  2. Announcements
  • MasMatM MasMat
    @gohan OK. I did that, the same socket error remains in Mosquitto just under new id.
    marceloaqno
    Code Contributor
    MasMatM 1 Reply Last reply
    • ? A Former User
      Can someone tell me how to apply this patch?
      marceloaqno
      Code Contributor
      You can download from:
      Here is a step-by-step:
      cd MySensors
      • M marceloaqno
        MasMatM
        MasMatM
        MasMat
        @marceloaqno Mosquitto v1.4.14.
          I'm using dietpi and I am not having big issues even running 2 gateway instances with 2 different radios
          A Former User
          @gohan
          I will try this...
            • O
              O
              otto001
              wrote on last edited by otto001
              #840
              @marceloaqno :
              Still the gw stops receiving, but without high cpu usage :-(
              Fortunately I can restart the gw now using a button and this udp-scripts :-)
              cheers,
              Otto
                MasMatM
                MasMatM
                MasMat
                wrote on last edited by MasMat
                #841
                @gohan I had another sd card and tried a ready image of DietPi with Mosquitto pre-installed.
                ..keeps repeating...
                ...and sudo ./bin/mysgw -d:
                mysgw: Starting gateway...
                mysgw: Protocol version - 2.2.0
                mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.0
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:INIT:TSP OK
                mysgw: TSM:INIT:GW MODE
                mysgw: MCO:REG:NOT NEEDED
                mysgw: MCO:BGN:STP
                mysgw: MCO:BGN:INIT OK,TSP=1
                mysgw: GWT:RMQ:MQTT RECONNECT
                mysgw: connected to 127.0.0.1
                gohanG 1 Reply Last reply
                  mvader
                  1st patch is still working good for me. have had no issues since applying it.
                  • MasMatM MasMat
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    MasMatM M 2 Replies Last reply
                      MasMatM
                      MasMatM
                      MasMat
                      @gohan How would I interface the rest of my HA without MQTT...that's at the center of my plan really :(
                          MasMatM
                          MasMatM
                          MasMat
                          @gohan I configured:
                          ./bin/mysgw -d:
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: failed to connect
                          mysgw: GWT:TIN:ETH OK
                          mysgw: GWT:TPS:ETH OK
                            • MasMatM MasMat
                              ./bin/mysgw -d:
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              marceloaqno
                              Code Contributor
                              wrote on last edited by marceloaqno
                              #848
                                No LSB modules are available.
                                Distributor ID: Raspbian
                                Release:        9.1
                                Codename:       stretch
                                persistence true
                                allow_anonymous false
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: MCO:BGN:STP
                              mysgw: GWT:RMQ:MQTT CONNECTED
                              mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                                mvader
                                @gohan said in 💬 Building a Raspberry Pi Gateway:
                                I'm not using mqtt.
                                gohanG M 2 Replies Last reply
                                • M mvader
                                  I'm not using mqtt.
                                  • O
                                    O
                                    otto001
                                    #851
                                    Yesterday I cloned the latest version on a recent raspbian (9.3) and I applied the first patch of @marceloaqno .
                                    Cheers,
                                    Otto
                                      • R
                                        R
                                        romeo01
                                        How can I monitor the traffic data between the raspberry and RF module (NRF24L01) on a Ethernet gateway ??
                                        • R romeo01
                                          @romeo01 see instructions at https://www.mysensors.org/build/raspberry#troubleshooting
                                          R 1 Reply Last reply
