  3. Home Assistant
  4. Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it
36 Posts 5 Posters 6.8k Views 5 Watching
    With myscontroller it is just a windows app where you can send anything you want to the gateway. Mycontroller it is just a Java program where you just launch the start script and configure a few simple parameters, nothing fancy but it is useful to have for multiple purposes.
    Richard van der PlasR 1 Reply Last reply
      @gohan said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
      myscontroller
      yes Mycontroller works as expected :), the issue lies in HA
      • Richard van der PlasR Richard van der Plas
        myscontroller
        wrote on last edited by Richard van der Plas
        @gohan what i see is that the mysensors.json isnt updated with values of the different sensors on the node ?
        log shows:
        child_id 3 already exists in children of node 11, cannot add child
        3:26 PM /srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py (WARNING)
        child_id 2 already exists in children of node 11, cannot add child
        child_id 1 already exists in children of node 11, cannot add child
        Node 11 is unknown
        3:25 PM /srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py (WARNING)
        Small update, using the 2.1 library issues are not there so much
          I moved it to the home assistant section. Let's hope somebody could help you out, I'm not HA expert
          Richard van der PlasR Sergio RiusS 2 Replies Last reply
            @gohan ty
              Sergio RiusS
              Sergio RiusS
              Sergio Rius
              Don't know if that is caused by the controller, by I'm having the same issue months ago but with domoticz.
              When that happens, I've found that manually restarting the mys GW service makes it work again.
              • Huỳnh Minh KhảiH
                Huỳnh Minh KhảiH
                Huỳnh Minh Khải
                The same issue here and solved by changing my NRF24L01
                  A Former User
                  I have the same problem
                  pi 3 as gateway ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=ethernet --my-port=5003
                  logs gateway:
                  Mar 13 17:00:40 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:00:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:00:42 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:00:44 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:00:46 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:00:48 MySensorsGW mysgw: TSF:MSG:READ,6-11-0,s=2,c=1,t=1,pt=7,l=5,sg=0:58.3
                  Mar 13 17:00:48 MySensorsGW mysgw: TSF:MSG:READ,5-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:00:49 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:00:52 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:00:59 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:01:02 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:01:09 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:01:12 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:01:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:01:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:01:29 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:01:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:01:39 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:01:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:01:49 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:01:52 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:01:59 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:02:02 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:02:09 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:02:12 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:02:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:02:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:02:29 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:02:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:02:39 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:02:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:02:49 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:02:52 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:02:59 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:03:02 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:03:09 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:03:12 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:03:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:03:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:03:29 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:03:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  communication stoped at Mar 13 17:00:49
                  When I try to switch a relay:
                  gateway:
                  Mar 13 17:06:15 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
                  Mar 13 17:06:15 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                  Mar 13 17:06:19 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:06:20 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
                  Mar 13 17:06:20 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                  Mar 13 17:06:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:06:25 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;4;1;0;2;1
                  Mar 13 17:06:25 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=4,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                  Mar 13 17:06:28 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
                  Mar 13 17:06:28 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                  Mar 13 17:06:30 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:06:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:06:34 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;3;1;0;2;1
                  Mar 13 17:06:34 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                  Mar 13 17:06:36 MySensorsGW mysgw: GWT:RFC:C=0,MSG=11;4;1;0;2;1
                  Mar 13 17:06:36 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-11-11,s=4,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:1
                  Mar 13 17:06:39 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:06:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  node:
                  9839799 TSF:TDI:TSL
                  9899802 TSM:FAIL:RE-INIT
                  9899804 TSM:INIT
                  9899811 TSM:INIT:TSP OK
                  9899813 TSM:INIT:STATID=11
                  9899816 TSF:SID:OK,ID=11
                  9899819 TSM:FPAR
                  9899855 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  9901864 !TSM:FPAR:NO REPLY
                  9901867 TSM:FPAR
