  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.5k Views 42 Watching
  • V vikasjee
    No help from the community! Sad!!!
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    #149
    @vikasjee Apologies for the late reply - I have no idea what's the issue with your setup - my guess is that something is wrong with the fuses and/or wrong .hex used: Can you post the MYSController log, used fuse settings and any other important information?
    • W
      W
      wanvo
      @tekka thanks for the answer. I'm still a newbie.
      Now I can not make a contribution to the development due to my incompetence.
      I can help as a tester :)
      • J jacikaas
        @tekka thank You for the answer. I'm not sure is answer was dedicated for me or for Mark, but I tested 1.3.0-beta.4 in the same way I described before:
        • Tested with 2 different Atmega328p
        • First try was with 1MHz - working on both Atmega328p
        • Second try with 8MHz - same situation as with beta 3, skecth won't upload and I get answer from Arduino Avrdude (this time I post full log after uploading):
        avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
                 Overriding Baud Rate          : 38400
        avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf1
        avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf1
        avrdude done.  Thank you.
        It would be best if someone also could try to burn same bootloader on standalone Atmega328p and post results to be sure all wiring and steps I did is without mistakes.
        Strange if I I burn 1.3pre2 8MHz bootloader - it works.
        What troubleshooting I could make?
        J
        J
        jacikaas
        @jacikaas
        Hello, maybe someone was trying 8MHz bootloader for standlaone Atmega328p?
        • C
          C
          cdr
          Anyone seen this error on latest 1.3 release? It seems a define is not done for F_CPU, what am I missing here?
          Generating function prototypes...
          In file included from C:\Program Files (x86)\Arduino\portable\sketchbook\libraries\MySensors/MySensors.h:371:0,
          from C:\Program Files (x86)\Arduino\portable\sketchbook\libraries\MySensors\examples\GatewayW5100MQTTClient\GatewayW5100MQTTClient.ino:138:
          C:\Program Files (x86)\Arduino\portable\sketchbook\libraries\MySensors/core/MyTransport.cpp:777:42: error: operator '>' has no left operand
           #if defined(MY_GATEWAY_FEATURE) && (F_CPU>16000000)
          In file included from C:\Program Files (x86)\Arduino\portable\sketchbook\libraries\MySensors/MySensors.h:396:0,
          C:\Program Files (x86)\Arduino\portable\sketchbook\libraries\MySensors/core/MySensorsCore.cpp:479:11: error: operator '>' has no left operand
           #if (F_CPU>16000000)
          exit status 1
          Error compiling for board ATmega328 with MYSBootloader 1.3.0.
          Regards
          H T 2 Replies Last reply
          • C cdr
            exit status 1
            Regards
            H
            H
            Henry
            @cdr Same Problem here!
            Greetz Henry
            • C cdr
              exit status 1
              Regards
              tsjoender
              @cdr @Henry I ran into the same issue. Turned out to be a syntax issue in the boards.txt file. If you change:
              MYSBL.menu.frequency.MYSBL16.f_cpu=16000000L
              into
              MYSBL.menu.frequency.MYSBL16.build.f_cpu=16000000L
              Then it works again. Adding build. needs to be done for the other menu entries as well.
              H C 2 Replies Last reply
              • T tsjoender
                into
                H
                H
                Henry
                @tsjoender
                PERFEKT!!! thx!!!
                • T tsjoender
                  into
                  C
                  C
                  cdr
                  @tsjoender said in MYSBootloader 1.3.0-beta.3:
                  into
                  thanks a lot!
                  • tekkaT
                    tekkaT
                    tekka
                    Fix: https://github.com/mysensors/MySensorsBootloaderRF24/pull/24
                    Thanks for reporting.
                    • thmT
                      thmT
                      thm
                      I am currently testing the OTA features with a "My Slim 2AA Battery Node", MYSBootloader 1.3.0-rc.1, MYSController Build 3316 and the original example sketch "PassiveNode" (MySensors 2.2.0). Unfortunately, no reboot will be performed if I want to execute it via the MYSController. Even with a firmware update, no reboot is performed. If I disconnect the sensor from the battery and reconnect, the firmware update will be executed. Am I doing something wrong or is this a software bug?
