  3. DIY CNC mill from mainly salvaged and 3D printed parts
76 Posts 5 Posters 21.3k Views 6 Watching
    @dbemowsk said in DIY CNC mill from mainly salvaged and 3D printed parts:
    The way I am testing this is just using a terminal connection to the CNC and pasting the gcode into the terminal window. If there is a better way to test this let me know.
    This may be your problem, or at least a contributing factor. Try using a gcode sender, such as ChiliPeppr, instead.
    dbemowskD
    dbemowskD
    @neverdie Thanks a million. I tried the online version of chilipeppr and it seem s to be working.
    • dbemowskD
      dbemowskD
      So I did a test run of an old style font carving my house number into a piece of wood. I created the gcode using Inkscape which is a popular vector graphics program. For a test run I think it went fairly well.
      I did a video of it carving. The spindle is spinning much faster than it looks like in the video. It has to do with the recording frame rate on my phone.
      https://www.youtube.com/watch?v=S2wdsbMfSeM&t=46s
        Looks like your spindle may have really bad runout.
        dbemowskD 1 Reply Last reply
          dbemowskD
          dbemowskD
          @neverdie I don't think it's runout. If you look, a lot of the video is shaky. I think it is vibration from the V bit cutting into the wood. The tip of that bit may be bent a little which would cause vibration like that. I guess I'l find out when I try cutting a PCB. When I do one, I'll change to a new bit. I ordered a pack of 10. I have to see if I have any copper clad laying around.
          • dbemowskD dbemowsk
            Well, haven't posted to my thread in a while so I thought I'd give an update. I am close to having the Z axis complete. Below are some pictures of the spindle assembly as I have it right now.
            This is the next part in line to be printed is the Z axis motor mount and X axis carriage. Below is a pic of the design. I have it printing now and there is 11 hours to go in the print. The longest printed part so far.
            #59
            @dbemowsk As it turns out, I too will have to make something similar to:
            in order to install my new brushless motor on the z-axis. What parts should I order to go inside the plastic? I mean, obviously two ball bearing something's and some kind of threaded nut or something. I'm just not sure exactly which something's I should get, if you know what I mean. Did you buy your something's, or were they junk-drawer parts that you had laying around?
            The z-axis that came with the 2418 is just a unit that came pre-assembled. I'm not even sure how I will take it apart. I suppose I could maybe extract the parts that are in it and re-use them, but they're melted into the plastic, so if I do that, I'm burning my bridges back to the system as it currently is. It does work, so I'm reluctant to wreck it.
              dbemowskD
              dbemowskD
              @neverdie I wouldn't advise tearing apart your old one. As you mentioned, you could at least fall back to that if it came down to it. I am assuming that you are getting a different spindle motor?
              To make that part I just used 3D printed linear bearings that the smooth rods slide into. For the threaded rod/lead screw, I used a threaded rod coupler nut like this one:
              I just hollowed out the hex shape inside the plastic so that when it is tightened on it holds it snug. I designed the part in OpenSCAD. Because I was designing the part myself, I had free reign on the design.
              • dbemowskD
                dbemowskD
                Sorry, meant to include a pic of the bearings. These fit into the outer recessed areas in the frame. I did it this way so I could change them if I had to.
                • dbemowskD
                  dbemowskD
                  #62
                  So, I was doing some reading on how to use auto-leveling with GRBL and the CNC shield that I have. What I read was that for GRBL on an arduino, the probe needed to be connected to analog pin 5 and ground. For the shield that I have, this is the arduino pinout that I found on it:
                  Turns out that A5 is not connected on my shield and is labeled (not used/reserved). Luckily, in my parts bin I had a couple arduino uno prototyping boards. So I made a board that stacks in between the CNC shield and the uno. Here is the board with the probe attached:
                  The probe wires are made from an old dupont header cable that was salvaged out of an old PC. I figured that fit right in with the theme of the project.
                  And here is the stack.
                  I did a test and the probe seems to work. Tomorrow I will probably do a test mill of a small pcb to see how that works out.
                  For a junk parts build, I am pretty happy with the way it is turning out.
                  • dbemowskD
                    dbemowskD
                    So, turns out the shaft couplers that I got are kind of crappy and seem to come loose every so often. These are the ones that I got which have their set screws on opposite sides from each other:
                    I am looking to get some replacements, but am wondering which style would be best to get. There is this style which has set screws at 90 degrees to each other:
                    There is this style which actually clamps around the shaft:
                    Then there is this style that also is a clamp style which says that it is somewhat flexible. The thing with this style is that I don't know if it separates at the red part:
                    The shaft on my stepper is a D shaft, so I am wondering how well the clamp style ones will work, at least on the motor side. The lead screw is round, so that should be fine for the one clamp.
                    Any thoughts?
                      Any thoughts?
                      @dbemowsk My kit came with the same blue couplers, and they came loose too. However, loctite fixed the problem.
                        dbemowskD
                        dbemowskD
                        #65
                        @neverdie I'm assuming you used loctite blue?
                          @dbemowsk Yes.
                            I believe the flexible couplers are for when the stepper axis isn't co-linear with the threaded rod.
                              dbemowskD
                              dbemowskD
                              @neverdie I still may buy another set. I think the clamping style would be the best, but as I said, not sure how that would be on the D shaft.
                                @dbemowsk Are these not something you can 3D print? Then you could customize to the D shaft if you like.
                                  BTW, I suspect that using longer linear bearings will lead to less slop:
                                  http://a.co/0yWkPgi
                                    http://a.co/0yWkPgi
                                    dbemowskD
                                    dbemowskD
                                    @neverdie said in DIY CNC mill from mainly salvaged and 3D printed parts:
                                    I guess I hadn't thought about 3D printing them. I did order a pack of two though.
                                    https://www.amazon.com/uxcell-Encoder-Coupler-Coupling-8mmx5mm/dp/B01E0CTI42/ref=sr_1_14?ie=UTF8&qid=1522050398&sr=8-14&keywords=5mm+8mm+coupler
                                    I would tend to agree. Does your CNC use linear bearings?
                                      Yes.
                                      • dbemowskD
                                        dbemowskD
                                        Just a note to everyone. These style couplers are NOT good for the X axis, or Z axis if the motor is vertical and facing down.
                                        The problem is that the spiral part is actually quite springy. When say the X axis motor spins to pull the X axis to one side, the springy part seems to really stretch. Pushing the X axis works fine. Since my Z axis motor is mounted on top with the weight of the axis being downward, this will cause the coupler to stretch even more. My 3D printer uses these on it's Z axis which works fine because the motors face up with the pressure of the Z axis down on the couplers.
                                        The only thing about the ones that I got that I liked was the way that it clamps to the shaft. I think the clamping action is better because you get more surface area grabbing the shaft.
                                        Something like this may be the best because it is solid and there is no stretching. It also has the clamping action.
                                          Technovation
                                          @dbemowsk they should work if used as intended. These couplings are supposed to be stiff in only one direction of freedom: Rotation of the axis (=transfer the torque of the motor to the axis). The other 5 degrees of freedom should be of low stiffness to absorb misalignment between motor and axis. So the correct type of bearings should actually constrain the axis to only rotate in one DoF and not translate into the coupling.
