  3. DIY CNC mill from mainly salvaged and 3D printed parts
76 Posts 5 Posters 21.3k Views 6 Watching
  • dbemowskD
    dbemowskD
    #48
    So, here is the latest update with pictures. I have the whole setup mounted on a leftover piece of MDF. I am using an ATX computer power supply to run everything. The fan pulls air from the back of the setup and blows it over the heatsinks for all of the modules.
    For spindle control I have 3 different modules. The first is a buck converter to boost the 12 volts to 24 for running the spindle motor.
    Next I have a dual H-Bridge that I had in my parts bin. I am only using one side of it. This handles the motor direction and speed. One problem with it that I had to overcome was that it had separate logic inputs for forward and reverse. The problem was that the CNC shield had a single output for spindle direction. To overcome this, I made a simple not gate circuit using an NPN switching transistor which sends a normal logic level to one input pin and an inverted signal to the other. I then use the enable line to start and stop the spindle. This setup works well.
    This is the entire spindle drive circuity.
    Here is an angled front view.
      #49
      Don't forget to include a snub diode on the motor, if you haven't already.
      dbemowskD 1 Reply Last reply
        dbemowskD
        dbemowskD
        @neverdie I thought that that was integrated on to the H-Bridge controller.
        • dbemowskD dbemowsk
          @dbemowsk If that's what it is, then I guess you're covered. :)
            #52
            I like the idea of recycling an old PC power supply with a boost converter. For instance, a lot of the 48v power supplies don't come with regular 110VAC plugs, and you're even left with semi-exposed 110VAC wiring, so this kinda works around that. It's a bit ungainly, but it works.
            The only problem is you probably can't get to more than 240w, as that would be 20amps at 12v to the input of the boost converter. Actually less than 240w because of conversion inefficiency. At best probably just 0.85*240=204w. Maybe it would be good enough for milling PCBs though.
            • dbemowskD
              dbemowskD
              So I am trying to test the new machine and am having some trouble. I am running into an issue with some gcode I am testing. The gcode was generated from inkscape and I am including the gcode below. The way I am testing this is just using a terminal connection to the CNC and pasting the gcode into the terminal window. If there is a better way to test this let me know.
              When I paste in the gcode below, the CNC runs through part of it and then stops. If I then hit enter in the terminal window I get this:
              error: Invalid gcode ID:35
              From my research on this error I found this:
              A G2 or G3 arc, traced with the offset definition, is missing the IJK offset word in the selected plane to trace the arc.
              After testing in chunks, I have found the line that appears to be causing the error.
              This will cause the error:
              G01 Z-0.125000 F100.0
              G03 X44.448347 Y19.159901 Z-0.125000 I-203.958107 J224.353401 F400.000000
              G03 X45.751092 Y20.363421 Z-0.125000 I-235.328819 J256.037427
              G03 X47.053649 Y21.586232 Z-0.125000 I-48.170466 J52.617095
              G03 X47.737750 Y22.275812 Z-0.125000 I-14.623944 J15.191857
              G03 X49.369789 Y24.042092 Z-0.125000 I-12.444180 J13.135542
              G03 X50.077180 Y25.172247 Z-0.125000 I-4.326712 J3.494655
              G03 X50.505064 Y26.430623 Z-0.125000 I-5.413285 J2.542606
              G03 X50.652755 Y27.790183 Z-0.125000 I-6.183798 J1.359560
              G03 X50.459010 Y29.287714 Z-0.125000 I-5.884361 J0.000000
              G03 X50.002913 Y30.259582 Z-0.125000 I-2.876467 J-0.756965
              If I run it just to the line that ends in J0.000000, I don't get the error. From all the testing I am doing, it almost seems like a problem with the version og GRBL that I am running. If anyone can help, it would be greatly appreciated.
              Here is the full gcode file I am trying to run.
              (Header)
              (Generated by gcodetools from Inkscape.)
              (Using default header. To add your own header create file "header" in the output dir.)
              M3
              (Header end.)
