  2. Feature Requests
  3. Would You Like Support For ESP8266 'Nodes'?
Scheduled Pinned Locked Moved Feature Requests
34 Posts 6 Posters 9.1k Views 5 Watching
  • AffordableTechA
    AffordableTechA
    AffordableTech
    @scalz said in Would You Like Support For ESP8266 'Nodes'?:
    which post was it ??
    The post just before mine: https://forum.mysensors.org/topic/6935/esp8266-as-mysensors-nodes-instead-of-arduino-nrf24l01/4
    when you say people use espeasy because esp nodes not available in mysensors (in your other post)
    That's news to me, no idea where I stated that? I can only recall mentioning EspEasy when I stated a MySensors user wanting ESP nodes was told to try EspEasy (read it for yourself in the link above). Somewhere I did say the difficulty of having to use the MQTT workaround and having to setup a computer with Mosquito was causing people to abandon MySensors, which I know to be a fact and can substantiate. Personally, I can't see any reason why someone would use EspEasy, and I'd certainly discourage anyone considering it.
    Regarding the AliExpress suggestion, I appreciate the tip. Not understanding the differences between the various 5x, I'm reluctant to buy something without knowing it's suitable for MySensors. The only device that I've seen that I could confirm would run MySensors core was the RedBear board and another $69 module on eBay. If you have a specific AliExpress chip number or module reference, I'd appreciate that.
    Cheers,
    Paul
    • K kimot
      @affordabletech
      And now have you got network, where RF nodes can directly communicate with RS485 nodes without controller?
      I think no.
      AffordableTechA
      AffordableTechA
      AffordableTech
      @kimot said in Would You Like Support For ESP8266 'Nodes'?:
      I think no.
      Where did you read that? I can't imagine anyone here making a statement like that. Certainly nobody has said that in this topic.
      gohanG K M 3 Replies Last reply
      • AffordableTechA AffordableTech
        I think no.
        @affordabletech did you look at https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action ?
          I think no.
          K
          K
          kimot
          @affordabletech
          I've been told "the focus of MySensors is on RF and RS-485 communications", whereas I always thought MySensors was about an 'open and practical Home Automation ....
          Normally, nodes on different "media" cannot talk each to other.
          So you need write code for some "super gateway", which integrate RF, RS485 and wifi, to receive data from one media and resend it to other media or to controller.
          Then I suggest PJON protocol, which support synchronous and for this purpose useful asynchronous ACK and different network ID.
          Or put some UPS on your windows controller.
          gohanG 1 Reply Last reply
          • K kimot
            @affordabletech
            @kimot I think you misunderstood what he meant.
            K 1 Reply Last reply
              K
              K
              kimot
              wrote on last edited by kimot
              #29
              @gohan
              I think he wants integrate ESP8266 to be able talk directly to other MySensors nodes.
              Here is his answer:
              *Yes, I've had to do that for a couple of ESP8266 nodes I added recently, but the problem with that work-around is that those nodes are not really part of the network. They are 'isolated' because they bypass the gateway and cannot talk / interact with other nodes, so you no longer have an 'integrated home automation network' and it can quickly become a 'disjointed collection of random nodes'.
              A lot of thought was put into the design of my system so that many of my nodes communicate direct with each other; if nodes have to depend on the controller to do their job, the system doesn't work if the controller is temporarily off-line..... *
                I think no.
                marceloaqno
                Code Contributor
                @affordabletech Playing with custom transport isn't that hard. Here is an unfinished example if you want to follow this path (sorry, I did it in a hurry, so maybe it isn't very self explanatory):
                https://github.com/marceloaqno/MySensors/commit/696d0d3993d88b2dc4565db6cb12f57a461372ad
                I think there has never been much interest in creating an ethernet transport before, given the fact that mysensors don't support multiple transports. But there is some work being done to change that.
                Building a node-to-node network using Ethernet with a standard client-server topology wouldn't be an easy task, I don't know how you intend to do it, but MQTT could help you with that.
                • AffordableTechA
                  AffordableTechA
                  AffordableTech
                  @marceloaqno ppp
                  Thanks for the link, I really appreciate the constructive attitude. It might just be what I need to take the plunge and dive in...
