  3. 💬 Dimmable Led Strip board (MysX)
ledled stripmysx
10 Posts 7 Posters 3.6k Views 5 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/552/Dimmable-Led-Strip-board-MysX
    • xydixX Offline
      xydixX Offline
      xydix
      FYI...
      12v = Mosfet = irlz44n, Voltage Reg (12 to 5v) = LM2940CT-5
      24v = Mosfet = ???, Voltage reg (24 to 5v) = ???
      I think IRZL44N will handle 24V.
      S K 2 Replies Last reply
      • xydixX xydix
        FYI...
        @xydix thanks! This was on my to-do list to find out but it's great with a helpful community!
        • xydixX xydix
          FYI...
          K Offline
          K Offline
          korttoma
          @xydix said in 💬 MysX Led board:
          IRLZ44N > VDSS = 55V
          http://www.irf.com/product-info/datasheets/data/irlz44n.pdf
          • Tomas
          • A Offline
            A Offline
            Anticimex
            Cool. What MYSX version is used?
            S 1 Reply Last reply
            • A Anticimex
              @anticimex Well - its 2.4 header (mostly for stability) but its only actively 2.1 which is used so Im not sure.
              • simboS Offline
                simboS Offline
                simbo
                In your next rev, perhaps you increase the spacing between the voltage regulator and the MOFSET to accommodate heat sinks? The minimum would be 2.54mm.
                • simboS simbo
                  @simbo sure! I was thinking only the mosfet would need a heatsink so my plan was to attach it on the back. The maximum led strip I have is 2.5m and I didn't have to use any heatsink so didn't think much about it. Do you have some sort of heatsink link you prefer (with measurements) I can have a look at.
                  • Y Offline
                    Y Offline
                    yoshida
                    Hi, some -maybe- silly questions:
                    In the diagram you marked MysX connector number 9 as the "LED1", but that's the A5, and not the D3 where I see it is connected. (just asking this to be sure that I understand right the board, and the diagram)
                    So this is only a typo, right?
                    Other question is that I can use the mysensors LED dimmer example sketch with the rotary encoder with this board, right? It needs 4 digital pins, and MysX has 4: "D2, D3, D5, D6".
                    So I just have to replace in the sketch the #define KNOB_ENC_PIN_1 4 to #define KNOB_ENC_PIN_1 2?
                    "#define LED_PIN 3 // Arduino pin attached to MOSFET Gate pin
                    #define KNOB_ENC_PIN_1 4 // Rotary encoder input pin 1
                    #define KNOB_ENC_PIN_2 5 // Rotary encoder input pin 2
                    #define KNOB_BUTTON_PIN 6 // Rotary encoder button pin"
                    • Y yoshida
                      @yoshida hi!
                      Im not sure where you get that #9 should be A5? Looks right to me. The pin is connected to pin 9, and that is D3.
                      0_1535522995805_62649016-d746-4ccb-b360-4e8b7ee1405b-image.png 0_1535523011377_7f2024c3-afd9-49ee-bb02-95e6e45275a9-image.png
                      For a rotary encoder, it depends on your input - but don't you want an analog signal in? In that case you use the analog pins.
                      Edit: offcourse, if you use a module converting it to digital like described in the the build section you use a digital pin.