              G21
              G00 Z5.000000
              G00 X43.225993 Y18.042555
              G03 X49.239064 Y30.916004 Z-0.125000 I-1.644692 J-1.141216
              G03 X48.146224 Y31.169360 Z-0.125000 I-1.092840 J-2.230286
              G03 X47.289509 Y31.048092 Z-0.125000 I-0.000000 J-3.086831
              G03 X46.475200 Y30.686621 Z-0.125000 I0.908316 J-3.144182
              G03 X45.866393 Y30.136858 Z-0.125000 I1.149043 J-1.884428
              G03 X45.713957 Y29.684007 Z-0.125000 I0.596437 J-0.452850
              G03 X45.985338 Y29.064178 Z-0.125000 I0.843529 J-0.000000
              G03 X46.679436 Y28.792797 Z-0.125000 I0.694099 J0.751942
              G02 X47.335454 Y28.673230 Z-0.125000 I-0.000000 J-1.859443
              G02 X47.812019 Y28.365758 Z-0.125000 I-0.474548 J-1.258585
              G02 X48.135474 Y27.903550 Z-0.125000 I-0.880288 J-0.960310
              G02 X48.257626 Y27.288877 Z-0.125000 I-1.485457 J-0.614672
              G02 X48.104631 Y26.518211 Z-0.125000 I-2.017507 J0.000000
              G02 X47.682050 Y25.896359 Z-0.125000 I-1.707278 J0.705676
              G02 X47.046759 Y25.486928 Z-0.125000 I-1.345892 J1.390756
              G02 X46.270965 Y25.339351 Z-0.125000 I-0.775794 J1.965345
              G02 X45.292182 Y25.503034 Z-0.125000 I-0.000000 J3.008278
              G02 X44.544242 Y25.933491 Z-0.125000 I0.740151 J2.151068
              G02 X44.042842 Y26.629349 Z-0.125000 I1.319262 J1.479165
              G02 X43.857268 Y27.530245 Z-0.125000 I2.093979 J0.900896
              G02 X44.053076 Y28.610069 Z-0.125000 I3.075347 J0.000000
              G02 X44.637076 Y29.609740 Z-0.125000 I3.204798 J-1.201795
              G02 X45.497064 Y30.450999 Z-0.125000 I4.328411 J-3.564579
              G02 X46.382366 Y30.983691 Z-0.125000 I2.558297 J-3.249731
              G02 X47.382290 Y31.355341 Z-0.125000 I3.964670 J-9.135984
              G02 X48.109089 Y31.522132 Z-0.125000 I1.448687 J-4.645789
              G02 X48.873231 Y31.617913 Z-0.125000 I1.459799 J-8.550217
              G02 X49.724411 Y31.652101 Z-0.125000 I0.851180 J-10.578908
              G02 X51.889847 Y31.372996 Z-0.125000 I0.000000 J-8.539831
              G02 X53.549194 Y30.649487 Z-0.125000 I-1.488545 J-5.678518
              G02 X54.704159 Y29.414339 Z-0.125000 I-1.811549 J-2.851516
              G02 X55.127380 Y27.753048 Z-0.125000 I-3.048959 J-1.661291
              G02 X54.936373 Y26.631768 Z-0.125000 I-3.386657 J-0.000000
              G02 X54.384704 Y25.636421 Z-0.125000 I-3.198858 J1.122406
              G02 X53.586077 Y24.796888 Z-0.125000 I-4.668650 J3.641547
              G02 X52.750815 Y24.225335 Z-0.125000 I-2.952589 J3.418787
              G02 X51.827360 Y23.791569 Z-0.125000 I-7.103306 J13.922514
              G02 X49.947214 Y23.018488 Z-0.125000 I-24.534815 J56.996312
              G03 X48.140362 Y22.212394 Z-0.125000 I6.972211 J-18.056198
              G03 X47.867719 Y21.960175 Z-0.125000 I0.309378 J-0.607900
              G01 X47.867719 Y21.885905 Z-0.125000
              G02 X48.332245 Y21.916706 Z-0.125000 I1.362590 J-17.031956
              G02 X48.926032 Y21.941607 Z-0.125000 I1.463551 J-27.806724
              G02 X49.538817 Y21.955270 Z-0.125000 I1.159694 J-38.263217
              G02 X50.225717 Y21.960178 Z-0.125000 I0.686900 J-48.074419
              G01 X53.159290 Y21.960178 Z-0.125000
