  3. DIY CNC mill from mainly salvaged and 3D printed parts
76 Posts 5 Posters 21.3k Views 6 Watching
  • dbemowskD
    dbemowskD
    So here is it's maiden voyage... It's first simultaneous run of all axes, AKA the initial X, Y and Z axis test.
    https://www.youtube.com/watch?v=8diihXJwMj0
    • dbemowskD
      dbemowskD
      I believe these are the settings that I need to change: https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.9
      I will be trying to configure things tonight. From the tracking information, I should have my chuck, coletts and the drills tonight, but the V bits won't be here til Monday. I am wondering if there are any test files that I can try to test my calibration? I will try to set up software on my WIndows laptop for now, but may migrate to a laptop running linux for the final setup.
      • dbemowskD
        dbemowskD
        I haven't had a chance to test the accuracy of the machine yet, but I did find a web page that has a VERY useful calculator for figuring out your steps per mm for a lead screw type system.
        https://www.prusaprinters.org/calculator
        Scroll down to the section labeled "Steps per millimeter - leadscrew driven systems". You just enter the parameters of your motor, microstepping, gear ratio (if any) and lead screw type/size. From that it calculates the steps per mm that is needed to configure your X, Y and Z axes for your GRBL controller.
        Figured this may be useful to others.
          Or use a dial gauge and get an exact measurement.
          dbemowskD 1 Reply Last reply
            dbemowskD
            dbemowskD
            @neverdie I'll check things with my micrometer once I get my bits and get a print on something.
              That should work. Here's what I meant though:
              https://youtu.be/rr42kPzL7js
                dbemowskD
                dbemowskD
                @neverdie Interesting video. It appears that I may have to get myself a dial indicator tool. Looks as if it will prove very useful. Using that calculator page that I found can at least get me to a starting point, and I can adjust from there.
                • dbemowskD
                  dbemowskD
                  So I am trying to get my spindle control set up and I am having an issue. I am checking with a volt meter between the spindle enable (SpnEn) and ground and I am reading 5v. No matter what spindle commands I am sending (M03, M04 or M05) I am always reading 5v. Is there a different command for spindle enable? If I check the spindle direction pin (SpnDir), I read 5v when I send M03, and 0v when I send M04. So that appears to be working.
                  • dbemowskD dbemowsk
                    #39
                    @dbemowsk
                    On my board,
                    M3 SP1000
                    spins the spindle at maximum speed. Just M3 by itself doesn't.
                    It's not obvious from looking at your board where the spindle OUT voltage is. Maybe on the opposite side? I guess you'll have to probe around to find it.
                      @dbemowsk
                      On my board,
                      M3 SP1000
                      dbemowskD
                      dbemowskD
                      @neverdie The SpnEn and SpnDir are control signals. For this board you need to have an external motor driver. After some looking, I may have found my answer. I am running GRBL 1.1. It appears that they swapped 2 of the pins. Pin 12 used to be the spindle enable pin in GRBL 0.9. In 1.1, they swapped 11 and 12 because pin 12 cannot be used for PWM which is how the controller limits the speed. I have not tried it yet, but I am going to try the Z+ pin which is pin 11. If that works, I may do a slight board mod.
                      Here is the post that explains it. https://github.com/grbl/grbl/issues/1187
                      • dbemowskD
                        dbemowskD
                        BTW, I am using an external H- Bridge to control the spindle.
                        • dbemowskD
                          dbemowskD
                          Just tried that and it worked perfect. I don't use SP though, I just use S. So M3 S1000 is full speed, M3 S500 slows the motor, and M5 stops it.
                            #43
                            Yes, my typo, just S, not SP.
                            I do wonder whether some of the more "advanced" boards, like the Duet WiFi, actually perform better, or whether the results are the same.
                            I think I may get a RAMPS board, if only because it supports Marlin, and that's what the MPCNC uses.
                            On the other hand, there is a smoothieboard clone on aliexpress for $40. . Hmm... It's tempting....
                            The jump from GRBL 0.9 to 1.1 convinced me that the firmware can make a difference, that it's not just all equivalent.
                              dbemowskD
                              dbemowskD
                              @neverdie I have always said, at least for 3D printers, that RAMPS was the way to go if you had to change your main board. Many of these 3D printer main boards have everything integrated into them. With RAMPS, it is all modular. If something dies, you are replacing 1 part rather than an entire board.
                                #45
                                @dbemowsk I'll give it a shot. I ordered a mildly upgraded RAMPs board (so called "version 1.6"). It doesn't have the re-settable fuses, which I guess have a dodgy reputation (or so Tom Sanlanderer seems to imply).
                                https://www.aliexpress.com/item/Bigtreetech-upgrade-Ramps-1-5-Base-on-Ramps-1-4-3D-control-panel-printer-Control-Reprap/32822038995.html?spm=a2g0s.9042311.0.0.9zbnJj
                                I'll be curious as to whether it can accept either the TMC2130 or the TMC2660 modules.
                                  dbemowskD
                                  dbemowskD
                                  @neverdie I think most of those stepper driver modules run the same footprint. Check out this link. It is from Tom's 3D forum. People there are talking about those as replacements for the DRV88256's, which are the ones that I have. May be some useful info for you.
                                  https://discuss.toms3d.org/hardware-f6/drv8825-vs-tmc2100-vs-tmc2130-vs-tmc2208-t250.html
                                    @dbemowsk Short of making a very careful study of the datasheets, the other info that's available is awfully sketchy, so I ordered one of each module, and I'll see if I can get either one to work on the RAMPS board that I ordered. I'm not completely sure, but I get the impression that after they are properly configured, they can maybe just plug and play.
                                    • dbemowskD
                                      dbemowskD
                                      #48
                                      So, here is the latest update with pictures. I have the whole setup mounted on a leftover piece of MDF. I am using an ATX computer power supply to run everything. The fan pulls air from the back of the setup and blows it over the heatsinks for all of the modules.
                                      For spindle control I have 3 different modules. The first is a buck converter to boost the 12 volts to 24 for running the spindle motor.
                                      Next I have a dual H-Bridge that I had in my parts bin. I am only using one side of it. This handles the motor direction and speed. One problem with it that I had to overcome was that it had separate logic inputs for forward and reverse. The problem was that the CNC shield had a single output for spindle direction. To overcome this, I made a simple not gate circuit using an NPN switching transistor which sends a normal logic level to one input pin and an inverted signal to the other. I then use the enable line to start and stop the spindle. This setup works well.
                                      This is the entire spindle drive circuity.
                                      Here is an angled front view.
                                        #49
                                        Don't forget to include a snub diode on the motor, if you haven't already.
                                          dbemowskD
                                          dbemowskD
                                          @neverdie I thought that that was integrated on to the H-Bridge controller.
