  3. Home Assistant
  4. Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it
36 Posts 5 Posters 6.9k Views 5 Watching
    The node is not receiving the reply from the gateway. Try moving it closer to gateway, or use the lower TX power settings
    Richard van der PlasR
    wrote on last edited by Richard van der Plas
    @gohan weird distance is 3 meters in clear air , it was working :(
    is has do do something with power and capacitors, connected a 3.3u one, and using a 2xaaa power supply with a DCDC stepup to 3.3 volt as in the manuals.
    what capacitors would you advice ?
      Try with fully charged alkaline batteries without the booster and see if it works better.
      Richard van der PlasR 1 Reply Last reply
        @gohan looks alot better indeed, powered the radio directly from the AAA batteries, and seems to work now, next step is why my voltage reading of the battery is way off :)
          Try using a ceramic cap on the booster output. I used 10uF without issues. As an alternative get the LiFePO4 batteries, get rid of booster and use vcc library to read battery voltage
            @gohan Small update, still weird things, everything works after a reboot, but after a short time, when toggling a switch in HA, nothing is send through the gateway?
            receives though work fine..
            snippet of the log, where the first sends are working, but then dead the send commands.
            Feb  6 22:01:53 raspberrypi mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            Feb  6 22:01:53 raspberrypi mysgw: TSF:MSG:PINGED,ID=3,HP=1
            Feb  6 22:01:53 raspberrypi mysgw: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            Feb  6 22:01:55 raspberrypi mysgw: TSF:MSG:READ,5-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:2
            Feb  6 22:01:55 raspberrypi mysgw: TSF:MSG:PINGED,ID=5,HP=2
            Feb  6 22:01:55 raspberrypi mysgw: TSF:MSG:SEND,0-0-3-5,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            Feb  6 22:02:02 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:02:02 raspberrypi mysgw: GWT:RFC:C=0,MSG=5;2;1;0;2;0
            Feb  6 22:02:02 raspberrypi mysgw: TSF:MSG:SEND,0-0-3-5,s=2,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
            Feb  6 22:02:02 raspberrypi mysgw: TSF:MSG:READ,5-3-0,s=2,c=1,t=2,pt=1,l=1,sg=0:0
            Feb  6 22:02:10 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
            Feb  6 22:02:12 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:02:18 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
            Feb  6 22:02:22 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:02:32 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:02:35 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
            Feb  6 22:02:42 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:02:46 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
            Feb  6 22:02:52 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:02:54 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
            Feb  6 22:03:02 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:03:03 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
            Feb  6 22:03:06 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
            Feb  6 22:03:12 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:03:21 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
            Feb  6 22:03:22 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:03:25 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
            Feb  6 22:03:32 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:03:32 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
            Feb  6 22:03:38 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
            Feb  6 22:03:42 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:03:45 raspberrypi mysgw: TSF:MSG:READ,5-3-0,s=1,c=1,t=0,pt=7,l=5,sg=0:-3.06
            Feb  6 22:03:45 raspberrypi mysgw: TSF:MSG:READ,5-3-0,s=0,c=1,t=16,pt=1,l=1,sg=0:0
            Feb  6 22:03:52 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
            Feb  6 22:03:53 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
            Feb  6 22:03:57 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
            Feb  6 22:03:58 raspberrypi mysgw: TSF:MSG:READ,3-3-0,s=3,c=1,t=0,pt=7,l=5,sg=0:1.0
              Are you sure it's not a controller problem? Try using something else like mycontroller or myscontroller and send something to the gateway
                @gohan is there a light weigth application to test this? or do i have to install a complete suite ?
                wouldt be handy if there's just a way to do a SEND command on the gateway
                  With myscontroller it is just a windows app where you can send anything you want to the gateway. Mycontroller it is just a Java program where you just launch the start script and configure a few simple parameters, nothing fancy but it is useful to have for multiple purposes.
                    @gohan said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
                    myscontroller
                    yes Mycontroller works as expected :), the issue lies in HA
                    • Richard van der PlasR Richard van der Plas
                      myscontroller
                      @gohan what i see is that the mysensors.json isnt updated with values of the different sensors on the node ?
                      log shows:
                      child_id 3 already exists in children of node 11, cannot add child
                      3:26 PM /srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py (WARNING)
                      child_id 2 already exists in children of node 11, cannot add child
                      child_id 1 already exists in children of node 11, cannot add child
                      Node 11 is unknown
                      3:25 PM /srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py (WARNING)
                      Small update, using the 2.1 library issues are not there so much
                        I moved it to the home assistant section. Let's hope somebody could help you out, I'm not HA expert
                        Richard van der PlasR Sergio RiusS 2 Replies Last reply
                          @gohan ty
                            Sergio RiusS
                            Sergio RiusS
                            Sergio Rius
                            Don't know if that is caused by the controller, by I'm having the same issue months ago but with domoticz.
                            When that happens, I've found that manually restarting the mys GW service makes it work again.