              G03 X54.047826 Y22.036865 Z-0.125000 I0.000000 J5.185830
              G03 X54.440406 Y22.182978 Z-0.125000 I-0.196020 J1.127129
              G03 X54.758038 Y22.451881 Z-0.125000 I-0.663402 J1.105664
              G03 X54.978847 Y22.814255 Z-0.125000 I-1.019962 J0.869964
              G03 X55.149683 Y23.228183 Z-0.125000 I-5.791228 J2.632369
              G03 X55.275917 Y23.612631 Z-0.125000 I-4.868337 J1.811474
              G02 X55.407546 Y24.001962 Z-0.125000 I45.628782 J-15.209704
              G02 X55.498720 Y24.262473 Z-0.125000 I20.519916 J-7.035405
              G01 X55.740088 Y24.262473 Z-0.125000
              G01 X54.551808 Y17.912589 Z-0.125000
              G01 X43.225993 Y17.912589 Z-0.125000
              G01 X43.225993 Y18.042555 Z-0.125000
              G00 Z5.000000
              (End cutting path id: path4518)
              (Start cutting path id: path4516)
              (Change tool to Default tool)
              G00 Z5.000000
              G00 X35.980838 Y21.607403
              G01 Z-0.125000 F100.0(Penetrate)
              G01 X35.980838 Y25.190815 Z-0.125000 F400.000000
              G01 X35.999408 Y27.233175 Z-0.125000
              G03 X35.574593 Y26.748497 Z-0.125000 I52.703425 J-46.622391
              G03 X34.773990 Y25.822090 Z-0.125000 I191.750900 J-166.520630
              G02 X33.983162 Y24.922179 Z-0.125000 I-36.848082 J31.584152
              G02 X32.917298 Y23.761165 Z-0.125000 I-62.405165 J56.220956
              G02 X31.819666 Y22.649912 Z-0.125000 I-29.726417 J28.264352
              G02 X30.726405 Y21.625970 Z-0.125000 I-26.328768 J27.015589
              G01 X33.028700 Y21.607400 Z-0.125000
              G01 X35.980838 Y21.607403 Z-0.125000
              G00 Z5.000000
              (End cutting path id: path4516)
              G00 Z5.000000
              G00 X40.399760 Y21.607403
              G01 X42.590657 Y21.607403 Z-0.125000 F400.000000
              G01 X42.590657 Y20.809024 Z-0.125000
              G01 X40.399760 Y20.809024 Z-0.125000
              G01 X40.399760 Y20.084915 Z-0.125000
              G03 X40.407178 Y19.750985 Z-0.125000 I7.520648 J-0.000000
              G03 X40.436895 Y19.249405 Z-0.125000 I17.002115 J0.755670
              G03 X40.546108 Y18.791102 Z-0.125000 I1.970229 J0.227339
              G03 X40.696833 Y18.543863 Z-0.125000 I0.702969 J0.258990
              G03 X40.941182 Y18.384755 Z-0.125000 I0.600616 J0.655210
              G03 X41.290973 Y18.283925 Z-0.125000 I0.555297 J1.269242
              G03 X41.662590 Y18.250282 Z-0.125000 I1.978264 J19.782188
              G03 X41.977950 Y18.228226 Z-0.125000 I1.153236 J14.223609
              G02 X42.293361 Y18.222789 Z-0.125000 I0.000000 J-9.150730
              G02 X42.516390 Y18.209656 Z-0.125000 I-0.158205 J-4.587139
              G01 X42.516390 Y17.912583 Z-0.125000
              G01 X33.715674 Y17.912583 Z-0.125000
              G01 X33.715674 Y18.209656 Z-0.125000
              G01 X34.198412 Y18.209656 Z-0.125000
              G03 X34.458043 Y18.231591 Z-0.125000 I-0.716004 J10.022311
              G03 X34.959656 Y18.283923 Z-0.125000 I-3.655306 J37.467340
              G03 X35.448552 Y18.416918 Z-0.125000 I-0.290338 J2.032389
              G03 X35.683768 Y18.580993 Z-0.125000 I-0.249659 J0.608548
              G03 X35.843078 Y18.850674 Z-0.125000 I-0.547342 J0.505231