                      Regards
                      Thomas
                        Try using smartsleep instead of usual sleep
                        • thmT
                          thmT
                          thm
                          Hello, thank you. It basically works with smartSleep. I only have to press the FW update or reboot button several times. After several attempts, the desired action is then executed.
                          Regards Thomas
                          • P
                            P
                            patrikr76
                            wrote on last edited by patrikr76
                            #161
                            Hello.
                            First, thanks to everybody developing all the stuff that is here, these are awesome projects and sorry to resurrect an old thread.
                            Second, i am trying to use the firmware update feature from MYSController, build 3316, with MYSBootloader, 1.3.0-rc1 8MHz, on a barebone atmega 328pu 28dip .
                            The device is running a simple thermistor sketch and reports happily to my RPi running MySensors ethernet gateway version 2.3.1-alpha(I have tried with version 2.2.0 as well).
                            I get the "reboot" screen if i choose the firmware after setting the device as a "Board with MYSBootloader" and the device clearly reboots but does not start any firmware download.
                            And of course, i am running nrf24l01+. Device is batterypowered from an 18650 li-ion, through a mcp1700 LDO 3.3v 250mA. 10uF on the nrf between vcc and gnd.
                            Device is set to sleep for 60 secs, but is also set to smartsleep for 500ms, as i read somewhere had solved other peoples issues.
                            Edit: I believe i was being stupid as i first burned the bootloader using arduino as isp and then burned the sketch, alas, erasing bootloader.
                            tekkaT 1 Reply Last reply
                            • P patrikr76
                              Hello.
                              tekkaT
                              tekkaT
                              tekka
                              @patrikr76 Yes, sounds like you erased MYSBootloader when uploading the sketch via ISP. Please post the MYSController log (starting before you reboot the node until the node is up an running) to verify this assumption.
                              • berkseoB
                                berkseoB
                                berkseo
                                Hello, everyone. Has anyone ever encountered a problem where after a power surge the device on this bootloader stops working? When I first encountered this, I did some tests. They're confirmed. This applies only to network devices. With the battery there are no such problems at all. So I had to switch to DuaiOptiboot. All stable. I do a bit of home programming :) so I don't think the problem is on my side, simple bugs are excluded.
                                • berkseoB berkseo
                                  tekkaT
                                  tekkaT
                                  tekka
                                  #164
                                  @berkseo Can you share additional details regarding your tests, ideally including logs that showed the proper function of the bootloader before the surge and after - what tool are you using for OTA updates?
                                  berkseoB 1 Reply Last reply
                                    #165
                                    @berkseo
                                    +1 for more details please, regarding hw and the power supply, mcu, fuses too.
                                    weird problem.. it works on batt but not on AC?? how do you replicate these power surge?
                                    if you have AC powered nodes sensible to power surge, transcient, I would add a TVS diode on the dc power supply side, and I would protect signals if needed. adding some filtering does not hurt too, pcb gnd isolation/shielding plane as well.
                                    Because, "even if" there is something related to mys bootloader, it seems also related to surge protection..
                                    • tekkaT tekka
                                      berkseoB
                                      berkseoB
                                      berkseo
                                      @tekka said in MYSBootloader 1.3.0-beta.3:
                                      Now not many can to share on the subject. We need to reproduce the problem again. OTA through the Majordomo system. But it's not about the update. The device died during a power surge, a feeling that was in the mode of receiving firmware due to the jump. Only re-recording the bootloader helped restore the device.
                                      • scalzS scalz
                                        @berkseo
                                        berkseoB
                                        berkseoB
                                        berkseo
                                        #167
                                        @scalz The problem was seen when the voltage surge in the network. It was later reproduced using supercapacitors. Let's try to reproduce the problem as follows: power the unit from 3.3 V, hang the supercapacitor on 1F in parallel and the led on the power through the 1K resistor, wait until the supercapacitor is charged, then wait for the discharge and on the verge of turning off ~ 2V, apply power pulses. I can't debug it right now. Will time will make. Bootloader latest version.
                                        There was a filter and a stabilizer. power surges are in principle excluded
                                          mafe
                                          can the bootloader also be used on an Atmega32U4? After programming, the Atmega is no longer recognized by the Usb port of the PC. Should programming via the IDE (Arduino, PlatformIO) still be possible or will it only work via MyController?