                            • Huỳnh Minh KhảiH
                              Huỳnh Minh KhảiH
                              Huỳnh Minh Khải
                              The same issue here and solved by changing my NRF24L01
                                A Former User
                                I have the same problem
                                pi 3 as gateway ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=ethernet --my-port=5003
                                logs gateway:
                                Mar 13 17:00:40 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:00:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:00:42 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:00:44 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:00:46 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:00:48 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=2,c=1,t=1,pt=7,l=5,sg=0:58.3
                                Mar 13 17:00:48 MySensorsGW mysgw: TSF:MSG:READ,5-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:00:49 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:00:52 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:00:59 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:01:02 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:01:09 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:01:12 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:01:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:01:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:01:29 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:01:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:01:39 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:01:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:01:49 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:01:52 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:01:59 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:02:02 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:02:09 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:02:12 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:02:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:02:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:02:29 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:02:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:02:39 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:02:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:02:49 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:02:52 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:02:59 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:03:02 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:03:09 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:03:12 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:03:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:03:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:03:29 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:03:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                communication stoped at Mar 13 17:00:49
                                When I try to switch a relay:
                                gateway:
                                Mar 13 17:06:15 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
                                Mar 13 17:06:15 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                                Mar 13 17:06:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:06:20 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
                                Mar 13 17:06:20 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                                Mar 13 17:06:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:06:25 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;4;1;0;2;1
                                Mar 13 17:06:25 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=4,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                                Mar 13 17:06:28 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
                                Mar 13 17:06:28 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                                Mar 13 17:06:30 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:06:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:06:34 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
                                Mar 13 17:06:34 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                                Mar 13 17:06:36 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;4;1;0;2;1
                                Mar 13 17:06:36 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=4,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                                Mar 13 17:06:39 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:06:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                node:
                                9839799 TSF:TDI:TSL
                                9899802 TSM:FAIL:RE-INIT
                                9899804 TSM:INIT
                                9899811 TSM:INIT:TSP OK
                                9899813 TSM:INIT:STATID=11
                                9899816 TSF:SID:OK,ID=11
                                9899819 TSM:FPAR
                                9899855 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                9901864 !TSM:FPAR:NO REPLY
                                9901867 TSM:FPAR
                                9901903 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                9903912 !TSM:FPAR:NO REPLY
                                9903915 TSM:FPAR
                                9903951 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                9905960 !TSM:FPAR:NO REPLY
                                9905963 TSM:FPAR
                                9905999 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                9908008 !TSM:FPAR:FAIL
                                9908011 TSM:FAIL:CNT=7
                                9908013 TSM:FAIL:DIS
                                9908015 TSF:TDI:TSL
                                pi@MySensorsGW:~ $ systemctl is-active mysgw.service
                                active
                                When I restart the gateway service everything is back OK
                                pi@MySensorsGW:~ $ sudo systemctl restart mysgw.service
                                pi@MySensorsGW:~ $ tail -f /var/log/syslog
                                Mar 13 17:21:55 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=6
                                Mar 13 17:21:55 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
                                Mar 13 17:21:55 MySensorsGW mysgw: TSF:MSG:GWL OK
                                Mar 13 17:21:56 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:BC
                                Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=6
                                Mar 13 17:21:57 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
                                Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:GWL OK
                                Mar 13 17:21:58 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                Mar 13 17:22:01 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                Mar 13 17:22:01 MySensorsGW mysgw: TSF:MSG:PINGED,ID=6,HP=1
                                Mar 13 17:22:01 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                Mar 13 17:22:03 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                Mar 13 17:22:03 MySensorsGW mysgw: TSF:MSG:PINGED,ID=6,HP=1
                                Mar 13 17:22:03 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                Mar 13 17:22:05 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:07 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:09 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:BC
                                Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=7
                                Mar 13 17:22:11 MySensorsGW mysgw: TSF:PNG:SEND,TO=0
                                Mar 13 17:22:11 MySensorsGW mysgw: TSF:CKU:OK
                                Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:GWL OK
                                Mar 13 17:22:12 MySensorsGW mysgw: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                Mar 13 17:22:12 MySensorsGW mysgw: New connection from 192.168.0.51
                                Mar 13 17:22:12 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
                                Mar 13 17:22:12 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:13 MySensorsGW mysgw: GWT:TSA:C=0,DISCONNECTED
                                Mar 13 17:22:13 MySensorsGW mysgw: Ethernet client disconnected.
                                Mar 13 17:22:13 MySensorsGW mysgw: New connection from 192.168.0.51
                                Mar 13 17:22:13 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
                                Mar 13 17:22:14 MySensorsGW mysgw: New connection from 192.168.0.35
                                Mar 13 17:22:14 MySensorsGW mysgw: GWT:TSA:C=1,CONNECTED
                                Mar 13 17:22:14 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:22:14 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:16 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:BC
                                Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=7
                                Mar 13 17:22:17 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
                                Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:GWL OK
                                Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                Mar 13 17:22:19 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:READ,11-11-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:BC
                                Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=11
                                Mar 13 17:22:20 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
                                Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:GWL OK
                                Mar 13 17:22:21 MySensorsGW mysgw: TSF:MSG:SEND,0-0-11-11,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                Mar 13 17:22:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:READ,11-11-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:PINGED,ID=11,HP=1
                                Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:SEND,0-0-11-11,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                Mar 13 17:22:24 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:22:24 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:26 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:28 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:30 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 17:22:32 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:34 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 17:22:34 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:36 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:38 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:40 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 17:22:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                  what version are you using?
                                  ? 1 Reply Last reply
                                    A Former User
                                    @gohan
                                    My last node (8-relay) 2.2.0
                                    my gateway RPi3 git clone https://github.com/mysensors/MySensors.git --branch master
                                    I think I have some other nodes on 2.0.0
                                      A Former User
                                      sometimes I see this in my gateway log
                                      Mar 13 17:42:32 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                                        @gieljnssns said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
                                        that looks like the message got lost between the gw and node. You could try moving the node closer or using a repeater halfway. Pls write the gw version since the git-clone is not telling me much
                                          A Former User
                                          @gohan
                                          how can I see wich version I'm using?