                  9901903 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  9903912 !TSM:FPAR:NO REPLY
                  9903915 TSM:FPAR
                  9903951 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  9905960 !TSM:FPAR:NO REPLY
                  9905963 TSM:FPAR
                  9905999 TSF:MSG:SEND,11-11-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  9908008 !TSM:FPAR:FAIL
                  9908011 TSM:FAIL:CNT=7
                  9908013 TSM:FAIL:DIS
                  9908015 TSF:TDI:TSL
                  pi@MySensorsGW:~ $ systemctl is-active mysgw.service
                  active
                  When I restart the gateway service everything is back OK
                  pi@MySensorsGW:~ $ sudo systemctl restart mysgw.service
                  pi@MySensorsGW:~ $ tail -f /var/log/syslog
                  Mar 13 17:21:55 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=6
                  Mar 13 17:21:55 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
                  Mar 13 17:21:55 MySensorsGW mysgw: TSF:MSG:GWL OK
                  Mar 13 17:21:56 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:READ,6-6-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:BC
                  Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=6
                  Mar 13 17:21:57 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
                  Mar 13 17:21:57 MySensorsGW mysgw: TSF:MSG:GWL OK
                  Mar 13 17:21:58 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  Mar 13 17:22:01 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  Mar 13 17:22:01 MySensorsGW mysgw: TSF:MSG:PINGED,ID=6,HP=1
                  Mar 13 17:22:01 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  Mar 13 17:22:03 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  Mar 13 17:22:03 MySensorsGW mysgw: TSF:MSG:PINGED,ID=6,HP=1
                  Mar 13 17:22:03 MySensorsGW mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  Mar 13 17:22:05 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:07 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:09 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:BC
                  Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=7
                  Mar 13 17:22:11 MySensorsGW mysgw: TSF:PNG:SEND,TO=0
                  Mar 13 17:22:11 MySensorsGW mysgw: TSF:CKU:OK
                  Mar 13 17:22:11 MySensorsGW mysgw: TSF:MSG:GWL OK
                  Mar 13 17:22:12 MySensorsGW mysgw: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  Mar 13 17:22:12 MySensorsGW mysgw: New connection from 192.168.0.51
                  Mar 13 17:22:12 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
                  Mar 13 17:22:12 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:13 MySensorsGW mysgw: GWT:TSA:C=0,DISCONNECTED
                  Mar 13 17:22:13 MySensorsGW mysgw: Ethernet client disconnected.
                  Mar 13 17:22:13 MySensorsGW mysgw: New connection from 192.168.0.51
                  Mar 13 17:22:13 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
                  Mar 13 17:22:14 MySensorsGW mysgw: New connection from 192.168.0.35
                  Mar 13 17:22:14 MySensorsGW mysgw: GWT:TSA:C=1,CONNECTED
                  Mar 13 17:22:14 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:22:14 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:16 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:BC
                  Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=7
                  Mar 13 17:22:17 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
                  Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:GWL OK
                  Mar 13 17:22:17 MySensorsGW mysgw: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  Mar 13 17:22:19 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:READ,11-11-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:BC
                  Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:FPAR REQ,ID=11
                  Mar 13 17:22:20 MySensorsGW mysgw: TSF:CKU:OK,FCTRL
                  Mar 13 17:22:20 MySensorsGW mysgw: TSF:MSG:GWL OK
                  Mar 13 17:22:21 MySensorsGW mysgw: TSF:MSG:SEND,0-0-11-11,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  Mar 13 17:22:22 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:READ,11-11-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:PINGED,ID=11,HP=1
                  Mar 13 17:22:22 MySensorsGW mysgw: TSF:MSG:SEND,0-0-11-11,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  Mar 13 17:22:24 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:22:24 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:26 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:28 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:30 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:32 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                  Mar 13 17:22:32 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:34 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                  Mar 13 17:22:34 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:36 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:38 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:40 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                  Mar 13 17:22:42 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                    what version are you using?
                    ? 1 Reply Last reply
                      A Former User
                      @gohan
                      My last node (8-relay) 2.2.0
                      my gateway RPi3 git clone https://github.com/mysensors/MySensors.git --branch master
                      I think I have some other nodes on 2.0.0
                        A Former User
                        sometimes I see this in my gateway log
                        Mar 13 17:42:32 MySensorsGW mysgw: !TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                          @gieljnssns said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
                          that looks like the message got lost between the gw and node. You could try moving the node closer or using a repeater halfway. Pls write the gw version since the git-clone is not telling me much
                            A Former User
                            @gohan
                            how can I see wich version I'm using?
                              when GW starts it prints the version in log
                                A Former User
                                @gohan
                                version 2.2.0
                                Mar 13 18:36:04 MySensorsGW systemd[1]: Stopping MySensors Gateway daemon...
                                Mar 13 18:36:04 MySensorsGW systemd[1]: Stopped MySensors Gateway daemon.
