
                                          33 TSM:INIT:TSP OK
                                          35 TSF:SID:OK,ID=56
                                          37 TSM:FPAR
                                          73 TSF:MSG:SEND,56-56-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2081 !TSM:FPAR:NO REPLY
                                          2083 TSM:FPAR
                                          2119 TSF:MSG:SEND,56-56-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          4127 !TSM:FPAR:NO REPLY
                                          4129 TSM:FPAR
                                          4165 TSF:MSG:SEND,56-56-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          6173 !TSM:FPAR:NO REPLY
                                          6175 TSM:FPAR
                                          6211 TSF:MSG:SEND,56-56-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          8219 !TSM:FPAR:FAIL
                                          8220 TSM:FAIL:CNT=1
                                          8222 TSM:FAIL:DIS
                                          8224 TSF:TDI:TSL
                                          18226 TSM:FAIL:RE-INIT```
