  3. DIY CNC mill from mainly salvaged and 3D printed parts
76 Posts 5 Posters 21.3k Views 6 Watching
  • dbemowskD dbemowsk
    So the CNC is near ready for testing. I need to solder a connector on to the X axis stepper and I should be able to run some tests. I think the next step is going to be figuring out how to calibrate the GRBL controller.
    Here are some pics of the build so far.
    0_1520435634637_d55a543c-c83e-45c2-baf1-88b9dffe4bf7-image.png 0_1520435645089_b6649401-63a5-4317-83fb-e3ffde4c1535-image.png 0_1520435653054_883b5d94-af50-4211-8b3c-13f5d682457e-image.png
    #28
    @dbemowsk A+ for sticking with it all the way to completion.
    The main calibration number will probably be the revolutions per inch for each of the axises (axi?). From there you can start air carving.
    dbemowskD NeverDieN 2 Replies Last reply
      dbemowskD
      dbemowskD
      @neverdie Thanks. I appreciate the tip and the compliment. Are you sure it is revolutions per inch and not steps per inch? The larger black motors I have for the X and Z axes are 400 steps per rev, but I think the Y axis motor is only 200 steps per rev. The Y axis is running on the large geared assembly though, so that should help more with both torque and revolution step count.
      There is the talk about the rigidity of it. I am thinking if I run it a bit slower, the rigidity will matter a little bit less, but I'll see once I get it going. The MDF I used is 3/4", and it feels pretty rigid, but only tests will tell. I have my spindle chuck, a set of 7 coletts and some bits on order from amazon. Those should be here tomorrow I am thinking, since everything was prime.
        @neverdie said in DIY CNC mill from mainly salvaged and 3D printed parts:
        I'm just going from memory. I think you're right, though: steps per inch. Or something like that. ;)
        • dbemowskD
          dbemowskD
          So here is it's maiden voyage... It's first simultaneous run of all axes, AKA the initial X, Y and Z axis test.
          https://www.youtube.com/watch?v=8diihXJwMj0
          • dbemowskD
            dbemowskD
            I believe these are the settings that I need to change: https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.9
            I will be trying to configure things tonight. From the tracking information, I should have my chuck, coletts and the drills tonight, but the V bits won't be here til Monday. I am wondering if there are any test files that I can try to test my calibration? I will try to set up software on my WIndows laptop for now, but may migrate to a laptop running linux for the final setup.
            • dbemowskD
              dbemowskD
              I haven't had a chance to test the accuracy of the machine yet, but I did find a web page that has a VERY useful calculator for figuring out your steps per mm for a lead screw type system.
              https://www.prusaprinters.org/calculator
              Scroll down to the section labeled "Steps per millimeter - leadscrew driven systems". You just enter the parameters of your motor, microstepping, gear ratio (if any) and lead screw type/size. From that it calculates the steps per mm that is needed to configure your X, Y and Z axes for your GRBL controller.
              Figured this may be useful to others.
                Or use a dial gauge and get an exact measurement.
                dbemowskD 1 Reply Last reply
                  dbemowskD
                  dbemowskD
                  @neverdie I'll check things with my micrometer once I get my bits and get a print on something.
                    That should work. Here's what I meant though:
                    https://youtu.be/rr42kPzL7js
                      dbemowskD
                      dbemowskD
                      @neverdie Interesting video. It appears that I may have to get myself a dial indicator tool. Looks as if it will prove very useful. Using that calculator page that I found can at least get me to a starting point, and I can adjust from there.
                      • dbemowskD
                        dbemowskD
                        So I am trying to get my spindle control set up and I am having an issue. I am checking with a volt meter between the spindle enable (SpnEn) and ground and I am reading 5v. No matter what spindle commands I am sending (M03, M04 or M05) I am always reading 5v. Is there a different command for spindle enable? If I check the spindle direction pin (SpnDir), I read 5v when I send M03, and 0v when I send M04. So that appears to be working.
                          #39
                          @dbemowsk
                          On my board,
                          M3 SP1000
                          spins the spindle at maximum speed. Just M3 by itself doesn't.
                          It's not obvious from looking at your board where the spindle OUT voltage is. Maybe on the opposite side? I guess you'll have to probe around to find it.
                            @dbemowsk
                            On my board,
                            M3 SP1000
                            dbemowskD
                            dbemowskD
                            @neverdie The SpnEn and SpnDir are control signals. For this board you need to have an external motor driver. After some looking, I may have found my answer. I am running GRBL 1.1. It appears that they swapped 2 of the pins. Pin 12 used to be the spindle enable pin in GRBL 0.9. In 1.1, they swapped 11 and 12 because pin 12 cannot be used for PWM which is how the controller limits the speed. I have not tried it yet, but I am going to try the Z+ pin which is pin 11. If that works, I may do a slight board mod.
                            Here is the post that explains it. https://github.com/grbl/grbl/issues/1187
                            • dbemowskD
                              dbemowskD
                              BTW, I am using an external H- Bridge to control the spindle.
                              • dbemowskD
                                dbemowskD
                                Just tried that and it worked perfect. I don't use SP though, I just use S. So M3 S1000 is full speed, M3 S500 slows the motor, and M5 stops it.
                                  #43
                                  Yes, my typo, just S, not SP.
                                  I do wonder whether some of the more "advanced" boards, like the Duet WiFi, actually perform better, or whether the results are the same.
                                  I think I may get a RAMPS board, if only because it supports Marlin, and that's what the MPCNC uses.
                                  On the other hand, there is a smoothieboard clone on aliexpress for $40. . Hmm... It's tempting....
                                  The jump from GRBL 0.9 to 1.1 convinced me that the firmware can make a difference, that it's not just all equivalent.
                                    dbemowskD
                                    dbemowskD
                                    @neverdie I have always said, at least for 3D printers, that RAMPS was the way to go if you had to change your main board. Many of these 3D printer main boards have everything integrated into them. With RAMPS, it is all modular. If something dies, you are replacing 1 part rather than an entire board.
                                      #45
                                      @dbemowsk I'll give it a shot. I ordered a mildly upgraded RAMPs board (so called "version 1.6"). It doesn't have the re-settable fuses, which I guess have a dodgy reputation (or so Tom Sanlanderer seems to imply).
                                      https://www.aliexpress.com/item/Bigtreetech-upgrade-Ramps-1-5-Base-on-Ramps-1-4-3D-control-panel-printer-Control-Reprap/32822038995.html?spm=a2g0s.9042311.0.0.9zbnJj
                                      I'll be curious as to whether it can accept either the TMC2130 or the TMC2660 modules.
                                        dbemowskD
                                        dbemowskD
                                        @neverdie I think most of those stepper driver modules run the same footprint. Check out this link. It is from Tom's 3D forum. People there are talking about those as replacements for the DRV88256's, which are the ones that I have. May be some useful info for you.
                                        https://discuss.toms3d.org/hardware-f6/drv8825-vs-tmc2100-vs-tmc2130-vs-tmc2208-t250.html
                                          @dbemowsk Short of making a very careful study of the datasheets, the other info that's available is awfully sketchy, so I ordered one of each module, and I'll see if I can get either one to work on the RAMPS board that I ordered. I'm not completely sure, but I get the impression that after they are properly configured, they can maybe just plug and play.