                  I'll have a look and get back to you.
                  Paul
                    #32
                    @AffordableTech
                    in aliexpress, type "nrf51822" or "nrf52832", and you'll find lot of different dev boards, "final" products etc.. few bucks and more. There is also adafruit, sparkfun (> 15$ .. I agree), or even an original nordic nrf5x dev board is 40$, worth it for dev.
                    it works in MySensors https://www.openhardware.io/view/376/MySensors-NRF5-Platform
                    • nrf52832: more ios, more peripherals, nfc+ ble or ESB(rf24 compatible mode), very low power. and soon nrf52840 will provide more range (integrated pa), integrated usb, 5v tolerant etc.
                    • esp8266 ?? wifi ? power hungry. limited ios and peripheral. else it's fun "toy" to play and tinker, I agree. I have a bunch of them that I won't never use I think :confused:
                    I'm not telling to give up on your esp or "go else where" (though, I haven't read the user said that in the other post, he was just trying to help with what he knows is available).
                    If you ask me, I prefer esp32 instead of esp8266.. I'm using esp32 for gw/bridge only, personally I think it's dumb to use wifi nodes for everything. I imagine people wanting that, would be mainly for convenience, money maybe or because they don't know pros&cons and alternatives.
                    +1 for marcelo comment above
                    Lack of time is main problem. So why not helping us, you're welcome! the more features in MySensors, the more fun, and .. the more maintenance :grimacing:
                    Edit: I didn't see your reply above, great to hear ;)
                    • AffordableTechA
                      AffordableTechA
                      AffordableTech
                      wrote on last edited by AffordableTech
                      #33
                      Thanks @scalz,
                      A very helpful an welcoming reply.
                      Im no great fan of ESP, particularly becuse of its lack of i/o but it seems ideal for a simple node wirh one switch or I2C sensir.
                      Here (in Australia) Adafruit and Spark fun products are 200% to 300% higher than US price. I get stuff direct from them when I need qty, but fir 1 or 2 boards, the shipping is just too expensive. So yes, an Adafruit or Spark 5x here is $65.
                      Anyhow, I will be checking out AliExpress - thanks!
                      If I can contribute, I will, I'm so happy with my HA, I want to see everyone experiencing what a truly 'smart home' is about. Hardware vendors push their own idea of smart home, but many dont want to share data with competitors products. Sharing data etc is what makes o.s. projects so great. If I can create, or help to create an ethernet based nodes, that would be fantastic as I know how good it is if a simple MySensors temp sensor could switch on a heater 'direct' without having to rely on a controller.
                      The reason u think this is good, is because little micro processors just seem to do their job year after year, without maintenance, as long as you feed them 'volts'. Complex controllers just are not as reliable.
                      My water heater is controlled by Arduino which saves me $1,200 pa at least. My hot water now costs 35 cents a day (because it knows my patterns), whereas it usdd to cost $2 to $3 per day keeping it at 55 deg c (thermostats often not adjustable in Oz).
                      I just need 40 deg most of the day (for hand wash etc) and a 'boost' to 55 deg just before my shower/bath. If I want a shower at an 'unusual' time, I have a 'boost' button on my phone or PC and 15 min later water is HOT!. $1200+ for the occasional inconvenience of waiting 15 min is fine 'smart' by me.
                      Cheers,
                      Paul....
                      AffordableTechA 1 Reply Last reply
                        Thanks @scalz,
                        Cheers,
                        Paul....
                        AffordableTechA
                        AffordableTechA
                        AffordableTech
                        TO ALL IN THIS TOPIC
                        I though it was appropriate I acknowledge that I now realise I misunderstood there was anti-ESP sentiment here, its more a case of just too busy to jump onto every idea mentioned. Like a few others who spoke to me, I failed to make an official request, therefore until I did and was told err.. 'where to go', I should not have assumed anything.
                        There was never any ill intention, just frustration as I probably love MySensors as much as anybody else here. Like everyone, I have real time restraints, but if I can conribute, I will.
                        My thanks to everyone who has taken the time to comment.
                        Paul
