  3. Best CNC for milling/routing wood?
39 Posts 8 Posters 12.1k Views 8 Watching
    Looks very nice. The rack and pinion approach does seem appealing. What a pity that rawcnc doesn't sell a complete kit. I don't see much leverage in having just the plans and then needing to source every single part individually from who knows where, only to hope it all fits together.
    The Shapeoko XXL is in the ballpark, but it does use a timing belt instead of the rack and pinion.
    dbemowskD
    dbemowskD
    @neverdie For 3D printing, belts are fine. When you are dragging a router around, you would think that the belts would stretch over time and become loose.
    • E
      E
      executivul
      6040 ebay cnc, ball screw version, water cooled 2kw spindle (24k rpm)
        This looks interesting:
        https://www.aliexpress.com/store/product/Openbuilds-OX-CNC-Router-Machine-OOZNEST-OX-CNC-Mechanical-Kit-with-4pcs-Nema-23-stepper-motor/1752067_32844841150.html?spm=2114.12010612.0.0.703b718fhDsf0q
        Seems like it might be a lot less expensive, when fitted out, than the Shapeko XXL, but a comparable build area.
        For comparison, here is the Shapeko: https://shop.carbide3d.com/products/shapeoko-xl-kit?variant=42721947206
          Interesting video that throws mud on a number of the branded kits you might buy:
          https://youtu.be/TSTThLM8s8o
          He bought a couple kits, but ended up making his own, almost from scratch. He concludes that none of the kits that he's aware of are worth recommending.
          It confirmed my suspicions about unsupported rails.
          scalzS 1 Reply Last reply
          • bjornhallbergB
            bjornhallbergB
            bjornhallberg
            The RawCNC uses rods that are glued or pressed into a shaft clamp and then a u-groove bearing on top of that.
              @neverdie said in Best CNC for milling/routing wood?:
              unfortunately yes :) the same point in 3d printer field..
              @bjornhallberg that's a nice machine, I didn't notice that one, looks strong, thx for the tip :+1: Will take a look at the build
                This guy made his own CNC, and he went balls out on making it as stiff as possible:
                https://youtu.be/DBm9c_TrH2g
                It does indeed look very sturdy. The end result is massive, though, and so he uses relatively large motors to move it.
                He did do a smart thing though which was ordering his extrusions from 80/20, who, it seems, did the cutting and drilling according to his instructions and so delivered the frame ready for final assembly.
                  bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  @neverdie Yeah that is a surprisingly good machine as it seems to be built from scratch with no plans or whatnot. It says in the Youtube comments that he spent $4K-4.5K on it though, with 1K of that being for the extra cost of servos as compared to steppers. Nice to have those linear rails and ball screws though.
                  By comparison the machine we're building is maybe $2K. It will have worse precision (than ball screws) as it is rack and pinion. But a work area of ~100x150cm.
                    @bjornhallberg said in Best CNC for milling/routing wood?:
                    It's not clear to me why he chose servos, unless, again, it was a step to further bolster the effective rigidity.
                    For roughly the same amount of money, he could have purchased either a standard or a pro kit from: http://www.cncrouterparts.com/benchtop-cnc-machine-kits-c-59_60.html
                    Their "Pro" version appears to be a highly rigid variant of their standard edition.
                    Which leaves me wondering: how do I decide between a standard machine and a pro machine? In some sense, more rigid is better, but it clearly comes at a cost, so how rigid is "good enough"?
                    Since maybe that is a tough question to answer, perhaps the ideal kit would be one where one starts with a cheaper "standard" machine, but where one can easily upgrade it to a rigid "pro" machine by simply adding additional parts. That would minimize the risk if one discovers that a standard machine just isn't rigid enough. So far, I haven't seen such an easy-to-upgrade kit, but maybe one exists?
                    RFM69R 1 Reply Last reply
                      RFM69R
                      RFM69R
                      RFM69
                      wrote on last edited by RFM69
                      Or you could try a MPCNC link text. I'm just finishing one myself.
                      • RFM69R RFM69
                        @rfm69 The link you supplied, "https://forum.mysensors.org/topic/9034/best-cnc-for-milling-routing-wood/vicious1.com", isn't working.
                        • RFM69R RFM69
                          @rfm69 Is this it?
                          Hmmm. That does look clever. I suppose one could scale it to use whatever bigger/stronger pipe might be needed to make it rigid enough. Pipe/tubing is usually plenty cheap, so I guess it might even be affordable.
                          If needed, you could maybe even replace the plastic joinery with Kee Klamps or similar: https://www.simplifiedbuilding.com/pipe-fittings/kee-klamp
                          When will you be done making yours? I'd love to hear how well you like it.
                          RFM69R 2 Replies Last reply
                          • bjornhallbergB
                            bjornhallbergB
                            bjornhallberg
                            The MPCNC is a smart project but I would assume it would struggle with a bigger motor.
                            The 2.2kW we are going to use weighs A LOT. Around 5kg at least I'd guess. The 1.5kW is not much better. With a smaller spindle, or router like a Kress things would be different. Still I'm glad to have the extra power, and standard ER20 collets up to 13mm. Plus these chinese spindles are really quiet compared to a regular router. And the speed can be set and spindle can be started from the control panel or from the computer. The downside is the low quality VFD I guess, but if it works it works. And you can always use shielded cables everywhere.
                            Muhammad IbrahimM 1 Reply Last reply
                              I bet that diameter of unsupported tube would be a fail, based on what we saw in the earlier videos.
                              However, if you were to fill those flimsy tubes with self-leveling mortar/concrete, maybe even with a piece of re-bar running down the center of it, I bet they'd become a lot more rigid.... Maybe then you could keep the same size.
                              Also, would box tubing be more rigid? Seems like the same design idea could be adapted to that. I can imagine that a box geometry might even stabilize the spindle more (keep it from going ring-around-the-rosie like maybe it would on a circular tube).
                                Well, anyway, until someone proves otherwise, I'm going to assume a supported rod/rail is the way to go. At least that has been proven to work reliably using straightforward techniques.
                                  @rfm69 Is this it?
                                  RFM69R
                                  RFM69R
                                  RFM69
                                  @neverdie Yes thats the one... I'm got it working but am waiting a few things by post to be able to connect the 3d printer. And then I need still to order a new spindle.
                                  There are some modifications people have made on thingyverse to strenghten the Z access to take heavier spindles... you can redesign the connecting corners and just print them out.
                                  I'd like to get a 1.5kw spindle, but might just get a small one to begin with.
                                    RFM69R
                                    RFM69R
                                    RFM69
                                    @neverdie They've already answered the concrete idea, many people consider that, but a simple center support I think solves the problem. They have nice forums over at the vicious.com link I shared.
                                      @rfm69 Is this it?
                                      RFM69R
                                      RFM69R
                                      RFM69
                                      @neverdie The same web site has a few other designs for larger machines.
                                      • RFM69R RFM69
                                        #22
                                        @rfm69
                                        Ah, OK, that makes sense for the side supports:
                                        The rods that move, though, remain unsupported, especially in the middle. What about those?
                                        • RFM69R RFM69
                                          #23
                                          @rfm69 said in Best CNC for milling/routing wood?:
                                          Hmm.. That Low Rider MPCNC does looks interesting. They're using just two stainless steel tubes for that. Should be relatively cheap to make, and it can handle large formats. :)
                                          !alt text