              G03 X35.962270 Y19.416503 Z-0.125000 I-2.408402 J0.802798
              G01 X35.999405 Y20.809021 Z-0.125000
              G01 X29.723789 Y20.809021 Z-0.125000
              G01 X29.723789 Y21.198928 Z-0.125000
              G03 X31.120862 Y22.513291 Z-0.125000 I-26.402073 J29.463183
              G03 X32.713060 Y24.151066 Z-0.125000 I-39.419679 J39.915522
              G03 X34.252508 Y25.840106 Z-0.125000 I-70.593355 J65.887243
              G03 X36.017970 Y27.864447 Z-0.125000 I-99.645628 J88.684620
              G03 X37.748161 Y29.937732 Z-0.125000 I-142.627488 J120.783656
              G03 X39.025809 Y31.522129 Z-0.125000 I-82.011066 J67.440569
              G01 X40.399760 Y31.522129 Z-0.125000
              G01 X40.399760 Y21.607403 Z-0.125000
              G00 Z5.000000
              (Start cutting path id: path4514)
              G00 Z5.000000
              G00 X18.865337 Y24.225335
              G01 X20.480658 Y31.559267 Z-0.125000 F400.000000
              G01 X20.647760 Y31.559267 Z-0.125000
              G03 X21.301879 Y31.370938 Z-0.125000 I4.220657 J13.429377
              G03 X22.207381 Y31.150795 Z-0.125000 I6.684447 J25.522464
              G03 X23.141733 Y31.001820 Z-0.125000 I1.740292 J7.910320
              G03 X24.249741 Y30.946556 Z-0.125000 I1.108007 J11.079935
              G03 X25.672326 Y31.009030 Z-0.125000 I0.000000 J16.228010
              G03 X26.570605 Y31.150795 Z-0.125000 I-0.580218 J6.593308
              G03 X27.163172 Y31.377624 Z-0.125000 I-16.345032 J43.587248
              G03 X27.758887 Y31.614966 Z-0.125000 I-17.300215 J44.288718
              G02 X27.874660 Y31.545070 Z-0.125000 I-0.000000 J-0.130829
              G02 X27.944556 Y31.262194 Z-0.125000 I-0.537466 J-0.282876
              G02 X27.858000 Y30.728811 Z-0.125000 I-1.686705 J0.000000
              G02 X27.517517 Y29.981077 Z-0.125000 I-3.699295 J1.233098
              G02 X27.036658 Y29.338516 Z-0.125000 I-2.958736 J1.712955
              G02 X26.087865 Y28.477160 Z-0.125000 I-6.317281 J6.005326
              G02 X24.999472 Y27.947358 Z-0.125000 I-1.799138 J2.313175
              G02 X22.968624 Y27.697349 Z-0.125000 I-2.030848 J8.123382
              G02 X22.023587 Y27.724483 Z-0.125000 I0.000000 J16.470844
              G02 X21.353303 Y27.790183 Z-0.125000 I0.479583 J8.344780
              G02 X20.698448 Y27.945130 Z-0.125000 I0.823870 J4.943211
              G02 X20.090753 Y28.180087 Z-0.125000 I1.386162 J4.488536
              G01 X19.496612 Y25.562154 Z-0.125000
              G02 X20.420767 Y26.277720 Z-0.125000 I3.544856 J-3.623633
              G02 X21.371870 Y26.694735 Z-0.125000 I2.068978 J-3.425688
              G02 X22.425760 Y26.915093 Z-0.125000 I1.767117 J-5.821095
              G02 X24.045505 Y27.010372 Z-0.125000 I1.619745 J-13.720196
              G02 X26.002310 Y26.698984 Z-0.125000 I-0.000000 J-6.304103
              G02 X27.684619 Y25.822090 Z-0.125000 I-1.793851 J-5.493667
              G02 X28.853132 Y24.429454 Z-0.125000 I-2.426172 J-3.222266
              G02 X29.262806 Y22.721416 Z-0.125000 I-3.355793 J-1.708038
              G02 X28.719685 Y20.623608 Z-0.125000 I-4.322955 J0.000000
              G02 X27.201879 Y19.008034 Z-0.125000 I-3.955337 J2.195212
              G02 X25.055324 Y18.043352 Z-0.125000 I-4.247338 J6.580391
