  3. sending two messages one after another
7 Posts 5 Posters 2.0k Views 7 Watching
  • rozpruwaczR
    rozpruwaczR
    rozpruwacz
    in my node I send two messages with ack=1 one after another. And it seems that most of the times the second one gets NACK. Is it possible that the gateway ACK message for the first node message gets into collision with the second node message ? I'm using RFM69 as a transport, does this transport handle collisions by itself ?
      I could be, maybe you can add a little delay between sends if they get sent too quickly one after the other
      • rozpruwaczR
        rozpruwaczR
        rozpruwacz
        I implemented the message queue so the queue does not send another message until it gets ack from gateway. Now it seems that everything is ok.
        J 1 Reply Last reply
        • rozpruwaczR rozpruwacz
          J
          J
          jkandasa
          @rozpruwacz can you share your implementation details?
          • alowhumA
            alowhumA
            alowhum
            @rozpruwacz I'd love to see how you implemented that as well!
            • rozpruwaczR
              rozpruwaczR
              rozpruwacz
              wrote on last edited by rozpruwacz
              I have implemented it in form of library. The library is here https://github.com/mczerski/MySensorsToolkit and example project that uses this library is here https://github.com/mczerski/MyDimmer. The actual logic is implemented here https://github.com/mczerski/MySensorsToolkit/blob/master/src/MySensorsToolkit/Message.cpp
              This implementation is not using software ack because i do not use repeaters in my setup and i believe that for such setup software ack will make no difference.
              • A
                ArduiSens
                Hello all,
                is this solution added to the standard MySensor library?
                If so, in which version is it implemented?
                I want to be sure there are no missing messages when having a list of messages to be sent.
                many thanks in advance
                MySensors 2.3.2; contr:Domoticz; layer: RS485, nRF24; gw: Ethernet, Serial