                                Mar 13 18:36:04 MySensorsGW systemd[1]: Started MySensors Gateway daemon.
                                Mar 13 18:36:04 MySensorsGW mysgw: Starting gateway...
                                Mar 13 18:36:04 MySensorsGW mysgw: Protocol version - 2.2.0
                                Mar 13 18:36:04 MySensorsGW mysgw: MCO:BGN:INIT GW,CP=RNNGL-Q-,VER=2.2.0
                                Mar 13 18:36:04 MySensorsGW mysgw: TSF:LRT:OK
                                Mar 13 18:36:04 MySensorsGW mysgw: TSM:INIT
                                Mar 13 18:36:04 MySensorsGW mysgw: TSF:WUR:MS=0
                                Mar 13 18:36:04 MySensorsGW mysgw: TSM:INIT:TSP OK
                                Mar 13 18:36:04 MySensorsGW mysgw: TSM:INIT:GW MODE
                                Mar 13 18:36:04 MySensorsGW mysgw: TSM:READY:ID=0,PAR=0,DIS=0
                                Mar 13 18:36:04 MySensorsGW mysgw: MCO:REG:NOT NEEDED
                                Mar 13 18:36:04 MySensorsGW mysgw: Listening for connections on 0.0.0.0:5003
                                Mar 13 18:36:04 MySensorsGW mysgw: MCO:BGN:STP
                                Mar 13 18:36:04 MySensorsGW mysgw: MCO:BGN:INIT OK,TSP=1
                                Mar 13 18:36:04 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:06 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:08 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:10 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:12 MySensorsGW mysgw: TSF:MSG:READ,5-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:12 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:12 MySensorsGW mysgw: TSF:MSG:READ,3-3-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:14 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:16 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:18 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:19 MySensorsGW mysgw: TSF:MSG:READ,2-11-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:19 MySensorsGW mysgw: New connection from 192.168.0.51
                                Mar 13 18:36:19 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
                                Mar 13 18:36:20 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:21 MySensorsGW mysgw: TSF:MSG:READ,1-1-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:21 MySensorsGW mysgw: TSF:MSG:READ,2-11-0,s=1,c=1,t=0,pt=7,l=5,sg=0:17.0
                                Mar 13 18:36:21 MySensorsGW mysgw: TSF:MSG:READ,2-11-0,s=2,c=1,t=1,pt=7,l=5,sg=0:38.0
                                Mar 13 18:36:22 MySensorsGW mysgw: GWT:TSA:C=0,DISCONNECTED
                                Mar 13 18:36:22 MySensorsGW mysgw: Ethernet client disconnected.
                                Mar 13 18:36:22 MySensorsGW mysgw: New connection from 192.168.0.51
                                Mar 13 18:36:22 MySensorsGW mysgw: GWT:TSA:C=0,CONNECTED
                                Mar 13 18:36:22 MySensorsGW mysgw: New connection from 192.168.0.35
                                Mar 13 18:36:22 MySensorsGW mysgw: GWT:TSA:C=1,CONNECTED
                                Mar 13 18:36:22 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                Mar 13 18:36:22 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:24 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:26 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=2,c=1,t=1,pt=7,l=5,sg=0:60.1
                                Mar 13 18:36:26 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:28 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:29 MySensorsGW mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                                Mar 13 18:36:30 MySensorsGW mysgw: TSF:MSG:READ,6-6-0,s=3,c=1,t=16,pt=0,l=1,sg=0:0
                                Mar 13 18:36:32 MySensorsGW mysgw: GWT:RFC:C=1,MSG=0;255;3;0;2;
                                  A Former User
                                  There is only 4 meter in between my gateway and node.
                                  @huỳnh-minh-khải said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
                                  I've already changed my radio
                                    Do you have a decent capacitor on the radio module? Have you tried a different maker of nrf24 module?
                                      A Former User
                                      @gohan
                                      I have these radios https://www.ebay.com/itm/400594940658?rmvSB=true
                                      I've used this adapter plate for my radio https://www.ebay.com/itm/200960749614?rmvSB=true
                                      And there is a capacitor on my radio
                                        I don't like those nrf24 modules as they are 99% fake clones. Once I got some real ones I solved a lot of range issues
                                          A Former User
                                          @gohan
                                          Can you give me a link to the real ones?