              G02 X22.467318 Y17.689786 Z-0.125000 I-2.588006 J9.294965
              G02 X20.516310 Y17.965951 Z-0.125000 I-0.000000 J7.029654
              G02 X19.125274 Y18.655265 Z-0.125000 I1.211062 J4.192136
              G02 X18.167632 Y19.798729 Z-0.125000 I2.094628 J2.726975
              G02 X17.844157 Y21.124661 Z-0.125000 I2.555779 J1.325932
              G02 X18.001470 Y21.835020 Z-0.125000 I1.682496 J0.000000
              G02 X18.475432 Y22.480048 Z-0.125000 I1.845992 J-0.859776
              G02 X19.163765 Y22.908353 Z-0.125000 I1.503460 J-1.648961
              G02 X19.942218 Y23.055620 Z-0.125000 I0.778453 J-1.983804
              G02 X20.910521 Y22.903307 Z-0.125000 I-0.000000 J-3.154065
              G02 X21.668941 Y22.498615 Z-0.125000 I-0.744739 J-2.308701
              G02 X22.184274 Y21.866063 Z-0.125000 I-1.061617 J-1.391084
              G02 X22.374483 Y21.031827 Z-0.125000 I-1.734336 J-0.834236
              G02 X22.212395 Y20.170622 Z-0.125000 I-2.368924 J0.000000
              G02 X21.780342 Y19.509343 Z-0.125000 I-1.793062 J0.699732
              G03 X21.254269 Y18.887006 Z-0.125000 I3.449199 J-3.449189
              G03 X21.186201 Y18.673830 Z-0.125000 I0.299780 J-0.213176
              G03 X21.278233 Y18.397734 Z-0.125000 I0.460159 J0.000000
              G03 X21.576106 Y18.153956 Z-0.125000 I0.643932 J0.482949
              G03 X21.992550 Y18.027396 Z-0.125000 I0.884662 J2.162523
              G03 X22.393050 Y17.986856 Z-0.125000 I0.400500 J1.958017
              G03 X23.573351 Y18.312863 Z-0.125000 I-0.000000 J2.299628
              G03 X24.286875 Y19.119436 Z-0.125000 I-0.912880 J1.526457
              G03 X24.642008 Y20.282923 Z-0.125000 I-4.628727 J2.048777
              G03 X24.788181 Y21.941607 Z-0.125000 I-9.337783 J1.658684
              G03 X24.614609 Y23.704630 Z-0.125000 I-9.040542 J0.000000
              G03 X24.156906 Y25.116548 Z-0.125000 I-6.224224 J-1.237565
              G03 X23.309525 Y26.128896 Z-0.125000 I-2.201031 J-0.981541
              G03 X22.133113 Y26.490499 Z-0.125000 I-1.176411 J-1.732823
              G03 X20.931989 Y26.297380 Z-0.125000 I0.000000 J-3.831820
              G03 X20.220721 Y25.859224 Z-0.125000 I0.566382 J-1.715806
              G03 X19.619208 Y25.205500 Z-0.125000 I7.557493 J-7.557497
              G03 X19.403778 Y24.893745 Z-0.125000 I1.484653 J-1.256244
              G03 X19.256083 Y24.552361 Z-0.125000 I3.008082 J-1.504041
              G03 X19.143841 Y24.188203 Z-0.125000 I3.312064 J-1.220236
              G01 X18.865337 Y24.225335 Z-0.125000
              G00 Z5.000000
              (End cutting path id: path4514)
              (Start cutting path id: path4512)
              G00 Z5.000000
              G00 X14.904203 Y20.233452
              G01 X14.941337 Y19.379374 Z-0.125000 F400.000000
              G03 X15.057746 Y18.793506 Z-0.125000 I2.825055 J0.256823
              G03 X15.201274 Y18.543863 Z-0.125000 I0.629513 J0.195849
              G03 X15.445033 Y18.383087 Z-0.125000 I0.623587 J0.680268
              G03 X15.776848 Y18.283925 Z-0.125000 I0.534255 J1.182988
              G03 X16.129803 Y18.248805 Z-0.125000 I3.255779 J30.929087
              G03 X16.370989 Y18.228226 Z-0.125000 I1.351946 J14.421104
              G02 X16.630791 Y18.223896 Z-0.125000 I0.000000 J-7.796989
