  2. Announcements
  • ? A Former User
    Can someone tell me how to apply this patch?
    marceloaqno
    Code Contributor
    You can download from:
    Here is a step-by-step:
    cd MySensors
    • M marceloaqno
      MasMatM
      MasMatM
      MasMat
      @marceloaqno Mosquitto v1.4.14.
        I'm using dietpi and I am not having big issues even running 2 gateway instances with 2 different radios
        A Former User
        @gohan
        I will try this...
          MasMatM 1 Reply Last reply
          • O
            O
            otto001
            wrote on last edited by otto001
            #840
            @marceloaqno :
            Still the gw stops receiving, but without high cpu usage :-(
            Fortunately I can restart the gw now using a button and this udp-scripts :-)
            cheers,
            Otto
              MasMatM
              MasMatM
              MasMat
              wrote on last edited by MasMat
              #841
              @gohan I had another sd card and tried a ready image of DietPi with Mosquitto pre-installed.
              ..keeps repeating...
              ...and sudo ./bin/mysgw -d:
              mysgw: Starting gateway...
              mysgw: Protocol version - 2.2.0
              mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.0
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: MCO:REG:NOT NEEDED
              mysgw: MCO:BGN:STP
              mysgw: MCO:BGN:INIT OK,TSP=1
              mysgw: GWT:RMQ:MQTT RECONNECT
              mysgw: connected to 127.0.0.1
              gohanG 1 Reply Last reply
                mvader
                1st patch is still working good for me. have had no issues since applying it.
                • MasMatM MasMat
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: MCO:BGN:STP
                  MasMatM M 2 Replies Last reply
                    MasMatM
                    MasMatM
                    MasMat
                    @gohan How would I interface the rest of my HA without MQTT...that's at the center of my plan really :(
                        MasMatM
                        MasMatM
                        MasMat
                        @gohan I configured:
                        ./bin/mysgw -d:
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: failed to connect
                        mysgw: GWT:TIN:ETH OK
                        mysgw: GWT:TPS:ETH OK
                          • MasMatM MasMat
                            ./bin/mysgw -d:
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            marceloaqno
                            Code Contributor
                            wrote on last edited by marceloaqno
                            #848
                              No LSB modules are available.
                              Distributor ID: Raspbian
                              Release:        9.1
                              Codename:       stretch
                              persistence true
                              allow_anonymous false
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: MCO:BGN:STP
                            mysgw: GWT:RMQ:MQTT CONNECTED
                            mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                              mvader
                              @gohan said in 💬 Building a Raspberry Pi Gateway:
                              I'm not using mqtt.
                              gohanG M 2 Replies Last reply
                              • M mvader
                                I'm not using mqtt.
                                • O
                                  O
                                  otto001
                                  #851
                                  Yesterday I cloned the latest version on a recent raspbian (9.3) and I applied the first patch of @marceloaqno .
                                  Cheers,
                                  Otto
                                    • R
                                      R
                                      romeo01
                                      How can I monitor the traffic data between the raspberry and RF module (NRF24L01) on a Ethernet gateway ??
                                      • R romeo01
                                        @romeo01 see instructions at https://www.mysensors.org/build/raspberry#troubleshooting
                                        R 1 Reply Last reply
                                        • M marceloaqno
                                            Release:        9.1
                                            Codename:       stretch
                                            persistence true
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: MCO:BGN:STP
                                          MasMatM
                                          MasMatM
                                          MasMat
                                          #855
                                          @marceloaqno What does your mosquitto.log show?
                                          So is this normal?
