  3. Cannot get RFM69HW connection between ESP8266GW and Pro Mini Sensor
35 Posts 4 Posters 6.4k Views 4 Watching
  • mfalkviddM
    I don't know why the code is written the way it is. When I verified the rfm69 wiring and wrote the instructions, I decided to not use the default IRQ pin, since it would interfere with boot (as you also have identified). That's why I added the define instructions to set both MY_RF69_IRQ_PIN and MY_RF69_IRQ_NUM.
    I am not familiar with the rfm69 driver code, but I think what you suggest should work. You are very welcome to create a pull request. If someone has any objections, they can always make their case during the code review.
    • E
      E
      elcaron
      I have already created an issue, but you are right, I could do a pull request.
      AnticimexA 1 Reply Last reply
      • E elcaron
        AnticimexA
        AnticimexA
        Anticimex
        @elcaron just add a #fixes tag to your pull request commit message and reference your issue so they get chained.
        • E
          E
          elcaron
          @mfalkvidd said in Cannot get RFM69HW connection between ESP8266GW and Pro Mini Sensor:
          Maybe note this in the instructions? This cost me 1 year (in which I did not touch the stuff after i didn't work immediately) and a weekend of checking wireing and so on (because with a missing IRQ on the gateway, it looks like nothing is working, while the issue is quite easy to find on a node).
          Ok, PR is filed, I also fixed it for the RFM95, which had the same issue.
          • E elcaron
            @elcaron could you describe the type of note you think you would have noticed?
            Great work on the PR.
            E 1 Reply Last reply
              E
              E
              elcaron
              wrote on last edited by elcaron
              #30
              @mfalkvidd Maybe a "* Different from code default and examples"?
              You do not really expect that you have to change defaults when you get a wiring guide from the official site associated with the code, especially when running an example that is explicitly for the platform (the ESP8266 gateway sketch).
              In hindsight, this was probably stupid, but I didn't even look at the defines below the table, because I thought I was running a working example specifically for the ESP8266 and only needed to find the right pins.
              • E elcaron
                @elcaron so we've determined that a note below the table wouldn't work (since you didn't read it). Where would we place the note so you would have noticed it?
                • E
                  E
                  elcaron
                  #32
                  As a * that resolves to above mentioned note directly in the table:
                  D1* | DIO0 | Gray
                  Below: * Different from code default and examples
                  As I said, one doesn't necessarily expect that defaults have to changed an ESP-specific example sketch.
                  • E elcaron
                    D1* | DIO0 | Gray
                    @elcaron thanks. I have updated connecting the radio.
                    • mfalkviddM
                      Adding references to github:
                      https://github.com/mysensors/MySensors/issues/1075
                      https://github.com/mysensors/MySensors/pull/1076
                      • E
                        E
                        elcaron
                        Ok, my setup is running now (including personalization, encryption, and soft signing) and stuff is published to mqtt.
                        Thanks everyone for the help! I really like this community.
                        Now I need to resolve the issue with the OpenHAB binding but that's no topic for here.