              G02 X16.927996 Y18.209656 Z-0.125000 I-0.340681 J-10.218602
              G01 X16.927996 Y17.912583 Z-0.125000
              G01 X8.164415 Y17.912583 Z-0.125000
              G01 X8.164415 Y18.209656 Z-0.125000
              G01 X8.572887 Y18.209656 Z-0.125000
              G03 X8.795484 Y18.230346 Z-0.125000 I-0.974770 J11.695148
              G03 X9.296997 Y18.283923 Z-0.125000 I-6.094603 J59.423063
              G03 X9.785893 Y18.416919 Z-0.125000 I-0.290337 J2.032380
              G03 X10.021106 Y18.580993 Z-0.125000 I-0.249656 J0.608537
              G03 X10.180418 Y18.850674 Z-0.125000 I-0.547335 J0.505231
              G03 X10.299610 Y19.416503 Z-0.125000 I-2.408361 J0.802788
              G01 X10.336743 Y20.270581 Z-0.125000
              G01 X10.336743 Y28.997033 Z-0.125000
              G01 X10.299610 Y29.851111 Z-0.125000
              G03 X10.182971 Y30.400736 Z-0.125000 I-2.487771 J-0.240753
              G03 X10.021106 Y30.686621 Z-0.125000 I-0.810657 J-0.270219
              G03 X9.776926 Y30.897553 Z-0.125000 I-0.581679 J-0.426566
              G03 X9.389831 Y31.020826 Z-0.125000 I-0.534986 J-1.010529
              G03 X8.980496 Y31.066901 Z-0.125000 I-1.187543 J-8.708864
              G03 X8.554320 Y31.095093 Z-0.125000 I-0.836645 J-9.412371
              G02 X8.127360 Y31.133065 Z-0.125000 I9.469020 J108.890844
              G02 X7.941612 Y31.150795 Z-0.125000 I1.875189 J20.626530
              G01 X7.941612 Y31.447865 Z-0.125000
              G01 X14.904203 Y31.447865 Z-0.125000
              G01 X14.904203 Y20.233452 Z-0.125000
              G00 Z5.000000
              (End cutting path id: path4512)
              (Footer)
              M5
              G00 X0.0000 Y0.0000
              M2
              (Using default footer. To add your own footer create file "footer" in the output dir.)
              (end)
                (Header)
                M3
                (Header end.)
                G21
                G00 Z5.000000
                G00 Z5.000000
                G00 Z5.000000
                G00 Z5.000000
                G00 Z5.000000
                G00 Z5.000000
                G00 Z5.000000
                G00 Z5.000000
                G00 Z5.000000
                G00 Z5.000000
                (Footer)
                M5
                G00 X0.0000 Y0.0000
                M2
                (end)
                @dbemowsk said in DIY CNC mill from mainly salvaged and 3D printed parts:
                This may be your problem, or at least a contributing factor. Try using a gcode sender, such as ChiliPeppr, instead.
                  dbemowskD
                  dbemowskD
                  @neverdie Thanks a million. I tried the online version of chilipeppr and it seem s to be working.
                  • dbemowskD
                    dbemowskD
                    So I did a test run of an old style font carving my house number into a piece of wood. I created the gcode using Inkscape which is a popular vector graphics program. For a test run I think it went fairly well.
                    I did a video of it carving. The spindle is spinning much faster than it looks like in the video. It has to do with the recording frame rate on my phone.
                    https://www.youtube.com/watch?v=S2wdsbMfSeM&t=46s
                      Looks like your spindle may have really bad runout.
                        dbemowskD
                        dbemowskD
                        @neverdie I don't think it's runout. If you look, a lot of the video is shaky. I think it is vibration from the V bit cutting into the wood. The tip of that bit may be bent a little which would cause vibration like that. I guess I'l find out when I try cutting a PCB. When I do one, I'll change to a new bit. I ordered a pack of 10. I have to see if I have any copper clad laying around.
                          Well, haven't posted to my thread in a while so I thought I'd give an update. I am close to having the Z axis complete. Below are some pictures of the spindle assembly as I have it right now.
                          This is the next part in line to be printed is the Z axis motor mount and X axis carriage. Below is a pic of the design. I have it printing now and there is 11 hours to go in the print. The longest printed part so far.
                          #59
                          @dbemowsk As it turns out, I too will have to make something similar to:
                          in order to install my new brushless motor on the z-axis. What parts should I order to go inside the plastic? I mean, obviously two ball bearing something's and some kind of threaded nut or something. I'm just not sure exactly which something's I should get, if you know what I mean. Did you buy your something's, or were they junk-drawer parts that you had laying around?
                          The z-axis that came with the 2418 is just a unit that came pre-assembled. I'm not even sure how I will take it apart. I suppose I could maybe extract the parts that are in it and re-use them, but they're melted into the plastic, so if I do that, I'm burning my bridges back to the system as it currently is. It does work, so I'm reluctant to wreck it.
                            dbemowskD
                            dbemowskD
                            @neverdie I wouldn't advise tearing apart your old one. As you mentioned, you could at least fall back to that if it came down to it. I am assuming that you are getting a different spindle motor?
                            To make that part I just used 3D printed linear bearings that the smooth rods slide into. For the threaded rod/lead screw, I used a threaded rod coupler nut like this one:
                            I just hollowed out the hex shape inside the plastic so that when it is tightened on it holds it snug. I designed the part in OpenSCAD. Because I was designing the part myself, I had free reign on the design.
                            • dbemowskD
                              dbemowskD
                              Sorry, meant to include a pic of the bearings. These fit into the outer recessed areas in the frame. I did it this way so I could change them if I had to.
                              • dbemowskD
                                dbemowskD
                                #62
                                So, I was doing some reading on how to use auto-leveling with GRBL and the CNC shield that I have. What I read was that for GRBL on an arduino, the probe needed to be connected to analog pin 5 and ground. For the shield that I have, this is the arduino pinout that I found on it:
                                Turns out that A5 is not connected on my shield and is labeled (not used/reserved). Luckily, in my parts bin I had a couple arduino uno prototyping boards. So I made a board that stacks in between the CNC shield and the uno. Here is the board with the probe attached:
                                The probe wires are made from an old dupont header cable that was salvaged out of an old PC. I figured that fit right in with the theme of the project.
                                And here is the stack.
                                I did a test and the probe seems to work. Tomorrow I will probably do a test mill of a small pcb to see how that works out.
                                For a junk parts build, I am pretty happy with the way it is turning out.
                                • dbemowskD
                                  dbemowskD
                                  So, turns out the shaft couplers that I got are kind of crappy and seem to come loose every so often. These are the ones that I got which have their set screws on opposite sides from each other:
                                  I am looking to get some replacements, but am wondering which style would be best to get. There is this style which has set screws at 90 degrees to each other:
                                  There is this style which actually clamps around the shaft:
                                  Then there is this style that also is a clamp style which says that it is somewhat flexible. The thing with this style is that I don't know if it separates at the red part:
                                  The shaft on my stepper is a D shaft, so I am wondering how well the clamp style ones will work, at least on the motor side. The lead screw is round, so that should be fine for the one clamp.
                                  Any thoughts?
                                    Any thoughts?
                                    @dbemowsk My kit came with the same blue couplers, and they came loose too. However, loctite fixed the problem.
                                      dbemowskD
                                      dbemowskD
                                      #65
                                      @neverdie I'm assuming you used loctite blue?
                                        @dbemowsk Yes.
                                          I believe the flexible couplers are for when the stepper axis isn't co-linear with the threaded rod.
